Question about Samsung Washing Machines
Out of balance
Washer is not balanced after a move
SOURCE: drum off balance
It's either a bad suspension spring or you have a crack in the tub support.
Posted on Jul 15, 2008
  • 18 Answers
SOURCE: washer tub goes off balance every time and washer walks!
there may be a possibility here of the centre hub being worn or the liner tub bearing being worn due to the age of the machine.. here is a list and diagrams of the parts you may need and can get from here:-
http://www.easyapplianceparts.com/MultiModels.aspx?ModelNum=mat13mn&searchTerm=img_CW17-6&RefineSearch=0&imgMfg=Maytag
try to check for slackness when the tub is empty causing a rocking/slapping motion whilst empty. if the tub is used regularly and to its maximum capacity then the likeliehood is these bearings/hubs may need to be replaced.. the "walking" across the floor will be accented by the amount of items plus water in the tub. and if the tub is off balance,then this will be more highlighted when also full of water and items... if you feel this is over the top,then try to lighten the load that is in the tub at any given time. this will determine weather the bearing has indeed worn .the lighter the load,the less "walking the machine should do in cycle.. the only time walking would be unchanged is during the spin cycle,when the speed is of a constant one and it will vibrate at the same rate. placing it on a rubber mat is not a solution but just something that will make you hopefully think it is solved
and you may as well just bolt the machine to the floor and hope for the best
Posted on Dec 27, 2008
  • 92 Answers
SOURCE: Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
Posted on Feb 06, 2009
onthejob5130
  • 640 Answers
SOURCE: Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Posted on Feb 07, 2009
SOURCE: Kenmore top load washer counter balance spring
There's a nice picture here.
Posted on Feb 20, 2009
Washer clothes
Your load is out of balance.
If you have a heavy item, spread it around the tub to balance the load.
It is normal for the tub to shake during the spin cycle. The washer has a safety feature, if it is too badly out of balance it will shut itself down and sound an alarm.
Jun 01, 2014 | Whirlpool Refrigerators
Kenmore washer lid locks tub moves for about 3 second
Have you tried balancing the load? Your washer is either sensing the load is off balance or displaying the effects of a tub problem. So step one is balance the load. Let me know if that doesn't help.
Jan 18, 2013 | Washing Machines
How to balance a frigidaire washer?
Hello - Are you speaking about being balance without the leveling legs? Is the unit located on complete level ground? Or is the washer tub loose and unable to move? If you are referring to the drum, try rotating it manually when it is turned. If you notice that the drum is not balanced and cannot rotate freely, I would suggest contacting a professional so they can move forward accurately. Washer may possibly have a faulty bearing, unbalance drum or pulley issue.
Dec 06, 2012 | Frigidaire Washing Machines
Washing machine balance is off since we moved it.
There are tension springs attached to the tub. They are for the balancing upon spinning. Check and see if one came loose
May 12, 2010 | Maytag EPIC MFW9700S Front Load Washer
My washer is out of balance when spinning.
Your problem is probably much more than the washer being out of balance. The front load washers have shock absorbers that hold them from moving all over the place. These have a habit of breaking. Then the drum hammers and sounds like things are flying apart. Pull the bottom front off and check the shocks. Typically the rings where the pins go throuhg are where they will break. Sometimes at first they look okay and you have to grab them and move them to see that they are broken.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Top loader Maytag washer cannot balance load
The shock absorbers that hold the tank are broken. Then the load will move the washer all over the place.
Look online for an exploded diagram and order the new shocks for it
Nov 12, 2009 | Dryers
Maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Sep 27, 2009 | Washing Machines
Will not spin or agitate
Get the model number. It may have an off balance switch that is stuck. Try moving agitator like its off balance and then turn on.
May 18, 2009 | Washing Machines
Drum off balance
how do I tell if the drum is off balance or the bearings are out in the inner tub of this front load washer?
Jun 30, 2006 | Whirlpool GHW9150 Front Load Washer
Washing Machines Logo
10 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
