Question about Electronics - Others
I need inverter parameters for holzher 1436 se pvc primus .thanks
Parameters for inverter of triming and miling motors ''frequenz-umrichter tip Dv-600-2200''is no firm on it
2 Suggested Answers
AndrexT
  • 15222 Answers
SOURCE: Can I exchange parts on HOLZ HER edge banders? 1st edge bander is a HOLZ HER 1436 S and the 2nd is HOLZ HER Primus 1436 SE PVC.
This doesn't sound like a
Question about Coffee Makers & Espresso Machines
I have recategorized to woodworking
Better to ask the makers
http://www.holzher-nullfuge.de/en/meta-navi/contact/
Posted on Aug 19, 2015
Testimonial: "Yes, I noticed after I was done.. Thank for the help!"
What does OL2 fault in KEB drive indicate?
Too much current is being required with the motor shaft not rotating. This is most likely a parameter adjustment issue with the motor data, torque limits and protective functions.
Possible motor issue as well.
Sep 29, 2015 | Inverter KEB COMBIVERT F5
Aug 19, 2015 | Crafts & Hobbies
Sir i have keb f5 inverter i need default parameter i am trying to external run but i do not have parameter.
There are over 1500 parameters in the inverter. These have been setup by the manufacture of the machine so that the machine functions the way it was intended to in a safe trouble free manner.
Before one defaults the inverter you should always use the COMBIVIS software to obtain a complete upload of all the parameter values. This way you can always get back to the settings before the inverter was set to default.
Also with the COMBIVIS software you can access all the parameters in the inverter. With the software the Fr parameters are where you would find how to reset the inverter to default values.
Dec 11, 2013 | Inverter KEB COMBIVERT F5
Hi, We have KEB F5 inverter on our machine model
If you are connected to the inverter with COMBIVIS, go to parameter FR.01 and enter a value of -4. This will set all parameters back to factory default.
You may be having an issue with the inverters software verison. As long as the inverters are the same part number, you should be able to download the parameters without any issue. There may be some unknown parameters but you should be able to hit ignore and keep on downloading.
Oct 26, 2013 | Inverter KEB COMBIVERT F5
I use KEB 18.F5.CBG340A (22,0 kW) "Compact"inverter , to run this inverter whose parameter must be set from cp mode and application mode
The CP mode parameters are a small list of parameters that are mapped from the application parameters. Not knowing what you are trying to do with the inverter, it is very difficult to tell you what needs to be programmed.
90% of the machines that us the KEB inverters use the application parameters to gain the full functionality of the inverter.
The machine manufacture whom built the machine that the inverter is installed in should be able to provide you with parameter settings.
There are instruction manuals on the KEB site.
www.keb.de
www.kebamerica.com
Sep 04, 2013 | Inverter KEB COMBIVERT F5
I fit a new keb f5 inverter which parameter set to run motor
Pretty general question. If it is a replacement inverter, best source would be to upload parameter values from original inverter with the COMBIVIS software.
Otherwise I would suggest downloading the manual from the KEB web site.
Aug 24, 2013 | Inverter KEB COMBIVERT F5
Inverter KEB COMBIVERT F5 parameter
The manual that came with the inverter has instructions on how to go from mode to mode.
If you do not have the manual, these can be downloaded from the KEB web site.
Jul 21, 2013 | Inverter KEB COMBIVERT F5
LOOKING FOR A MANUAL FOR HOLZHER 1205 APNEL SAW
basically the 1205 is a Grggio sc3200 with Holzhers own slider on it. Can source the manuals either frm holzher or griggio.
Oct 19, 2010 | Amana TOOL DT220T641 220MM X 64 TEETH...
81 Suzuki GS650L Engine Ticking/Tapping
i had same problem,..i changed the oil and it went away,..i find in the non oil cooled motors you need to change oil every 300-500 miles depending on how hard you drive.
Apr 17, 2010 | 1981 Suzuki GS 750 L
Electronics - Others Logo
77 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
