Question about Euro-Pro TO289 1200 Watts Toaster Oven with Convection Cooking
ModelT0284 Timer dial won't return to start it goes over to Stay on
Black & Decker Toaster Oven CTO650 ... Numbers around dials has worn off. Where can I get a replacement panel?
Search Results
    Black & Decker CTO650 1500 Watts Toaster Oven - Read ...
    www.epinion.com/.../Black_Decker_CTO650_Toaster_Oven.../3529132...
    Black & Decker CTO650 1500 Watts Toaster Oven No complaints Is it really ... Cons:Numbers wear off around dials after years of wiping. ... It has a see-through glass door, 30 minute timer, variable temp up to 450 degrees F and signal bell.
    Black & Decker CTO650 1500 Watts Toaster Oven No complaints i should'a bought this one Is it ... Cons: Numbers wear off around dials after years of wiping. .... It hasa 4-slice or 9 pizza capacity and touch button controls with LCD display.
Jan 28, 2016 | Toaster Ovens
The oven does not heat up when I turn it on. what is wrong with it?
could be one of several things or several ,timer , switch ,element, fuse and on and on
Mar 17, 2015 | Toaster Ovens
Power light out and doesn't heat
Ticking sound when unplugged? It sounds like a mechanical timer. Check the timer / control setting is actually on a cooking cycle. The unit may be set on delayed start? If there is no power to the unit, there may be a fuse inside it. You may have to take the back / side off to see.
Nov 08, 2013 | Hamilton Beach 31199xr Countertop...
I recently bought a Euro-Pro convection toaster oven and the timer switch has already broken. How do I get another one?
Call 800.798.7398. After polylingual promts, Select promts for "how to repair/replace your product", "Ninja or other kitchen appliances." Katie sd will send 3 knobsin the mail free of charge within 7-10 business days.
Jun 13, 2012 | Euro-Pro Toaster Ovens
I have a farberware convention turbo-oven model 460 serial number 2336445 I can only read the first two temperatures on the dial [150*- 250*] I am guessing that 350*- 450* is that correct ? , is that...
The top temperature is actually 475 (which is 550 in a regular oven). That's with the dial turned as far as it goes to the left. Don't know how you'll figure out the settings for the temperatures above 350, unless you measure the intervals below 350 and mark them off on the other side some way.
Here's a picture of the dial on my oven:
Oct 08, 2010 | Farberware T490C 1500 Watts Toaster Oven...
Kitchenaid kco1005 toaster oven broken timer dial/knob
My kitchen aid toaster oven when set on baking the light is not coming on.
Aug 20, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
Jun 13, 2009 | Black & Decker CTO650 1500 Watts Toaster...
Oven just stopped working
1-usually it easy proplem
2- check your electricity voltage by testsrowdriver or another good device like radiocasset or voltmeter if you can
May 31, 2009 | DeLonghi XR450 Retro Toaster Oven with...
Delonghi Toaster Oven Color Select Dial does not turn off
This sounds like a defective timer switch that is not turning the oven off at the end of the time selected. You will need to replace the timer switch. The switches are available but unless you're able to do this kind of work you will need to take it to a repair shop. If you want to DIY you can find the switch at www.thegourmetdepotco.com or www.applianceparts.com. If you don't have a part # you will need the make and model # to get the correct switch.
Jun 19, 2008 | DeLonghi EO1258 - Stainless Steel Toaster...
Euro-Pro TO289 1200 Watts Toaster Oven with Convection Cooking Logo
Top Euro-Pro Toaster Ovens Experts
eyecam
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Euro-Pro Toaster Oven Expert? Answer questions, earn points and help others
