Question about Hitachi 55HDS69 55 in. Plasma Television
Has sound but not picture
Has good sound but the picture does not display.
Why sound but no picture?
Hi Roy,
Why sound but no picture means the sound is able to make it to the speakers while picture is unable to do it to the display screen. Even if the picture has reached the display screen some times it does not show due to back light failure. Please consult some local TV Tech to handle it.
Good Luck.
Aug 07, 2015 | Televison & Video
I HAVE A SONY-KV-ES34M61TV,PICTURE GOOD,SOUND GOOD BUT LIGHT BLINKIG FIVE TIMESWHEN NOT PICTURE ON TV SCREEN FLESHING LIGHT IS STOP, PICTURE GOOD,SOUND GOOD BUT IN SELF DIAGNOSTIC SCREEN DISPLAY 005:255,IT...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 11, 2015 | Sony Televison & Video
Will not display picture. powert switch turns on. no picture displayed. no sound.
I had a ViewSonic TV and the problem is prbably the power supply it's there problem
Jan 05, 2011 | ViewSonic N3250W Television
There is no picture for my Xbox360. There is
Yes this is the display chip overheating you can fix it with a good guide or you can send it in and they will fix it for you.
If you are going to use a good guide you can see the best HERE or send it in.
Jul 30, 2010 | Microsoft Xbox 360 Console
Good picture, no sound
hello, if you have a good picture then your set is serviceble make sure you check all your options and audio set up settings before you go futher, with this symptom your set displaying fine and sound not coming trough it could be a fualty sound board module this board is identified by aquiring a service manual and then using the schematic drawings location the board that controls sound, i would then find this board online at auction or parts site and have it exchanged. hope this helps
Jun 04, 2010 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Tv has sound but no picture
the problem is from your picture IC. The picture IC of your TV is faulty and need to be changed/replaced for your TV picture to display again.
Good luck.
Mar 11, 2010 | Televison & Video
L18 will not display stored pictures when > button is pressed
Sounds like your cardholder assemlby may not be working properly. You may send it to NIkon in Melville, NY or take it to an Authorized Service Center. I know of a good one in Miami, but not sure where you are. Their number is 305-653-7355
Apr 20, 2009 | Nikon COOLPIX L18 Digital Camera
I have a sony 61HS10 rear projection tv. The small displays work, showing two or more pictures at the same time but when you want to display just one large full screen picture there is sound but no pi
As you told big picture freeze is working ,then there could the problem in the main processors which not to able pick video input signal ...If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:http://servicemanuals.vstore.ca/ which also contains the part number incase you need a new part...
Good luck.....
Dec 06, 2008 | Sony KP-53HS30 53" Rear Projection...
SD300 LCD Display Shows Same Image
Sounds like it needs service. Call Canon tech support.
May 28, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Hitachi 55HDS69 55 in. Plasma Television Logo
37 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
