Question about Teleflex 1979-Present Omc Engines Omc 479 Control Cable 30' 1979 ->
19779 ford 302 will not start
Truck will not start. We have replaced brain box, coil, and magnetic pickup. It will turn over but wont start but as soon as you let off the key the truck will attempt to start what could be the cause?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Teleflex Master
  • 1,190 Answers
Check the ignition switch , try turn to on position then jump a live to starter solinoid and see if it starts !
Posted on May 29, 2014
Toyota pickup 94 model cant get spark plugs 2 fire replaced pickup coil igniter rotor buton wires cap coil fires plugs wont
I had to replace the magnetic pick-up sensor on the side of the distributor that tells the coil when to fire on my 86 truck. It was $80 and slips onto the distributor held on by the cap.
Mar 29, 2013 | 1994 Toyota Pickup
Will turn over without fire, replaced brain and the ignition coil
bet on the module,if it's tfi it's on the side of the dist.85 could be either way,may be the older fender mounted module.
If it's dist. mounted Ford recomends replacing the pick up coil also. There is a wire with a plug on the tfi's ,you remove the "cap" to set the timing,just 2 wires with a gray cap on the end.Maybe that's the wire you mentioned.
Jun 08, 2012 | 1985 Ford F150
Got a 85 toyota pickup..will not start..replaced coil, brain box, and all fuses...still no fire from the coil?
Not sue what you mean by brain box. You may need to replace the ICM the Ignition Control Module that sits right below the coil. Mine cost almost $300 locally, but found them online for less then $100. When mine went out in my 1985 Toyota pickup I was doing about 45 MPH and it was just like someone turn the key off., dead, no spark nothing. I ran the troublesooting steps in my repair manual and found it was dead.
Sep 09, 2011 | 1985 Toyota Pickup
Will turn over wont start getting plenty of gas new built 302 motor ran fine for last 6 months yesterday it died at a stop sign still wont crank had to tow it to the house
If I am reading this correctly, the engine cranks but does not start. It was running, died and will not start. I would be inclined to think it is a pickup coil in the disturbutor or the ingition control module. These are very common parts to fail in older ford products.
Feb 28, 2011 | Ford F-100 Cars & Trucks
'87 ford van w/302 just died,no spark,replaced ign.mod. &ign.coil.still no spark.
mark the distributor and pull it out, turn the key on.with module wires connected, ground the dist. body and spin the gear, with the cap off, you should hear a light spark or tick in the distribtor, if not the pickup in the dist. is bad. a rebuilt distributor is probably cheaper than the pickup alone.
Dec 04, 2009 | 1987 Ford F 150
No fire to distributor module, coi, pickup coil and coil o.k. tfi module good
Maybe a broken wire going to the distributor, Check that first. Check fuse also ( Engine fuse ). Check distribution box ( brain box ).
Nov 10, 2009 | 1984 Ford Bronco II
1984 F150 302 motor no sparck to the plugs. i replaced the following with new parts ( the brain-the distribtor-the coil-the ignition switch )what else is there that could cause no spark to the plugs has...
take the distributor cap off, and have somebody crank the engine while you watch the rotor, if the rotor isn't turning, then the distributor shaft is broken
Also, if you have not done so, replace distributor cap
Nov 05, 2009 | Ford F-150 Cars & Trucks
Teleflex 1979-Present Omc Engines Omc 479 Control Cable 30' 1979 -> Logo
67 people viewed this question
Top Teleflex Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Teleflex Boating Expert? Answer questions, earn points and help others
