Question about Winter Sports
Rival flow boot dial - Winter Sports
Dial knob cracked in half. Can it be replaced/
sure, i would go to the rival website, they likely have replacement knobs
Oct 23, 2013 | Rival 6445 6.5-Quart
How do you turn on a rival steam wave iron
The Manual for the Rival IR699 and IR999 Steam Wave Iron may be downloaded in PDF from the following link:
http://www.rivalproducts.com/manuals/MANUALS/IR999_43_64403016.PDF
STEAM IRONING
1. Fill the Water Reservoir.
2. Plug the cord into a 120-Volt AC outlet.
3. Select the fabric setting you desire using the dial. Allow the iron to
heat for 2 minutes. While the iron is heating, make sure it is sitting on
its heel rest on a stable, protected surface.
4. Turn the Steam Selector to the appropriate setting. Begin Ironing.
IMPORTANT: When not ironing, always set the Variable Steam Selector
to (Dry) and the Fabric Select Dial to OFF.
Jun 19, 2012 | Rival Steam Wave Iron
I have a Rival Crock Pot slow cooker. I do not have the directions to use the meat probe. What dials do I set?
The Instruction Manuals for Rival Slow Cookers are available on-line:
http://www.crock-pot.ca/CustomerService.aspx?id=man
For some reason it does not seem easy to match up model numbers; however, I believe the manual posted for the SCVP600HSS will provide the information you need for use of the temperature probe:
http://www.crock-pot.ca/Manuals/MANUALS/SCVC600SS-CN_43_41977702.PDF
Refer to pages 9 -11 of the PDF.
Apr 02, 2011 | Rival SC7600 6-Quart
Is the 1 on the dial faster cooking than the 2?
The Ower's Guide for the Rival 3745 4.5-Quart Crock-Pot Slow Cooker can be found here:
http://dl.owneriq.net/1/1a941b3f-df28-4cb1-b8c4-e50ed3f70a72.pdf
Turning the switch from the off position, the first setting is Low; the second setting is High.
Feb 16, 2011 | Rival 3745 4.5-Quart
It is a dial temperature control
Yes. This roaster is a dial-type temperature control. For more information on it, you can follow this link to view the owner's manual in case you don't have it by chance:
http://www.rivalproducts.com/manuals/MANUALS/RO180BR-C_43_18972586.PDF
I hope this helps! :)
Nov 04, 2009 | Rival 18 Qt Roaster Oven with Buffet...
No instruction manual rival 3040-vg slow cooker
plug into three prong outlet, turn dial to desired setting,
now if you want my moms stew recipe thats a different story
Oct 10, 2009 | Rival 3040-VG 4-Quart
Dial indicator on crocket pot and handle on lid broke
you cannot buy them . but a big wodden knob from a hardware store works great on the top and its only a 1.00 ...... the side handles are made from the same cheep plastic and snap off without warning , so dont move the pot when full .people have been burned with hot food from this crockpot !
Feb 17, 2009 | Rival 38601 Smart Pot 6-Quart
Winter Sports Logo
100 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
