Question about Technics SU-G75 Amplifier
Technics SU-G75 has no sound
I have no sound found R703 and R-705 are burned out how can I fix this? I believe they are transistors on the main board is this why there is no sound?
    Habit-Forming:
  • 91 Answers
Hello
when the resistors are burned,means that the transistors are damaged, or the power module is damaged.
and in your case its the power module.
Hope this helps.
Posted on Jan 02, 2016
5 Suggested Answers
SOURCE: Technics SU-G75
I had the same problem. The solution to me was presoldering transistor Q708. http://www.flickr.com/photos/37147023@N03/3511227679/?edited=1
Posted on May 08, 2009
petraman7
  • 1175 Answers
SOURCE: Technics su-Z750 Intergrated Amplifier stays in Standby
HI...
This happens when one or more components in the power amplifier section has failed.
The protect circuit keeps large DC voltages off the speakers.
The only thing you can check for before finding a tech is that the speakers are firmly connected at both ends. If they are ok, you need a tech
PLease rate my help if this helps
Posted on Nov 09, 2009
  • 4234 Answers
SOURCE: Technics SU-G95 Amplifier and no sound on left speakers
Usually this is a defect in the output amp IC. If you have no experience with repairs of these types of units, have it checked by a service shop. If the output AMP IChas failed, it will cost about $75 for a replacement. This unit uses an RSN3306P IC .
Dan
Posted on Mar 15, 2010
SOURCE: my technics su-g86 has no sound but has power?
It's simple I had the same problem , all u need is terminal compound. Here is what u do , open ur receiver inside u see huge heatsink and RSN3305 AUDIO MODULES H are on the heatsink rite , so u do this umscrew them off the heatsink and rest of stuff that is connecter to the heatshink , then when everything unscrewed from heatsink , then u umscrew heatsink its self from the unit , pull the heatsink out and put terminal compoud on it put nice amount and make is nice and smooth its urfinger do that in spot the audio modules were located , then u look and the back of the audio modules and apply terminal compound to the back of them also and also smooth it out with ur finger , make sure its all covered up and smoothly , make sure u didn't leave not even a tiny peace not covered , and after that put it all toghwter , the reason it happens after many years of use the compound that was put there by technics at factory probobly dried out by now and audio modules starting to overheat due to lack of compoud comecctiong to the heatsinck , after that process it will work as new , till terminal compound dries up ... It's simple fix and it will work just as it did out of the store
Posted on May 12, 2012
Technics SU-G75 owners manual download
http://www.manualslib.com/manual/926367/Technics-Su-G75.html?page=2#manual Technics SU G75 Service Manual Page 2
Sep 23, 2015 | Technics SU-G75 Amplifier
Want to download Technics SU-G75 service manual
Technics will not give it to you. Gotta pay the piper!
Did you try to google it - might get lucky - but don't hold your breath.
Sep 21, 2015 | Technics SU-G75 Amplifier
Technics su-g75 drawing/schematic? when hit power button fuse in power supply blowout.
Fuses blow when there's an overload. This is most likely caused by a semiconductor device(s) shorted. In amps this is often cuased by speaker wires that have touched while on power. The main culprits are the devices on the heat sink. If they are transistors then connecting an Ohm Meter accros the terminals of the transistor(s) (amp switched off) will show as if you have touched the test probes together! More than one device might have blown!!
Dec 23, 2014 | Technics Audio Players & Recorders
How do I fix my integrated amplifier Su g75 it
It sounds to me like you blew the output transistor(s). Best take it to a service shop.
Oct 01, 2014 | Audio Players & Recorders
Ok I have a technics integrated receiver su-g75 it
The amplifier power transistors could be bad, the speakers can be muted or a fuse for the speakers could have opened.
Aug 28, 2014 | Audio Players & Recorders
Technics su-g75 amp goes to loud static after a few minutes
Hi Aawpharmd,
system control error.
please go for repair shop.
regards,
nuwan
Jan 13, 2014 | Technics SU-G75 Amplifier
No sound from stereo
Greetings
the power module is damaged and the components ... as you described, resistors burned and other components are over heated .
you need a service technician if you are still hanging on your baby :)
unless you are a technician .i will be glad to send you send you schematic.
i cannot post it as(PDF).
Dec 29, 2013 | Technics SU-G75 Amplifier
Technics SU-G75 overload
I have the same problem..it will be required to remove the board and resolder "cold " solderings... None of above solutions have been helpful, but "you get what you paid for"..and I completely disagree...even if required, remove ALL audio power managing circuitry and replace this expensive original design with TI´s Integrated chips..using PWM technology..unless you want to go back to L6, ot Kts tubes..
Nov 07, 2012 | Technics SU-G75 Amplifier
Speakers for Technics SU X933?
check given link for speakers
http://www.fixya.com/myhome.aspx#Answers
Jun 05, 2012 | Technics SU-G75 Amplifier
Technics SU-G75 Amplifier Logo
131 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
