Question about LG WM0742HWA Front Load Washer
Error code ue - LG WM0742HWA Front Load Washer
3 Suggested Answers
  • 1294 Answers
SOURCE: ue error code on the display
For "ue" an unbalanced load is sensed three times, re-adjust your load in the machine.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
Posted on Nov 25, 2007
  • 343 Answers
SOURCE: WM1814CW Front Load Washer: UE error code on display...
UE is Imbalance error..Redistribute the load or you may have tried to wash something which will not 'spread' enough to balance the load...Nomess
Posted on May 18, 2010
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
Tip
LG Washing Machine UE Error Code Solutions
An UE Error Code is indicative of a "Unbalanced Error". This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. gcs_la.jpg
on Jun 02, 2011 | Washing Machines
UE Error Code
The UE error code (Unbalanced Error) displays when you wash items that cause the machine to shake badly during the spin cycle, if possible wash and drain the items only, then open the door and stack the items evenly on both sides of the drum in order to balance it, now select the spin cycle.
Dec 26, 2013 | LG WM1812C Front Load Washer
My 7kg LG front loader WD-80134T showed a UE error. Please can you tell me what this means and where can I get the manuel?
This is an imbalance error code. Too small of a load will cause this error code.
-Check and rebalance the load
-Make sure Washing Machine is level
-Redistribute the load evenly
May 15, 2012 | Washing Machines
I am getting alert of UE for fully automaticatic washing manchine
According to Lg Ue error code is an unbalanced load error code or uneven load error code you can also click this link from the LG site which describes some ways to alleviate the problem of the UE error code http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=800. I have also found that if these ways do not remove the problem you may have to open the unit and check the damper struts that attach to the tub assembly. If one of these struts were not to be attached or have broken, or came away from the tub assembly this would also cause the UE error code as well with the unit. Also if you remove the rear panel you will see the stator which is basicly the motor as well as an rps sensor which helps the stator to rotate. I also have found that in some cases the center bolt that holds the stator in place sometimes unloosens and unscrews as well also causing this UE error code. So you would first try the methods that LG has listed in order to alleviate the UE error code and if there methods did not work then you would first look at the stator center screw to assure that it is tightened and in place. And secondly if the stator screw were in proper place and tight then you would look at the damper struts in the unit lastly. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks
Rick
Jul 04, 2011 | LG WM-2277HW Front Load Washer
Error code "UE" clothes have
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa !!
Dec 12, 2010 | Washing Machines
May 16, 2010 | LG WM1814CW Front Load Washer
Code error ue lg washing machine
ue is (imbalanced error) cause. the load is to small,washer is tilted, laundry is gathered to one side, non distributed things are put into the washer
Jun 20, 2008 | LG WM-2077C Front Load Washer
LG WM 14316FD washing machine
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. I found this answer on the lg web site.
Dec 01, 2007 | LG Washing Machines
Ue error code on the display
Sep 23, 2007 | LG WM1814CW Front Load Washer
LG WM0742HWA Front Load Washer Logo
14 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
