Question about Car Audio & Video
Alpine xqe 105560 cd changer cables
Is there an adapter for this CD changer to connect to the radio in a ford focus?
SOURCE: ford edge 6 disk cd changer cd error will not
According to the tow truck that just came to pick up my Edge, the cd player killed the battery. He jumped it, turned the radio on and said to let the car run for at least 20 minutes. He says that if you leave the radio ON when you turn the car OFF, it should correct itself. Good luck.
Posted on Jan 08, 2010
  • 1015 Answers
SOURCE: I have my cd changer (alpine) plugged into the
One thing to verify is that the Ai-Net switch at the bottom of the radio is set to Norm and not the EQ position. And also gray Ai-Net connectors are for audio input and the black Ai-Net connectors are for audio output. It sounds like you have everything connected correctly and at least the Sirius is coming up. And I assume that the CD changer works when connected directly to the reciever so you know that it is working. I would suspect that there might be a problem with the Sirius reciever not allowing the communication signal to connect to the Alpine deck and in that case you would need to get a new reciever. You could check the Alpine radio settings and see if there is something that needs to be changed in order to allow the CD changer to work. If you disconnected the battery connection to the radio then it might have reset the settings to factory default. Otherwise it sounds to me like the problem is with the Sirius reciever.
Posted on Jan 09, 2010
  • 306 Answers
SOURCE: jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Posted on Feb 06, 2010
dj_relly999
  • 4070 Answers
SOURCE: cd changer magazine does not eject
good day, you may want to do it manually if its jammed, you may find a pinhole on it and u can use a paperclip, insert it in the hole and it will open. hopefully it wont jam again. hope this helps, have a nice day
Posted on Feb 10, 2010
Geekman
  • 32281 Answers
SOURCE: need a radio code for 2003 1.8 tdci ford focus
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Ford service centre and get them to enter this code for you.
Posted on Sep 09, 2012
How do i install my alpine cd changer to a kenwood mp528 unit
It is unclear which Alpine CD changer you have and what output connections are available from it.
However your Kenwood unit has Aux input terminals at the back. With appropriate cable connectors you should be able to hook the two up. In the Kenwood you will have to select AUX in menu when playing CD changer. Download user manual for Kenwood from this site.
http://www.kenwoodusa.com/Support/Car_Entertainment/
Search using full model number KDC-MP528
Sep 04, 2014 | Kenwood Car Audio & Video
Alpine CHM-S620 6 Disc CD Changer Components
sounds like the changer was plugged into the antenna jack of the radio. this means that you can run it through any radio simply by sending a signal to a preset station on the radio and listening to it through tuner. the control unit ran the changer itself. you may be able to obtain replacement cables from pacparts.com
Apr 01, 2010 | Alpine CHM-S630 6-Disc CD Changer
I have my cd changer (alpine) plugged into the input port via ai net cable and I have the output going to the alpine radio (cda 9886) via ai net cable. When I hit the source button everything comes up but...
Jan 09, 2010 | Sirius Satellite Radio Sirius SIR-ALP1...
Can a CHM-S601 hook up to a 1997 ford F-150?
It won't work if the radio doesn't have a cd changer input. The radio/receiver has to have been designed/programmed to interface with the changer since that is what the changer is controlled through.
Jan 08, 2010 | Alpine CHM-S630 6-Disc CD Changer
Can you please tell me if and where I can get an adapter to join a pioneer cdx m50 multi changer to the lead in the boot of a jagaur xj 40
This vehicle is already pre-wired for an Alpine M-BUS CD Changer, if you look in the boot under the parcel shelf you should see a Alpine cd cable tucked behind the carpet. The Alpine unit will plug in and play without any adaptors. You will not be able to get the Pioneer to work unless you replace the radio system.
Nov 25, 2009 | Cell Phones
How do i plug a alpine cd disk changer in to a poineer deck
honestly you most likely can not unless you purchase the fm modualator allowing you to hook it threw your antena and you wont be able to control it threw you deck (head unit)
Sep 26, 2009 | Pioneer AVIC-D1 In-Dash Mobile Navigation...
How can i plug my mp3 player into my alpine cde-7853?
Get a cd/aux adapter from an alpine dealer, this will change your cd changer input on the back of the radio to a RCA input, then get yourself a Y adapter, and head phone adapter, and you are set..
Aug 22, 2009 | Alpine CDE-7853
Can someone give us a clue to what i am doing wrong
that is a cd changer you put your cds in there but you control it of your radio unit there should be a button that should activate the cd changer. it doesnt come pre wired so you might have it wired before you can use it.
Jul 27, 2009 | Car Audio & Video
On my Alpine CDA 7892 i have the aux cables right for my iPod but i don't know how to swith it to the "aux" , just CD or Radio, How do you switch it to the "aux" imput in the back
I believe you need the Alpine KCA-410C - Ai-Net multi-changer/versatile link adapter before you can input from an external source directly.
Mar 28, 2009 | Alpine CDA-7892 CD Player
Peripheral's Connex2Car adapter to an Alpine CDA-9851
the alpine should recognize it as a "changer" when you select the source; ie: radio, CD, changer. Sounds simple, but have you turned up the volume on the iPod?
The Alpine adapter is $100, but works great, you can totally control all your iPods functions, and it displays all song info on the Alpine decks display.
Dec 30, 2007 | Alpine CDA-9851 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
