Question about Refrigerators
Maytag mtb1954dr Both lights in fridge weent out simultaneoulsy.
Light not working in Maytag Plus 134A Refrigerator
Sure you've got power to the bulbholder? Check the switch
Sep 04, 2012 | Maytag Refrigerators
Fridge freezer probs
From the sound of it I would looking at the evaporator fan in the freezer. This is what circulates air and actually cools the refrigerator as well as the freezer
May 21, 2012 | Maytag Refrigerators
How do I reset the 'change water filter' light~the filter no# is UKF003
Hold the botton on each side of the light in , until they start flashing .
Nov 12, 2009 | Maytag MSD2456G Side by Side Refrigerator
Top freezer fine, frig not cold. fan,condensor cleaned.
Set both cold controls on the number 4. See if this helps
Jul 15, 2009 | Refrigerators
Just moved my Maytag fridge and it won't restart.
let it sit for about 36hrs without power.Then switch it back on it should start ok.adrian
Mar 28, 2009 | Refrigerators
2003 Maytag Plus Dual Cool Side by Side
Check to see if the bacl of the fridge is iced over, if it is the fridge is not defrosting, 99% of the time it is the defrost control circuit board located in the upper right hand corner of the fridge.
Jun 09, 2008 | Maytag MZD2766GES Side by Side...
Maytag lock and filter change
to reset the change filter light:
Press hold the LIGHT and LOCK pads until the CHANGE FILTER light blinks (approx. 3 sec.)
Dispenser lock:
to interrupt power to the water and ice dispenser so it cannot be used , press the lock pad 3 times within 10 seconds.
Jan 21, 2008 | Maytag MSD2454G Side by Side Refrigerator
Maytag fridge
Without knowing the type of fridge(side by side, freezer on top etc.) all I can offer is this: Somewhere between the freezer and the fridge there's an opening thermostatically controlled to transfer cold air from freezer to the fridge. Most have a fan to move the air. So either the fan (if so equipped) stopped, and need to replace, or opening is stuck closed, or plugged.
If freezer is working fine, this is the only problem I can think of.
Hope this helps
Dec 15, 2007 | Maytag MTB1504A Top Freezer Refrigerator
Maytag french door fridge model mfi2568ae
unplug it. wait 15 minutes. plug it in. any change?
Jun 06, 2007 | Maytag MFI2568AE Side by Side French Door...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
