Question about Kocaso 7" Capacitive Touchscreen Tablet Android 4.0
We need a plug
How do we get a plug for our tablet
  • Kocaso Master
  • 2,219 Answers
The charging on the tablet depends on the model.
Most including the Kocaso 776 charge via the micro USB port, and this is a standard USB port.
So all you do is purchase a micro USB to standard USB cable and plug it into the standard USB port on the charger or a PC.
Posted on Mar 15, 2015
Do I need to replace a battery or adaptor for tar us tablet that won't charge unless I move cord plug until .
if you have to "wiggle " the end of the charger where it enters the tablet then its the charging port on the tablet itself that needs re soldering or changed. check the charger by plugging it into some thing else with the same end on ( phone etc ) to make sure its not the charger end. if it works fine then you need to change the port on the table.
May 24, 2015 | Tablets & eReaders
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
My tablet and keyboard to not function together. What do I need to do to resolve the situation?
Make sure the keyboard is plugged all the way into the tablet. Since you didn't say what kind of tablet/ keyboard combo it is (wireless, wired, bluetooth) I'll just assume it's the kind you plug in. So do that, then power down the tablet and restart it, all with the keyboard FULLY plugged in. You prolly just don't have it plugged in all the way. Pretty common problem for people who have no idea what they are doing.
Oct 31, 2014 | Tablets & eReaders
Where the charger plugs into the tablet has become dislodged.
Need to open the casing and re-solder the power plug. Hopefully, no pcb traces are broken but it can be repaired with a little patience. If unit is out of warranty, go to the local cell phone repair shop, they can easily do this for you.
Sep 22, 2014 | Ematic 4.3" FunTab Mini Android 4.0...
My charger for my tablet is not chargin it has to be bend in to charge
You either need to replace the carger or the bit that you plug the charger into.
Sep 11, 2014 | Tablets & eReaders
I need some drivers for i craig tablet usb cord driver
If you plan is to do Android Programming, you just need to download adb, or a rooting kit like RootThat. If you plan to just transfer files to it, BEFORE plugging in the USB connector, go to SETTINGS, scroll down to USB, and turn off "HOST MODE".
Now plug in; the tablet & the computer should recognize each other.
Mar 14, 2014 | Craig CMP741d Tablet
POLAROID TABLET PMID709 WILL NOT CHARGE
How old is tablet , maybe new battery is needed ???? Is there power at the wall plug your using ???? Sometimes it's as easy as the plug , !!M the charger your using May be bad , do you know how to use a voltage meter to test if there s power coming from it to your tablet ?? More info is needed on this ??
Dec 01, 2013 | Polaroid Tablets & eReaders
Kocaso 7" Capacitive Touchscreen Tablet Android 4.0 Logo
54 people viewed this question
Top Kocaso Tablets & eReaders Experts
CrisO
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
