Question about Kenmore Elite Oasis 27052 Top Load Washer
F 51 code
Washer stopped with 17 minutes left during rinse and drain cycle. Blinking f51 code, but I think the machine may have been loaded with an unbalanced portion of wet towels. I balanced the clothes, unplugged the machine for a half hour and tried another cycle. Went about a minute and then the beeping and flashing f code. Any suggestions?
    Prodigy:
    An expert who has answered 500 questions.
  • Kenmore Expert
  • 517 Answers
Check the filter
Posted on Feb 08, 2014
4 Suggested Answers
SOURCE:
SOURCE: washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Posted on Nov 22, 2007
SOURCE: he2 washer flashing code f51
check hose inside mine had two baby socks clogging it up
Posted on Feb 14, 2008
  • 1028 Answers
SOURCE: F01 Error code
most likely suspect main control bd
Posted on Apr 19, 2008
How di I stop the F:51 from flashing where the time left for a load to be completed stopping the load in the washer to wash, rinse and drain?
If its a Whirlpool machine, F51 has something to do with whats called a rotor position sensor, It tells the machine that the bowl is or isn't turning. Check and make sure the bowl hasn't jammed up.
Jan 01, 2015 | Washing Machines
After working well for six months, my washer now expels water at random points during the wash and rinse cycles.
Check inside the fill hose for debris. There is a screen designed to block debris from getting inside the machine valve. If the screen builds up with debris the water slows down. Sounds like the water is filling too slow. Also the unit and/or the load may not be balanced causing it to stop and drain out. If it's okay then see what lights are blinking when these events occur and post here.
Jun 06, 2013 | Haier HLP21E Top Load Washer
Rinse and spin cycle keeps repeating at 11 minute time to 17 minute time and won't stop
Sounds like your washer does not empty enough water for the spinning to stop. Have you check that the filter(s) are not clogged?
Jan 23, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
F51 error
Hello, the F51 code is a motor rotor position sensor failure. It's best to call in the warranty service as there is a bunch of tests that need to be run to determine if it's the sensor or control board. If the tech wasn't any help, contact the store for a replacement.
Thanks
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Stops during wash cycle
my cabrio agi washer will stop constantly during the wash and rinse cycle and it will say F51 and dL
Sep 17, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Machine keeps flashing F-51
This happened to me, everytime I washed clothes it lite up F51 and wouldn't go through the cycle to drain. I had to manually put the machine on drain and spin to get the water out.
After three times of having the repair man come I called Whirlpool and said I had a lemon and it couldn't be fixed and the machine was replaced. They are allowed to try three times to repair the machine for the same problem, like it lighting up F51 and then they have to replace the machine as a lemon while the machine is still under warranty.
I hope this was of help. The delivery man said that the machines are bounced around so much during transit that it's no wonder they have problems.
Feb 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer stops and must be restarted flashes F51
there is a updated wiring harness and sensor on the the bottom of this tub on the motor. It needs replaced
Nov 13, 2008 | Kenmore 22422 Top Load Washer
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
178 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
