Darfon v144-301 inverter
Tv has black screen
3 Suggested Answers
SOURCE: Either PSU or Darfon V144 inverter backlight problem?
Hi, Please measure all windings again and see if there is one lower than 900ohm. All CCFL might seem working but only for one second before the protection circuit cuts in. By the way, there is something that I would like to know, what is the type number of your remote control?
Posted on Dec 31, 2008
walesarumi
  • 6993 Answers
SOURCE: My 27" Darfon tv's screen
I think you need to check the ballast. The ballast ignites the lamp. A defective ballast to cause your screen display become dull or dim.
So, you might also need to replace the ballast.
Lastly, power problem could cause this type of problem. When the power board is not supplying full current into other parts of the TV, this can cause the display to become dim. So it is also possible that low voltage circulation in the TV is the cause of the problem. Check the power supply board for any short or obviously bad capacitor or any other component on the power board.
But check check the ballast first, if that doesn't fix things, then check the power supply board.
Good luck.
Posted on Mar 31, 2011
My 40"flat screen TV goes black after ahwile the
Check its backlight inverter board, and CCFL lamps. In most cased, the back-light inverter board might need replacement. Check all the CCFL lamps too for any black edges.
Jun 10, 2013 | Televison & Video
Westinghouse LTV30w2 has blank screen and audio only - I've tried cable and RCA inputs, still only audio. My TV flashed the picture and would immediately go to black. I unplugged the TV and when I...
What you have is a darfon V144 board (junk). it's a simple fix if you know how to use some basic tools and a soldering iron. Get an led (i used digikey's PN: L10041-ND) and solder it from pin 10 to pin 16 on the OZ960 chip on the inverter board. If you need the chip layout type "OZ960 pdf" in google. Hope this helps.
Dec 31, 2009 | Westinghouse LTV-30W2 Television
Sanyo ce32ldy1b lcd 160gb black screen with sound
It sounds like you have a power supply problem, this powers the inverter! Where you just replaced the inverter, we could assume it is good! Look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). The power supply can fail on some output and be good on others. Was the back light inverter new? If all else fails, see if you can return the back light inverter and get another! I hope this is helpful!!
Mar 01, 2009 | Sanyo DP32746 32 in. LCD Television
Dec 22, 2008 | Televison & Video
TV SCREEN GOES BLANK
Yes your inverter is bad, I have the same problem my set is about 1 and 1/4 years old. Because Olevia makes a terrible product there inverters are attached directly on to the panel, which means they will only sell the inverter along with the panel i.e $700+ to replace + $100 dollars labor if u don't know how to fix it ur self. I am currently searching to find the manufacture that makes the inverters because olevia will not disclose that information. I believe it is darfon, if so the inverter should cost about $150-200 depending. If you dont believe you can fix it ur self ur best bet is try and sell the set for scrap take ur $100 or so dollar and buy a quality product! Oh and dont call there support they will tell 10 different things before u find out this long for seen truth!
May 04, 2008 | Olevia LT37HVS 37 in. LCD HDTV
No picture.
The problem is with the ic's which will have to be replaced to fix this problem.
Apr 09, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Screen is black except briefly blue upon power on or putting source on "VGA"
Your backlights power inverter board is what causes this prob. It is a Darfon V144-001.
Dec 30, 2007 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
No picture on Westinghouse W32701 LCD Model
Screen goes black, sound unaffected. Can be remedied by turning off and immediately back on, but it will do it again and again and again.
Nov 11, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
