Question about Kocaso M752 Dual Camera Android 4.0 ICS 512MB RAM WIFI 1.2Ghz 4GB
We need to replace plug - Kocaso M752 Dual Camera Android 4.0 ICS 512MB RAM WIFI 1.2Ghz 4GB
My rca 2 in 1W1013 DK tablet will not charge or turn on
will it turn on if you plug it into the mains?
if it does then it sound like the battery needs replacing.
so let me know if it does stay on when you keep it plugged in.
Nov 28, 2016 | Tablets & eReaders
My rca cambio w101 v2 won't charge. have to use it plugged in
then I would suspect the internal batteries have failed and need replaced .
Jul 21, 2016 | Tablets & eReaders
My tablet wont charge.when i plug it in the orange light will come on but it wont charge.
This is a fatal problem. Your device needs to be replaced. ;( call up customer service. Then, when your tablet gets repaired/replaced, Get a strong case and NEVER LET THAT 2 YEAR OLD TOUCH THAT TABLET AGAIN! Hope I helped!
~Conner
Nov 28, 2015 | Vivitar XO-780 7in XO Childrens 8GB Tablet
Do I need to replace a battery or adaptor for tar us tablet that won't charge unless I move cord plug until .
if you have to "wiggle " the end of the charger where it enters the tablet then its the charging port on the tablet itself that needs re soldering or changed. check the charger by plugging it into some thing else with the same end on ( phone etc ) to make sure its not the charger end. if it works fine then you need to change the port on the table.
May 24, 2015 | Tablets & eReaders
I need the charging peg replaced ,broke off or bent,can this be done?
If you mean the center pin of the barrel plug, no you must replace the entire plug, which requires removal of the main board. Not easy for a DIY, but it can be done.
Feb 19, 2015 | PANDIGITAL Tablets & eReaders
My trio stealth 9 only runs when it is plugged into the outlet. It says it if fully charged, yet when I unplug it, it goes black
Your battery is dead and needs to be replaced. Recharging batteries only live for so long as well.
Jan 17, 2015 | Tablets & eReaders
My charger for my tablet is not chargin it has to be bend in to charge
You either need to replace the carger or the bit that you plug the charger into.
Sep 11, 2014 | Tablets & eReaders
Plug doesn't work to charge
Sounds like you have found the problem already ... you may need to replace the charger.
Dec 01, 2013 | PANDIGITAL Tablets & eReaders
Netbook turns off instantly when power cord plugged in - even when not plugged into power outlet!
Have you tried a different adaptor or power outlet other than that the dc jack on the notepad may need replaced
May 08, 2013 | Gigabyte Atom Series Netbook: Q2005 -...
I lost the download plug
Search it on its website, or contact supplier for help. I think you can get one from supplier.LOL
Android 4.0 Tablet PC
Jan 10, 2012 | Sharper Image Literati Reader 16375680042...
Kocaso M752 Dual Camera Android 4.0 ICS 512MB RAM WIFI 1.2Ghz 4GB Logo
Top Kocaso Tablets & eReaders Experts
CrisO
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
