Question about Kenwood Audio Players & Recorders
It don't stay on. I plug it up and it jest blinks on and off
Carburetor
It sounds like you have a dirt particles in the carb jets or jets, the jest and air bleed orifices are so small it only takes a very tiny piece of dirt or metal shaving to plug them. Remove the carbs and clean them with compressed air and car spray, do not use any other type of cleaner other than carb spray and compressed air to blow out the jest after spraying the. If you are careful removing the float bowl you won't even need any parts.
Feb 11, 2012 | 1996 Suzuki GSX 400 Impulse
I have a lexus es 300, 2002. the check engine light jest came on, and i had it checked at autozone. P1135 code came up, "Fuel sensor heater circuit malfunction". the print out said there could be...
#1 stay away from Ottozoo. #2 have a good repair shop check it out. Most likely the A/F ratio sensor (oxygen sensor) is bad. the BLACK wire is power for the heater, so if the BLACK wire has power, replace the A/F ratio sensor.
Sep 21, 2011 | Lexus ES 300 Cars & Trucks
Are the lights on the router stay on or blinking ?
The power light should stay solid as long as the router is plugged in. The WAN light and LAN lights are solid when you are connected, and the connection is idle. The lights blink when traffic is present. The lights are off when there is no connection.
Mar 15, 2011 | D-Link DIR601 WirelessN 150 Home Router...
I have had 4 pantech jest phones and it wont charge!!!! i had it plugged in then i thought it was charged fully cause the bars were full when i took it out.....BAM!!!! i shutt of!! im sick of it i had 4...
Make sure you're using the Pantech charger you got with your phone. I had this problem, got a new one, and realized I'd been using my old charger charger. Plugged it in with the wrong charger, it wouldn't work. Plugged it in with the Pantech charger, it started charging up and worked fine again.
Dec 27, 2010 | Cell Phones
We have a Mitsubishi tv Model WS48311 purchased in 2003. Recently the picture will blink off and then return on in rapid succession. The sound stays on when the picture is blinking. We hit the ?menu button...
You have bad switches on the front panel. Press them 50+ times to release them. Failing this you will have to replace them. You can disconnect the front panel to confirm this.
Jun 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
