Question about Samsung LN-R3228W 32 in. HD-Ready LCD Television
I have a Supersonic SC- 191 TV. It worked at first, for about 3 weeks then nothing. It won't turn on. What could be the problem ?
There's a constant light greenish yellow light on in front but that's it.
Trying to install stereo in 01 impala. I need to know the stereo wiring diagram. I keep reading that the yellow is 12v constant but have no yellow wire. Any help? Factory harness was cut out -______-
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: White
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Oct 31, 2016 | Cars & Trucks
2000 villager radio wiring diagram
Constant 12V+ Green/Purple Switched 12V+ Yellow/Black Ground Black/Light Green Illumination Green Dimmer n/a Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 5" x 7" Side Panels Left Rear (+) Light Brown/White Left Rear (-) Light Brown/Yellow Right Rear (+) Light Brown/Green Right Rear (-) Brown/Pink
Jan 31, 2014 | Car Audio & Video
How do I straight wire a CD player in a 2000 mustang?
Constant 12V+Green/Yellow Switched 12V+ Yellow/Black Ground Black/Green Illumination Light Blue/Red Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 6" x 8" Rear Deck Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
May 17, 2012 | Ford Car Audio & Video
Need Wireing diagram to hook up a Wire Harness to a Kenwood BT645U to a 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
Dec 21, 2010 | Car Audio & Video
We also have a greenish tint. We put a new bulb in because the box that said bulb needed replacing came up. We reset the tv but its still green. we have tried to adjust colors, temperature adjustment and...
Your "light engine has possibly gone down on you, did you replace just the bulb it's self or the complete bulb assembly? If you pulled out light assembly and replace just the bulb then repalce light assembly, if you repalced the whole light socket assembly and still have greenish color the you have a "light engine problem". Seek repair tech.
Oct 01, 2009 | Sony KDS-55A2020 55" Television
It went this greenish yellow hue
Try resetting the monitor to defaults if possible. If you still have the greenish yellow hue then at that point, try another known working monitor on the computer, if the hue goes away then you know the original monitor is bad, if you still have the greenish yellow hue then you know the video card is bad.
Aug 19, 2009 | Kogi L7CH Monitor
I need the wiring diagram for the radio on a 1994 nissian quest gxe
Constant 12V+ Brown/White
Switched 12V+ Orange
Illumination Pink/Black
Dimmer Pink
Left Front (+) Gray/Blue
Left Front (-) Yellow/Blue
Right Front (+) Blue
Right Front (-) Yellow
Left Rear (+) Blue/White
Left Rear (-) Blue/White
Right Rear (+) Blue/Black
Right Rear (-) Red/Blue
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 13, 2009 | 1994 Nissan Quest
I need the wiring color schematic for speakers in a 2002 Kia sportage
Constant 12V+ Light Green Switched 12V+ Black/Yellow Ground Black Illumination Blue/Yellow Dimmer n/a Antenna Right Front Front Speakers 4" Doors Left Front (+) Green Left Front (-) Blue/Red Right Front (+) Light Green/Yellow Right Front (-) Black/Green Rear Speakers 6 1/2" Side Panels Left Rear (+) Green/Yellow Left Rear (-) Blue/Orange Right Rear (+) Green/White Right Rear (-) Green/Blue
Dec 25, 2008 | 2002 Kia Sportage
Greenish tint on my Hitachi x1250 Projector
the light polarizer on the blue lcd panel is fried due to excessive dust and heat. you'll have to replace the entire optical engine.
Dec 22, 2008 | Office Equipment & Supplies
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Samsung LN-R3228W 32 in. HD-Ready LCD Television Logo
19 people viewed this question
Jerry Greenberg
Jerry Greenberg
