Question about Pioneer VSX-822-K
How to repair overheat warning on pioneer vsx 822
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: My Pioneer Elite VSX-91TXH is
Well, is it actually getting hot?
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Sep 03, 2011
one5oneproof
SOURCE: Pioneer VSX-822-k Subwoofer problem
I had the same problem. Dont know why the receiver set it up this way but grab your remote, go down to the lower right and select ch setup. Keep on pressing it till your receiver says SW. Then press lev+ on your remote to change the db on your powered sub.
Posted on Oct 31, 2012
Whats the problem?
It's a safety , possibly your volume is cranked up too high or you could have something hooked up wrong
Feb 18, 2015 | Pioneer VSX-822-K
I have a pioneer VSX-822k receiver. My older Runco CL-710 projector with DVI will not display anything from the Pioneer's HDMI output. (using a monoprice HDMI to DVI cable designed for this) The sourc
it is not compatable with 1080p,it says so on pg 17 of the projector manual,This unit is compatible with the following computer resoultions: 1280x720, 1024x768, 800x600, 640x480,you cannot use it with the receiver unless you use rca cables http://www.projectorcentral.com/pdf/projector_manual_2126.pdf
VSX 822 5 1 Channel 3D Ready Receiver
Oct 18, 2014 | Audio Players & Recorders
Pioneer vsx 822 k shuts down when i turn up the volume
Could be caused by a bad speaker, try disconneting speakers and see if it still happens.
Jan 10, 2014 | Pioneer Vsx-822-k 5.1-channel 3d-ready...
My Pioneer Receiver VSX-519V has a blinking HDMI light and won't show video.
You guys mentioned the reset via the front panel, and I tried that with this very same issue on my VSX-822-k and it worked!
thought I would post the instructions for anyone else that lands here:
Reset the main unit if the receiver is generally not operating correctly. Switch the receiver into standby mode. Hold down the "BAND" button while pressing the "STANDYBY/ON" button for about two seconds. When "Reset?" appears in the display window, press the "AUTO SURROUND/ STREAM DIRECT" button. "OK?" appears in the display window. Press "STEREO/A.L.C." to confirm. "OK" appears in the window. The system has been reset.
Oct 28, 2012 | Pioneer Vsx 519v-k 5.1 Home Theater 550...
Vsx 822k network problems
did you ever resolve this? i am having the same problem. i even r i even took it in for a warranty repair....but when i go it back it was still doing the same thing!
Oct 23, 2012 | Pioneer Vsx 822-k Av Network Receiver -...
Go to manual setup, selct the subwoofer and set it to Pus.
Jul 29, 2012 | Pioneer Vsx-822-k 5.1-channel 3d-ready...
App err
PDF]VSX-D414 VSX-D514 - Pioneer
www.pioneer-latin.com/downloads/xre3077a.pdf
Increase the separation between the equipment and receiver. - Connect the .....AUDIO/VIDEO MULTI-CHANNEL RECEIVER VSX-D514. RCE. VSB. MODE.
Pioneer VSX-D514 Receiver Repair Questions,... - Fixya
www.fixya.com > Forum > Audio & Video Receivers > Pioneer
Recent Pioneer VSX-D514 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
app err Turns on then says amp err. - Fixya
Jan 26, 2012 | Pioneer VSX-D514 Receiver
Pioneer VSX-822-K Logo
56 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
