Question about Pentair Pool & Spa
Pantera pump buscamos caldera
Caldera spa error code four dashes and won't run after replacing pressure switch what next
sounds like shorted temp sensor or recirculation pump isnt working
Aug 19, 2014 | Pool & Spa
Caldera olympia highland spa keeps tripping breaker
with power off take heater wires off make sure to mark them so you know which is which if it doesnt blow fuse it is heater element if it still does hook back up then try to disconnect the recirculation pump just keep eliminating things
Mar 02, 2014 | Caldera Spas Highland Series Olympia Model...
Pantera pool filter manual
Exactly where is the pump leaking?
If it is leaking between the wet end and the motor then you need a new shaft seal sometimes referred to as a mechanical seal.
You will need to know the brand of your pump when you start searching for the replacement.
Rod
US Parts Center
May 06, 2013 | Hayward SAND FILTER, PRO SERIES
Labels Gone
I also have the same problem with the label on my filter. My pool dealership said I would need deal with Wicor directly. I see two other people with the same problem, however, neither has been responded to. It is VERY difficult to run your pool properly if you don't have your control lever labeled. An immediate response would be greatly appreciated.
Apr 23, 2010 | Wicor Industries Master Plumber Geyser...
Want to install xp by caldera dr dos
The problem is hard enough for beginners . First :
1.DR DOS is used by ASUS . DR DOS isn't MS-DOS (Microsoft), just 99% compatible with it . You have access with it on whole HDD+cd/dvd but , because drdos will enable only 8MB RAM you can't install winnt.exe from i386 . There are at least 2 solutions :
a. if drdos is enable because u reseted BIOS try to change bios according to a better result (avoiding Caldera) and start a nice windows installation;
b. u may use another desktop/laptop until the first restart (in installation) ; u must try to use a computer with ~motherboard for best results.
Don't forget that DR DOS Caldera is almost every time used on ASUS MBs with all on board and you must have a PS2 keyboard/mouse to use any kind of DOS . I read sometimes that DRDOS is a soft used by Microsoft which it's wrong - there isn't any link between drdos and any windows system , genuine or not .
DRDOS problem might appear because it's a soft put on ASUS MB cd driver and , sometime, might be on a BIOS ROM .When u will boot with the MB cd driver in this kind of problem might occur .
Other way Caldera may appear is when u have a windows cd made careless with NERO and caldera will appear no matter the MB .
Mar 24, 2009 | Microsoft Windows XP Professional SP2
Pool & Spa Logo
15 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
