Question about YouTube Videos
Mincrraft wrecking ball - YouTube Videos
2000 Chevy venture wobbles and makes noise on passenger side with increased speed it starts shimmering real bad,just replaced the CV axle
Lift that tire off the ground. Grab it on the top and bottom. If it moves, have some on watch the lower ball joint. If the ball joint moves, replace it. If it doesn't replace the wheel bearing. If the tire doesn't move top and bottom. Grab the sides and move back and forth. If you feel slop in it, replace the outer tierod. Do this soon, because a lot of vibration could be close to failing/wreck.
Feb 06, 2015 | 2000 Chevrolet Venture
Torque steering or pulling under acceleration
The vehicle could have been repaired after a wreck and the front end is skewed.
Oct 20, 2014 | Cars & Trucks
Low drone or humming noise from front tires @ 40mph and up. Tires have about 6000 miles on them....needs alignment. ..will that fix or is it something else?
Without more information its hard to say. How many miles on the vehicle, what vehicle, and why do you say it needs alignment? Was it in a wreck? Is it both tires or just one? Is it a front-wheel drive?
That sound can be from a variety of causes, but if the vehicle has over 150K miles on it, it could be bad lower ball joints. Could also be the CV joints if the car is old enough. Could be a pattern worn in the tires from all both ball joints and alignment being off for some time.
You have to give us more information.
May 27, 2014 | Cars & Trucks
Need to find out how a kingston 71597 goes back together
If you physically opened a hard drive exposing the platters. Then the hard drive is destroyed beyond repair.
A simple speck of dust landing on a hard drive platter is the equivilant of a wrecking ball being dropped on a toy car. Which is why they are sealed.
Nov 26, 2013 | Computers & Internet
Need to syphon gas out of gas tank ofa dodge Dakota
Take filer line off tank and try to acsess tank will mite have chek ball in line
Dec 10, 2012 | Cars & Trucks
When im driving my front end gets to shaking so bad i have to pull off the road, it use to quit when i mash the brake but not any more. Its a suzuki samurai 4-wheel drive
The ball joints need replacing and maybe the tierod ends too. That violent shaking can cause part failure which could cause you wreck the vehicle. Don't drive it usless it is inspected and repaired.
Mar 19, 2010 | 1988 Suzuki Samurai
I have no instructions fpr batman for ds, how do i beat the first level
Make the crane/Wrecking ball,Knock down the sign, it makes a car. Mind control the guy to open the door. Then After you make the crane/wrecking ball car, use that to go through the 2 shiny gates to the right. After the 2nd gate, you'll see silver objects on the wall. Use the crane and destroy them which will reveal a opening you go through.
Oct 28, 2009 | Warner Bros. Interactive Lego Batman for...
The whole front end of the van needs to be
you want to spent 5000 on a 100 dollar van?
Aug 18, 2009 | 1998 Plymouth Grand Voyager
YouTube Videos Logo
13 people viewed this question
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
Mike
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
