Question about Toro 1800 ELEC SNOWTHROWER
Scraper 99-5390 assembly
How to assemble / replace the scraper
  • 20 Answers
Remove the four carriage bolts holding the bar in place. Underneath these are held with locking nuts and will probably need cutting to remove.
Posted on Jan 14, 2015
Plotter hp 4000 message maintenance #2 required
Maintenance kit 2 includes the following
This Preventive Maintenance Kit contains the following components:
?? Complete Carriage Assembly (? Page 8-53).
?? Ink Supply Tubes and Trailing Cable (? Page 8-33).
?? Scan-Axis Motor (? Page 8-59).
?? Belt Assembly (? Page 8-58).
?? Most Left Spittoons (? Page 8-43).
?? Middle Left Spittoons (? Page 8-44).
?? Scraper (located on the Service Station).
Once installed, you reset the counters, link for manual:
http://www.partsnow.com/docs/service-manuals/hp-designjet-4000-service-manual.pdf
Feb 11, 2015 | HP Office Equipment & Supplies
Changing 2000 Ford F250 tail light
First check in the bed for access panel. If there is no way to access from behind (normally torx[star] bit) use a plastic scraper to gently pry behind assembly.
Jan 22, 2015 | Ford Cars & Trucks
Install scarper blade toro powerlite mod. 38182
On everyone I have ever seen, there are just three bolts that go through it into the auger housing. There is a notch that the scraper has that fits on to the end of the housing. You can see the drawing for it here - http://www.partstree.com/parts/?lc=toro_consumer&mn=38182%2C+Powerlite+Snowthrower%2C+2009+%28SN+290000001-290999999%29&dn=3358-429-383366-0008
I just picked one of the models for 38182 cause i think they are likely all the same, but if you want to be sure, use the list here - http://www.partstree.com/parts/?lc=Toro+Consumer&mn=38182 and choose the one that matches your serial number range. Then select the drawing to see the rotor assembly. Should be pretty easy except sometimes the heads of the bolts to keep the scraper on get wore down if the scraper bar wasn't changed when it should have been.
Jan 09, 2015 | Toro Power Clear 210R Part 38587
How to replace the scraper blade on a 123527HV
Oct 05, 2013 | Husqvarna Garden
How do I replace the coffee scraper and Spring?
Only help I can give you now is to phone the shop and ask. Next would be to take the machine to the shop and ask them to assist you. Kolbrun
Sep 18, 2013 | Gaggia Titanium Espresso Machine
CD Player get stuck after dead battery
hi..
This is a faulty loading motor. you will need to replace the entire optical lens assembly in this case. the motor is part of the assembly...
thank u
rate me!!
Jul 27, 2009 | 1998 Lexus LX470
Jamming paper at fuser. Paper try is pulling fine. Stops at Fuser
Open the fuser and look at the exit area. There should be little scrapers (pick off fingers). These are mostly spring loaded and rest on the upper fuser roller. If the spring or pressure level is missing or detached, the scraper /finger will hang in the paper path and catch the paper. There could be 4-6 scrapers. The main scrapers needed are the 2 ends and the middle. So if a spring is missing you could take the scraper/ finger out. **** MAKE SURE AS TO NOT SCRAPE THE FUSER ROLLER AS THIS WILL LEAVE A MARK ON EVERY COPY*****
Dec 30, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Whirlpool gold model GU100XTLB0, is not cleaning, leaving soap in the tray. have replaced the fill valve assembly, still doing same thing. what else can i check?
I found that the chopper assembly shaft had snapped in half, the scraper was not rotating to clean the screen so it was completely clogged. called the local parts supplier and they had the part in stock for $25. I will assemble tonight, but this should correct my problem. As dirty as the screen was I can see why the water pressure in the dishwasher was extremely low and not cleaning and leaving soap in the tray. To all you home "do it yourselfers", check the chopper assembly. From the looks of the broken shaft, it appears as if there was a quality problem with the casting of the plastic shaft. The shaft had air bubbles inside the shaft.
Dec 16, 2008 | Dishwashers
Chrysler Sebring 2002 convertible door assembly
use a scraper and remove the water shield as its called, very slowly . make sure to try and keep as much of the sealer on the water shield as possible. if you want to completely remove it you also have to disconnect all the wires leading to the door panel
Jul 07, 2008 | 2002 Chrysler Sebring
Toro 1800 ELEC SNOWTHROWER Logo
77 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
