Question about LifeCast Spas LifeCast Vista Hot Tub Spa - PS5901
Turn Htr Off?
I'm looking at getting a Vista. I live in CA and want to turn the heater off but keep the pump circulating and ozonating for a few hours a day. Will the controls let me do this?
All the parts are working 100%,but jacuzzi trips the earth leakage after 2 hours
If your GFCI is tripping, it could be due to a bad heater element, pump, blower or ozonator. To determine which component is causing the problem, unplug the components one at a time and turn the breaker on. If the breaker does not trip after unplugging the pump, ozonator or blow, you've found the problem and you can now replace that component. If you've unplugged all three components and the breaker still trips, it's likely the heater element. Hiring a technician or replacing the heater is the next best course of action.
Apr 06, 2016 | Jacuzzi Water Heaters
What is the air pump in the zodiac clearwater ozonator
This ozonator is no longer manufactured. It was made for larger spas with a volume of 1,000-1,500 litres. As the Zodiac Spa Ozonator, when it was manufactured, had its own internal AIR pump to add ozone to the spa independently of the other equipment - 24/7. Ozone is an extremely powerful oxidizer and as an added benefit, ozone also kills viruses. When a unit has an auxiliary air pump, it can always add ozone, even if circulation equipment is off!
Mar 16, 2015 | Zodiac Pool & Spa
Hydropool hot tub
. sounds like the heater might be shorted.. also check the motor amp's when motor is running
Oct 01, 2013 | Pool & Spa
Indoor swimming pool has bad smell only when running spa pump or ozone pump with lots of foaming
Hi.. I tell my customer to boil a glass jar and lid, like your canning. and use this jar to take the sample of water out of your pool - spa to have tested, take it to several places to have it tested.
and ozone pumps are not good to run inside in a open environment, I think the produce positive ions. but kill bacteria and odors, so if this is a SPA run the pump and ozone generator for a few days with the correct amount of anti foam and cover on it should clear right up. to avoid this problem pool and spas must have the pump on a timer or set to circulate !
if your not going to use your portable spa for say a season you must drain it !!! and drain the pumps. this will ensure that you get many many happy years of service out of your pumps and spa.
Hi; I'm Jay the pool pump motor repair guy in sunny longwood Florida. were the pool is always open, so jump in and get wet the waters just fine.
REMEMBER GREEN POOLS ARE DANGEROUS. children can fall in and not be seen costing valuable rescue time !!!
a clean pool is a safer pool "pool pump repair puppy"
Dec 29, 2012 | Pool & Spa
I have a Lang Autocirc with timer for 11 years. The past few months water not getting hot I timed how long hot water takes in faucet before \unit by 6' and faucet just after unit and times the same over 2...
Autocirc can be uninstalled and the pipe cleaned out with CLR (calcium lime and rust), otherwise there are no repair parts.
Once the motor begins to slow, it overheats and burns out.
11 years is a good run, so you must have good water or are careful about your water softener.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Using the timer and running Autocirc 1 hour a day costs between $11 and $17 per year to operate.
2 hours a day is $22-34 per year.
This includes pump operation and additional time that water heater operates.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circulation system or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 18, 2011 | Laing Thermotech Autocirc Undersink...
I have a cal spa ps-4-b no manual, it came with a house. I filled it up and turned on the breaker. The pumps started working but the heater light just kept flickering on and off and then just stayed off....
One of three things here.
1.the circulation pump is clogged or failing. (solution: replace or clean out)
2. the filter is old and not letting the circulation pump flow freely (solution: replace filter. to see if this is the problem. Clear the spa of debris. Turn off power. remove filter element. turn on power. see if problem persists. if this fixes it, replace the filter)
3. the heating element is bad. Typically when this happens it blows the breaker, but not always.
You can test this if you turn off power. disconnect the heater and test the heating element for resistance ratings. if you do not know how, this is something a service tech should do.
Nov 15, 2010 | Pool & Spa
My hot tub control panel keeps showing OH and the temp of the water is 99 degrees any sugestions?
It sounds like your circulation pump is not keeping up with the heater. Check for debris in the pump impeller. If this is 24 hour circulation pump, it is probably failing. New units are about $200 US
Aug 14, 2010 | Qca Spas Paradise Hot Tub
How do you get the pump to circulate less. It seems like its running all the time to keep the temp up? I have a ozone system also could that be affecting it?
Your pump should be two speed if it is wired right there will be an overide in the way of a timer switch and or a therapy button ether one of these will keep the pump running at full speed the low speed should only run off the thermostat otherwise the water runs to fast to be heated properly. And no your ozone should have no effect on this. So check your timer and your therapy spa side.
Aug 15, 2009 | Waterway Spa Pump & Hot Tub Pump 1.5"...
How does heater work to keep freeze off pool in winter
What state do you live in, what is the brand name and model number of the heater. If you live in a state that gets cold during the winter, call you local pool store and schedule a closing. If the pump is running and water is not circulating, most likely the pump lost prime or your filter needs to be backwashed, or there is some debris in the impeller.
Nov 25, 2008 | Hayward H Series Pool & Spa Heater 400k...
Living Air XL 15, no ozone
My XL-15 had the same problem a few years ago. I had a broken wire on the fan, and the Ozone problem turned out to be a problem with the power supply. I had to send it in to have it repaired.
Mar 18, 2008 | Ecoquest Living Air Classic Air Purifier
LifeCast Spas LifeCast Vista Hot Tub Spa - PS5901 Logo
46 people viewed this question
Top LifeCast Spas Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a LifeCast Spas Pool and Spa Expert? Answer questions, earn points and help others
