Question about Iomega 1TB Desktop USB 2.0 Hard Drive
"path length too long" for transferring files to usb 2.0 from my Windows 8.1 computer.. What is maximum??
How do i transfer photos from a usb to samsjng galaxy 3 tablet
To transfer files directly from a usb flash drive you will need a USB on the go adapter. If your tablet is rooted, StickMount will make the process much easier.
You can also use a computer to transfer the files, plug both the tablet and the flash drive into a computer and use windows to transfer them between the two devices.
Additionally you could use some sort of cloud storage to transfer them, attach the usb drive to the pc, and copy the photos to a service like Google drive or Dropbox, then simply download the files onto the tablet using that services app.
Oct 12, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
3 tbs
Does not need a driver.
COMPATIBILITY:
  • Formatted NTFS for Windows XP, Windows Vista, Windows 7 or Windows 8
  • Requires reformatting for Mac OS X Tiger, Leopard, Snow Leopard or Lion
  • Available USB 3.0 or USB 2.0 port
  • USB 3.0 port required for high speed transfers
Jun 26, 2014 | Toshiba Canvio Computers & Internet
Path length too long
The Windows error is complaining about the length of the full path. The full path includes the entire path as well as the file name. If that 'Full Path' is longer than 256 characters, then you may run into this error.
Feb 07, 2014 | Iomega 1TB Desktop USB 2.0 Hard Drive
My Hitachi Touro 4TB external hard drive get stuck every time I try to transfer large files. How do I fix that? The format is NTFS and the files are 4g and up.
External hard drives are popular portable storage devices because they allow you to back up files such as documents, music and videos, and transfer files from one computer to another. While external hard drives vary in storage capacity, they are ideal for storing large files such as videos and animations. Files of this nature consume volumes of hard drive and memory space and are best stored in external hard drives. Whether you are using Windows or Mac OSX, transfer large memory consuming files to your external hard drive quickly and safely. Connect your external hard drive to your computer using the Firewire or USB cable that came with your portable storage device. If its transferring to slow the usb lead might be at fault or you might need a usb 3 card which makes data transfers much faster USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Power on your drive. Some external hard drives do not have a power button, because your computer powers them on automatically using the Firewire or USB cable. Click the Windows "Start" orb and click "Computer" or "My Computer" to launch Windows Explorer if you are using a Windows PC. You should see your external hard drive in the "Drives" section next to the "Local drive (C:)" drive. If you are using a Mac, you should see your external hard drive on the desktop. Double-click your external hard drive to open its hard disk window. If you have any content on your external hard drive, you should see it in this window. Drag files from your computer to your external hard disk's window. Because you are uploading large files, make sure their memory s do not exceed your drive's total memory. Your computer shows a status bar displaying the upload progress for each file you are transferring to your drive. The upload time varies depending on the of the file. Close the hard disk window when you finish uploading the files you want to store, and then click the "Safely Remove Hardware" icon on the System Tray next to the clock, if you are using Windows. The hardware removal window launches. Click your external hard drive's icon in the hardware removal window, and then click "Stop." When prompted, disconnect your external hard drive from your computer. Drag your external hard drive's icon from the desktop to the trash bin on the dock if you are using a Mac. Disconnect your drive from your computer. If you right click in the bottom toolbar select applications to see whats running at the time when transferring the files might be a virus or malware if you see something running that should not be select end now also processes to see what ticking over in the background
Hope this helps b>
b>
Dec 14, 2012 | Hitachi 4TB Touro Desk DX3 USB 3.0 Hard...
Download photos to pc
If you're photos are saved in your phone's internal memory, transfer them first to the memory card.
To move files from the phone to the card, perform the following steps:
1. At the main screen, tap Menu.
2. Tap My Files.
3. Tap Phone at the top of the screen.
4. Tap the desired folder.
5. Tap the desired file.
6. Tap Options.
7. Tap Move to.
8. Tap Memory card.
9. Tap the desired folder.
10. Tap Open.
11. Tap Move to.
Once you have transferred your photos to the card, the next step would be transferring those photos from the card to your computer.
To move files from the card to the computer, perform the following steps:
1. Plug one end of the USB cable into the USB port on the top of your phone.
2. Plug the other end of the USB cable into a USB port on your computer.
3. Click File Transfer on the phone.
4. If required, tap OK on the phone to exit to the main screen.
5. On the computer, in the Removable Disk dialog box, click to select Open folder to view files using Windows Explorer, and click OK.
6. Navigate to the file on your memory card that you wish to copy.
7. Right-click the file and click Copy.
8. Navigate to the desired folder on your computer.
9. Right-click and click Paste.
10. When you are finished transferring files, tap Back on the phone.
11. Tap OK to exit the card reader mode.
12. Disconnect the USB cable from your phone and from your computer.
http://www.cellphones.ca/answers/how-do-i-download-photos-from-my-phone-to-my-pc/
Nov 16, 2012 | Huawei 2x Hb5a2h 1150mah Battery For U7519...
System files are missing
How to recover system files on H10?1.4_4_2012_7_54_27_am.jpg2. LCD on H10 displays "USB Connected" and then double click "My computer".
3. Click right mouse on "H10" drive and select "Properties"
4_4_2012_7_55_46_am.gif4. Go to Tools -> Error checking -> Check Now -> Check "Automatically fix file system errors" and click start.
4_4_2012_7_56_53_am.gif5. It will take you around 1~2 minutes, 5 minutes at maximum.
4_4_2012_7_57_35_am.gif6. Go to "Tools -> Folder Options -> View" on Windows Explorer. Uncheck "Hide protected operating system files(recommended)". Click OK to save properties.
4_4_2012_7_58_37_am.gif4_4_2012_7_59_08_am.gif7. Double click on "H10 drive" and delete "System" folder.
8. Open iriverplus and transfer music.
If your device was detecting by USB cable. Then update the firmware for this device:
1. Please open iriverplus3 and connect your device with USB cable.
2. After connecting your device, please follow the steps below to upgrade New Firmware
** Tools -> Portable Device -> Firmware Upgrade **
3. After upgrading the New Firmware, please check the firmware version before playing device.
** Setting -> Advanced -> System information **
Hope this will resolve the issue.
Regards
Nandu
Apr 04, 2012 | iRiver H10 MP3 Player
Sir i have purchased Roland gw-8 keyboard in the usb port when i put any flash drive it power is shown but it doen't read and it gives message usb memory not ready sir please solve my problem?
Read pages starting with 49 in your user's manual.
You MUST format the USB flash in the GW-8 before it can be used. Formating in a computer MAY b e inadequate as sometimes the formats have special quirks.
Also pay attention to the MAXIMUM file name length... It is 16 characters MAX !!!!
Feb 16, 2011 | Roland GW8 Keyboard Arranger
Verbatim USB 8GB file copy problem
ITS virus problem which is playing with the inf file of the usb drive.
also another possibility is 1) the usb port ihas loose connections and disconnects i between drive sensing
2) certain 8 gb drives go back to a capacity of 2 gb drive if one formats it accidentally .
Sep 18, 2009 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Trying to trainsfer program from my computer to the tevion memory
Place the flash drive (mem stick) into the USB port of the computer. Copy the files to it. Remove it from the computer and put it into the USB port of the other computer. Copy the files from the flash drive to the computer hard drive.
The memorystick (flash drive) will show up as another disk in File Manager/Windows Explorer, and disappear when the device is removed.
You cannot transfer already installed games from computer to computer, only the files. The game must be installed from the original CDs in order to function.
You can transfer documents, music, pictures, etc.
Jun 12, 2009 | Computers & Internet
Iomega 1TB Desktop USB 2.0 Hard Drive Logo
22 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
