Question about Dehumidifiers
Altec bucket moving slow - Dehumidifiers
My DEHUMIDIFIER shows check-red light
well you didnt mention model but most times this occurs on dehumidifyers it means the bucket full sensor has tripped , this does not mean that bucket is full, it just means that bucket is either not seated all the way in or maybe the sensor has moved in the bucket and no longer hits the sensor as it should , try reposisioning the bucket and full sensor , ck for looseness
Nov 15, 2014 | Dehumidifiers
My Comfort-Aire Dehumidifier has started leaking water. The unit works fine but the water bucket does not retain all the water. As the bucket fills there are slow leaks. Also, sometimes when replacing the...
It can have leaks from the condenser to the bucket. The piping and hoses should be checked all the way. Perhaps even replaced or at least cleaned. I don't think it is wise to do this yourself. Because in the system also can be algae, bacteria and viruses. And you need tools and skills to replace defective tubes, pipes or gaskets.
Oct 10, 2014 | Dehumidifiers
Humidifier is draining on floor while bucket is not yet full- why?
ck that float level in corner of bucket is free and moves well , also verify that unit is level as this affects the float and amount that bucket can hold , also a ck that drain hole that allows water to enter into bucket is not partways plugged with something , should be pencil size hole there
Oct 01, 2014 | Danby Dehumidifiers
Code: CH 67
Bucket switch/float valve sticking? Take out the bucket and make sure the switch moves freely.
Oct 20, 2013 | Maytag M7DH45B2A Dehumidifier
The water full light glows and the collection bucket is empty. nothing is happening. Any suggestions. thank you
The bucket level sensor may have been moved, bent, or ? the last time the bucket was removed, dumped, and reinstalled.
Sep 11, 2012 | Daewoo DHC-400 Dehumidifier
The light indicating the bucket is full stays on with no water in it.
Michael, the problem you're experiencing is caused by one of two things. Solving either requires turning the unit OFF , unplugging it and removal of the water collection bucket.
1. The float valve in the top of the bucket is either broken or stuck in the ON position. Check the arm of the float valve to see if it moves freely and is not broken.
2. The bucket was not reinstalled properly. Install the bucket so that it fits "squarely' from top to bottom into the bucket holder and that is it makes good contact with the bucket safety removal switch on the rear wall of the bucket holder.
Hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Sep 22, 2011 | Maytag M7DH65B2A Dehumidifier
My dehumidifier full light is on but the unit is empty and the fan motor won't work. Is there a way to reset it? Is that why the fan motor won't work?
This is generally causes by improperly installing the water collection bucket after removing it to empty it. Or the float valve in the top ow the water bucket s stuck in the "UP" position. Some Maytag models have a float control that moves from left to right, depending on how much water you want it to collect, before having to empty it. It may be stuck in the center position and needs to be moved left or right.
When installing the bucket, be sure that it fits into the holder "squarely" from top to bottom and makes contact with the bucket removal safety switch at the back of the bucket holder. When installed properly, the bucket should not tilt down at the bottom.
Hope this helps you and thanks for choosing FixYa.
Aug 06, 2011 | Maytag Dehumidifiers
Slow blinking light the same as johnworland on june 13th. A solid light indicates full bucket. I was getting full bucket light the last couple of times I checked the unit. odd because it is set up for...
remove the bucket and check the yop of it for a Float Valve. The float my be stuck in the UP position, If so, jiggle the arm of the float to make it return to the DOWN position.
Jul 13, 2011 | Comfort-Aire BHD-301 Dehumidifier
I have a slow blinking red light - not working
Normally, the slow blinking red light, indicates that the water collection tank/bucket is full and needs to be emptied. If the bucket is NOT full, it indicates that the tank/bucket was not installed or reinstalled properly, because it did not make secure contact with the bucket removal safety switch. Removing the bucket and reinstalling it properly will normally resolve the problem. Make sure the bucket fits squarely into it's holder from top to bottom.
In case you have misplaced your Owner's Manual, I have included a link to it, that you can download and print for future reference. http://www.appliancefactoryparts.com/content/pdfs/117029-1.pdf
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 13, 2011 | Comfort-Aire BHD-301 Dehumidifier
Bucket fills, doesn't stop
make sure unit is level , the cut off switch will not work if not level
Jun 07, 2009 | LG LD65EL Dehumidifier
Dehumidifiers Logo
26 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Dehumidifier Expert? Answer questions, earn points and help others
