Question about Marantz Audio Players & Recorders
Hook up skytec 1000w passive speakers to to skytec 1000w spl amplifier
MNfisherman
  • 11896 Answers
SOURCE: WIRING A SPL DK2-340
Posted on May 09, 2009
  • 1114 Answers
SOURCE: passive radiator speaker wiring
Passive Radiators are not driven by the amp. They have no voice coil and no power goes to them. They are used to enhance the bass or lower frequencies in a speaker system. They work by utilizing the back pressure that a driver (woofer) produces. When a woofer produces sound, it moves forward and backwards inside the speaker cabinet. This backward motion is what drives the passive radiator. So in order for the passive radiator to work, it would have to be placed in speaker cabinet along with a woofer that is hooked up to an audio amp.
Posted on Jul 24, 2009
etirbynnor
  • 655 Answers
SOURCE: Amplifier displays "CUR"
Hello anwbrown,
The "CUR" display means that the amp is drawing excessive current and the protection circuit is activating. Too low impedance or shorted speakers will cause the amp to draw excessive current.
The Alpine V12 is a Class D mono amp with only one set of speaker outputs. All versions, M301, M501, and M1001 are only stable to 2ohms. Assuming that all 6 of your connected subwoofers and speakers are 4ohm and they're all connected in parallel, the amp sees a .67 ohm load, far below it's rated impedance.
When brand new, the amp could probably operate at low to moderate volume levels without drawing excessive current. But as electronic components age, their tolerances change and they become less able to withstand excessive current or mismatched impedances.
I'd get a 4-channel amp and drive the 4" speakers off the front channels and the 6X9's off the rear channels. And just power the subs off the V12 making sure that they are connected to show a minimum load of 2ohms.
Hope this helps.
Posted on Jul 29, 2009
JOHN RESTY
  • 38 Answers
SOURCE: Car Ampli Problem
Use x21000w speaker size 10 that is good for your ampli..........theres no over heat because your ampli using a battery of your car thats is 12amp supply your ampli
Posted on Sep 29, 2009
  • 47 Answers
SOURCE: tri-mode amplifier hook-up
you dont have to have a crossover to hook up ur amp 2 ur subs
Posted on Feb 28, 2010
Connect skytec subwoofers passive speakers
Be sure the sub pre-out is intended to drive a powered sub (RCA to RCA). Is there a sub power indicator on? If not, there may be a blown internal fuse. Also some custom speaker configurations such as speaker size can override what you think you want to do.
Feb 01, 2014 | Pioneer Audio Players & Recorders
I want to purchase a behringer 15 band graphic equaliser and connect it to a numark 5000fx mixer via skytec pro600 power amp can you help.
The signal path to follow is explained below:
*Audio Source(Cd/LapTop/Ipod)output to,
*Numark 5000FX Input, Then master/main outputs go to,
*Behringer FBQ1502 Inputs, then outputs go to,
*Pro600 Power Amplifier Inputs, then power amp outputs hooked up with a speaker each side.
Hope this helps.
Nov 06, 2013 | Behringer FBQ1502 Ultragraph Pro Dual...
How do I hook up passive subs to my board
Sub outs needs an active speaker.
An active speaker have a built in amplifier and preamplifier.
For a passive speaker it needs an amplifier.
Oct 01, 2012 | Mackie 2404-VLZ3 Mixer
How do I hook up two powered 15's and two passive 15's to this mixer(1202-VLZ3)?
You connect the powered 15's using balanced cables. The passive speakers you will have to get an amplifier for as the mixer does NOT have a powered output, only line-level audio outputs.
The powered speakers MAY have audio line level outputs to continue to other powered speakers or, as in your case, external amplifiers to drive your passive speakers.
Remember to power ALL interconnected equipment from the same receptacle or source to avoid ground bounce faults that can destroy sensitive circuits in your equipment.
Mar 05, 2011 | Mackie 1202vlz3 12 Channel Mixer
How do you bridg the pryamid pa 1000x power amplifier
you hook up the speaker the speaker neg on Right+ and pos on Left+
Sep 05, 2010 | Pyramid PA-1000X Stereo Amplifier - 1000W...
Hi i own 2 omnitronic speakers DX 1022, each have
You're speakers are 8 Ohm, so it is no problem.
You're amplifier can handle a 4 Ohms load.
You can loop through you speakers.
regards,
Gerard
Jan 22, 2010 | Audio Players & Recorders
I have a 1000w amp but it got burned why??
I'm sorry but your problem was a little confusing. Your speakers worked fine, you hooked up a 1000W amp and now you cant hear the sound ?
Then you say "they say because the wires were connected wrong in the amp it burned" does that mean your amp burnt out ?
Please post back and sort these facts out for further assistance.
As of right now im not sure if the problem is with the speakers or the amp itself.
Oct 01, 2009 | Alpine MRD-M1005 Car Audio Amplifier
PROTECT LIGHT COMES ON WITH 2 SPEAKERS HOOKED UP
Go to this website page and see if any of this applies to your problem. http://www.caraudiobook.com/car_audio_amplifiers/car_audio_amplifiers.htm
Aug 11, 2007 | Lanzar HTG244 Car Audio Amplifier
35 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
