Allen&Heath Xone:4D not detected by Macbook Pro
Macbook Pro won't detect my Allen&Heath Xone:4D mixer as a viable output solution under sound settings even though I got the correct drivers for my OSX installed. The cable and USB ports have been checked on other devices and work properly and so does the mixer. Any ideas why this incompatibility seems to happen?
  • 4 Answers
The drivers may just need to be uninstalled /reinstalled.
i have had the same problem with various hardware on macs.
they dont work, then inexplicably they do! you could try an older driver.
maybe a reinstall on OSX? Its possible it has become corrupted
Posted on Feb 15, 2014
SOURCE: Toshiba Tecra 9100; "output device error" message
No sound? The only solution I've found is to get a USB headset like the Logitech USB Headset 20. I have had this same problem with my Tecra 9100 for almost 6 months. I tried on a pair of USB Headset and it works! because it bypasses your internal soundcard. The downside is that if you have a great pair of speakers on your laptop, then it's kind of a waste that you can never use it. But at least, with this, you can now listen to CDs and chat on the internet
Posted on Nov 21, 2007
sparky1500
  • 1066 Answers
SOURCE: no midi out device is detected
If you dont have a joystick port on the card, then you dont have a midi out. make sure your "out" or"playback" is patched to your card's synthesis engine, wavetable or GM/GS midi playback, and not to a "midi out" which really means a physical midi port.
Posted on Mar 01, 2008
SOURCE: Problem with Windows XP recognizing Creative Sound Card
which driver saport w/xp i have ct 4780 sound card
Posted on Apr 21, 2008
SOURCE: Edirol ua-25 not detecting midi but audio works fine
**** THIS IS THE SOLUTION ****
On the back of the UA25 there's a switch called "Advance" - this needs to be set to ON for the device to work as a MIDI interface.
LC (UK).
Posted on Sep 08, 2008
craigjamesbt
  • 65 Answers
SOURCE: MBox 1 Compatibility with new Macbook Pro Unibody and OSX 10.5.6?
unfortunately any pro tools application below version 7.4.2 is not compatible with leopard and I don't think you can use mbox 1 with the universal mac I may be wrong but I wanna say I tried a while back and even garageband wouldn't find it anymore but you can check for sure by going to the applications folder then open the utilities folder in there is an application called "Audio Midi Setup" and you can select the mbox in there if you see it but if not there is no patch or driver that I know of to get it working unless you upgrade pro tools which if you do upgrade I suggest getting mbox 2 and getting LE with it
Posted on Apr 26, 2009
Filter Knob and Buttons move from left to right
If you pull the knobs off, you will find lock nuts under them. You could tighten them up. See if the knobs have set screws on them to lock them in place before pulling them off. On Allen & Heath, I don't think they do but, just in case.
Mar 21, 2014 | Allen & Heath Xone:92 DJ Mixer
What is compatible mixer for technics sl-dq33
Take one with a balaced output and well if you want a nice sound then the allen & heath xone 23 http://www.allen-heath.com/ahproducts/xone-23/ is real nice and well build and they have also the c version with build in sound card, but that unit is a lot more expensive . But when it comes to soundquality, this the one. Numark makes perfect tables, especially the x serie , i have a x-5 for scratching but my denon has the best parts for it\'s price , with real good capacitors, only your choice will be the xone. and costs 300 euro, three times more expensive then the numark. and with build in soundcard 200 euro extra. For less you don\'t buy a lot and don\'t take the reloops, those are very old and upgraded four times. Greetings richard
Dec 29, 2013 | Technics Audio Players & Recorders
Allen & heath xone 42 fader problem channel 1
Carbon track on fader 1 is open because of wear or just broken, if you are getting sound then the ground carbon track is out but certainly the problem lies in the pot.
Nov 04, 2013 | Allen & Heath Xone:42 DJ Mixer
Midi problem
i think this problem is related with the power of the mixer, see the guide of that mixer and learn how to connect it on right way.
good luck
Feb 17, 2013 | Computers & Internet
Only half the volume on the left channel of the mixer. Why? :(
Does the left meter do the same thing? If the meter matches the right one, I would suspect the volume potentiometer on the powered speaker. Try exercising the volume knob. There might be some oxidizing on the potentiometer.
Oct 25, 2017 | Allen & Heath Xone-22 2 Channel Dj Mixer
I have an allen and heath Xone 22 Mixer. Its great, except due to the lack of a power switch I pulled the ac adapter/power cord out too many times and now it has a really bad, loose connection. It works,...
Usually the connector that is board mounted is the problem. I would OPEN the unit as there may just be broken solder at the connector inside. If the connector requires replacement, find one at Digikey.com by searching for "power connector coaxial".
Hint: In the future install one of those little lamp switches that are in a little plastic box with knurled knob sticking out the sides. ONLY break ONE wire from the adapter to avoid getting the connections reversed. Since the wires are smaller than lamp cord, tack solder the wires to the piercing points of the switch .
Apr 11, 2011 | Allen & Heath Xone-22 2 Channel Dj Mixer
Hi I have two marantz amps witch cut in and out when run from
In stereo terms your system is "clipping" which means you are pulling more amps than the system can handle. If it happens only when you use the mixer, I'm thinking the mixer cant handle the power. Check the specs, It should show maximum amp input.
Jun 04, 2010 | Audio Players & Recorders
Samsung HLN5065W freezes in black / White screen
Picture freezing that is the symtoms of depected DMD modules...
Just click below for electronics store you can order online;
Partstore.com.
Vance Baldwin Electronics
http://servicemanuals.vstore.ca/
http://www.electronix.com/catalog/
Hope this may help;
Regards,
VOTIT
Aug 21, 2008 | Samsung HLN5065W 50" Rear Projection...
Adding new equipment?
http://www.allen-heath.com/US/dl.asp?file=288
Apr 07, 2008 | Allen And Heath Xone 92 4-Channel DJ Mixer...
Computers & Internet Logo
237 people viewed this question
David Payne
David Payne
