Question about Bosch Saws
Where is carbon brush in bosch gst 100 bce
My jig saw won't tuRn on checked fuse so I am hoping it is the carbon brush but must locate it any suggestion
3 Suggested Answers
comax
  • 154 Answers
SOURCE: what is the process
There is a lever on the handle, you have to pull it up and rotate it counter clockwise about 3 times (shouldn't take any more than that. The blade will be loose now,put in the new blade and turn the back lever clockwise until it clicks. The blade should be tight,push the lever down and move it into the slot in the handle.
I hope this helps
Posted on Apr 14, 2009
SOURCE: Instruction manual for Bosch Jig Saw 1587AVS
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00061v-1.pdf
This is the Owner's Manual for the Bosch 1587AVS Jigsaw.
Posted on Jun 24, 2009
How change blade on bosch gst 60 pb
the holder is a twist lock just turn it counter clockwise and pull blade out .
Feb 14, 2016 | Bosch Saws
GST 2000. How do I replace brushes?
Bosch Power Tools
fill in gst2000 in the white menu and look for what you need
Nov 10, 2015 | Bosch Saws
Won't start
Symptom of poor contacts..
It could be the carbon brushes that you need to change?
Check the carbon brushes.
Use a wooden pallet to hit around the motor area and on the machine see if it can start.
Apr 19, 2014 | Hitachi Gst Hitachi C9u2/J7 Circular Saw...
Bosch 2604320913 Carbon-Brush Set
No If the saw is running the brushes must be working. Maybe the front end grease has dried causing too great of load on the motor. if not the motor must be defective (lost a winding in the feild) don't know how much you paid but unless its worth is greater than $150 I sugest buying another
Sep 18, 2012 | Bosch 2604320913 Carbon-Brush Set
Manual for Bosch GST 85PE Jigsaw
You betcha, got it right here:
http://mdm.boschwebservices.com/MDMCache/English%20[US]//t10/0000000/r00058v-1.pdf
Thanks for using FixYa.com
Farmerbear
Sep 08, 2010 | Bosch 1581AVSK Top Handle Jig Saw Kit
This was my second bosch jig but this one died right away some years back. i needed a jig immediately and bought a dewalt. this basically brand new tool has been collecting dust ever since. Simply put, it...
Check the brushes inside the saw. Unplug first ! . some brushes these days have a spring lug which pushes out when the brush is worn down to prevent damage to the comm of the motor. If these are ok and the comm is not burnt check the cable with a multi meter as the cables are known to break on power tools especially in the cable grip inside the saw and in the plug. Failing that it could be the switch. Again check with multi meter and make the switch to see if it makes contact through it. Good luck.
Aug 09, 2010 | Bosch 5 Amp Barrel Grip Jig Saw with Case
How do i get the blade out of my gst 2000
pull up knob on top at front turn anti clockwise three times turn blade 90 deg remove blade insert new blade turn 90 deg turn knob on top clock wise untill clicks press knob back down you are ready to go
Jun 04, 2010 | Bosch Saws
Changing the blade on my Bosch GST 2000
lift knob on top twist 3 times anti clockwise remove blade by twisting it 90 deg insert new blade turn 90 deg,turn knob on top clockwise until it clicks press down and you are ready to go
May 16, 2009 | Bosch #T101A3 3PK 4" 14TPI Jig Blade
What is the process to change a saw blade on Bosch GST 2000 jig saw SDS system
I hope this helps
Apr 06, 2009 | Bosch Saws
Saws Logo
66 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
