Question about Samsung Washing Machines
Diamond drum error le
Have a lg direct drive front loader model wd11020d makes a knocking noise and after a while an Le error comes up, pulled the back of all looks in good condition
Open front door. Pull push on inner drum and see if it wiggles independent of outer drum. If it does, then the knocking is a bad bearing or spyder(part that hold drum to bearings). If inner tub is tight, then I'm not sure issue. LE error is a Rotor Position Sensor error.
Jan 30, 2017 | LG Washing Machines
LG washer IF82 code. What does it mean? This is a washer not a dryer.
LE error is hall sensor is bad or bearing not letting motor turn
Aug 05, 2014 | LG WFT1071TP Top Load Washer
Wm2016cw
LE errors mean the motor is locking up and cannot turn the drum. If the drum turns freely by hand then it could be https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/406-200-684484-/LG-LE-MOTOR-ERROR-Motor-Stator-overheat-or-connection-error-WM2016CW
If that is not the problem then the motor needs replaced.
Apr 15, 2017 | Washing Machines
Cod error 5d samsung diamond?
http://skp.samsungcsportal.com/integrated/popup/HtgDetailGuide3.jsp?cdsite=uk&seq=2132&gubun=I&tabStatus=s&status=&step_no=1
Feb 26, 2013 | Samsung WF330ANW Front Load Washer with...
Drum starts to move then stops then Le appears and a slight hissing noise from direct drive motor. Looks like intemittant fault
The LE error message means "locked motor error" which means the control is not seeing the motor running.
The problem can be caused by a broken wire or loose connection but the most likely cause of the problem is a bad hall sensor.
The sensor can be accessed by removing the rear panel and the rotor assembly. See the image below for help with this. Remember to unplug the washer first.
Make sure the rotor and drum rotate. Anything blocking the tub rotation might trigger an LE code.
Aug 11, 2011 | LG WD-1080FD Front Load Washer
Spinning Motor is overloading
Hi
Thanks for using FixYa. LE error is a communication error between the control board and the motor. In you LG washer the Hall Effect sensor board monitors the direction and speed of the motor and sends this information to the control board. Usually the issue is with this Hall Effect sensor going bad and should be replaced. However, to make sure it’s not a locked motor, try turning the drum with your hand. And, if you feel some resistance while turning the drum or the drum doesn’t move freely then the motor is locked and you’ll need to get it replaced. If it is fine then it is the Sensor. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | LG WM-2277HW Front Load Washer
I START MY WASHER AND IT TELLS ME THERE IS A LE ERROR. IT LOOKS LIKE THE DRUM IS NOT SPINNING, JUST SLIGHT MOVEMENT. BY HAND I CAN ROTATE THE DRUM. ????
LE stands for locked motor error..
1 . check the connections to the Coil/Stator at the rear of the unit possible broken wire.
2 . Coil/Stator Assembly is defective hence no drive
Dec 15, 2009 | LG WM-2277HW Front Load Washer
Lg wd8074fhb will not rotate drum on was or rinse
LE=Load Error CE=Cycle Error
Unplug at socket for two hours will reset the Error Sensors. The sensors are there to prevent overheating of the motor and the possible risk of a fire.
Load Error is linked with too much weight in the drum. Cycle Error is limked with an uneven load.
If it happens again, unplug for two hours to reset the Error Sensors.
Hope this helps.
Nov 16, 2009 | LG Washing Machines
LE error on LG wm1814CW
My wife and I had the same LE error on our LG washer intermittently in the past. We have already been down the road to replacing the Hall Sensor only to find the washer not spinning and displaying the LE error again. Here is what we have found to be the remedy: Being that the Hall Sensor is a "Position" Sensor, we made a conscientious effort after unloading the washer to place the drum in the same position as when it finished its spin cycle. It has now been about 3-4 months with NO "LE" ERROR on the washer!!! One other thing - if you currently have the error displaying, you will have to unplug the washer for at least 2 hours to erase the memory of the drum position. This way you start fresh with a good position. Just leave it unplugged overnight. Hope this helps out!
Mar 14, 2009 | LG WM1814CW Front Load Washer
Washing Machines Logo
11 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
