Question about Homedics Ultrasonic Cool and Warm Mist Humidifier
How do I clean my HoMedics UHE-OW14 humidifier
Homedics Humidifier UHE-CM45
Check the float that is monitoring the water level. Sometimes lime and calcium build up will restrict the motion of the float. If it's a probe level, check to make sure there is no hard water build up on the probes that will restrict continuity from one probe to the other
Aug 15, 2016 | Humidifiers
I have a Cool Mist Homedics Ultrasonic humidifier, Model UHE-OC1A that has stopped working...I have cleaned it, the small lights go on when turned on, but no mist is coming out ... ???
In the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Feb 24, 2015 | Homedics Cool Mist Humidfier - Uhe-oc1 -
My homedic s humidifier is leaking.I turn it on in the evening and next morning I see it in a puddle of water.Happens every time.
Chances are it is just condensation not leakage if it's only wet when its running. Nothing you can do except put a towel under it.
Dec 01, 2014 | Homedics Cool Mist Humidfier - Uhe-oc1 -
UHE-WGP1
https://www.walgreens.com/store/c/walgreens-humidifier-replacement-wick-filter/ID=prod6242355-product
Mar 09, 2014 | Walgreens Humidifiers
Ultrasonic humidifier's fan isn't running, the light indicated red instead of blue, and there is no mist coming out. How to fix it please since we cannot afford for another one right now.
I had the same problem. Looked up the manual online. Red light indicates water level is low I had just refilled the tank so that was not the problem but manual said to make sure water tank was firmly, securely seated on base. I unplugged the unit, unscrewed the plug on the tank and screwed it back on and then made sure the tank was securely seated on the base, plugged it in and it started working. If the tank is full you may just have to make sure the tank is fitting properly in the base.
Feb 05, 2014 | Homedics Uhe-oc1 Cool Mist Ultrasonic...
What is the box with lightning bolt inside? turn on humidifier and just the orange light above this comes on but humidifier not working?
I looked at the Owners Manual for your humidifier online, but could not locate what you described.
However, it is manufactured by Homedics and you can contact their Customer Service Dept @
800-466-3342 Mon - Fri, 8:30a - 5pm ET for help in solving your problem.
Mar 07, 2011 | Walgreens Cool Mist Ultrasonic 2 Gallon...
Homedics Ultrasonic Cool and Warm Mist Humidifier Logo
35 people viewed this question
Top Homedics Humidifiers Experts
Mack Baxter
Dennis
Are you a Homedics Humidifier Expert? Answer questions, earn points and help others
