Question about HP LaserJet 2420 Printer
On 3 different HP printers I get a printer error 49 when I attach printer to network
  • 300 Answers
SOURCE: 49.FF05 SERVICE ERROR
A critical firmware error has
occurred.
Try following these steps -
1. Press CANCEL JOB to clear the
print job from the printer
memory.
2. Turn the printer off, and then
turn the printer on again.
3. Go to http: www.hp.com/
support/lj2410, www.hp.com/
support/lj2420, or
www.hp.com/support/lj2430.
Click Download Drivers and
Software
. Check for the
latest firmware image version
at the bottom of the page. If
this firmware image is newer
than the one installed on the
printer and the printer can
receive a firmware update,
download the newer firmware
upgrade. Not all printer
models can receive firmware
upgrades.
4. Try printing a job from a
different software program. If
the job prints, go back to the
first program and try printing a
different file. If the message
appears only with a certain
software program or print job,
contact the software vendor
for assistance.
1. After performing the actions
listed in the preceding item, if
the message persists when
using different software
programs and attempting
specific print jobs, disconnect
all cables that connect the
printer to the network or a
computer.
2. Turn the printer off.
3. Remove all memory DIMMs
or third-party DIMMs from the
printer. (Do not remove the
firmware DIMM in slot J1.)
4. Remove all of the
EIO devices from the printer.
5. Turn the printer on.
6. If the error message
disappears, reinstall
each DIMM and EIO device
individually, making sure to
turn the printer off and then
on again as you install each
device. To replace a DIMM,
see.
7. Replace the DIMM or
EIO device that caused the
error message.
8. Remember to reconnect all of
the cables that connect the
computer.
9. If this error message persists,
replace the firmware DIMM.
10. Replace the formatter
Posted on Jul 14, 2008
leroyal
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
trungkien810
SOURCE: hp 3050 error 49
on the menu setup and then mover to usb opption. choose full usb (do not choose hight usb) now ii's ok!!!
Posted on Jun 15, 2009
  • 21 Answers
SOURCE: HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
Posted on Jan 07, 2010
SOURCE: error 79 hp laserjet m2727nf mfp; error 49 hp laserjet m2727nf mf
Bueno, el error 79 en mi caso se presentó con el servidor de impresion, tienes que limpiar los trabajos en cola y luego reiniciar la impresora.El error 49 indican que es con un problemas de fax o con scanear en Mac OS X, en todo caso hp support tiene los pasos a seguir.
Posted on Jul 26, 2010
Error- 49.4C06
I had this error too, i had 32 MB ram in the printer i took it out and put in a 64 MB chip in and the error went away.
Jan 12, 2016 | HP LaserJet 2420 Printer
Tip
49.XXXX errors on HP LaserJet Printers
The 49 error is the printer telling you that a command or information it received it did not know how to process. Much like if someone tried to tell you how to do something but spoke a different language than you. The first step to fix this problem is to restart the printer. If it comes to ready, skip down to the next paragraph. If if does not come to ready, you will need to clear any print jobs from the print queue on your computer and then restart the printer again. If the 49 error still occurs, you will need to unplug either the parallel, network cable or usb cable to see if the printer will come to ready with no computer attached, if it does then restart your computer and then reattach the cable. If the printer is on a network, make sure that no computers have jobs in the queue for the printer. Once you have the printer at ready and attached to your computer. you will need to update the firmware as this usually fixes a 49 error. Go to www.hp.com and from this page select "SUPPORT AND DRIVERS". Type in the model of your printer. For most home machines, the new firmware will be shown once you select your correct operating system. For business class machines, there will usually be an option for "cross operating systems (bios, firmware, diagnostics, etc). Once you have downloaded the new firmware file, there will be a readme file attached that explains how to install the new firmware. For many of the newer printers, an Easy Firmware Update Utility is available. It is simply an executable file that finds any compatible pirnters automatically and processes the update. This is the best choice if your printer comes to ready and is connected to your computer via USB.
on Apr 11, 2011 | HEWLETT-PACKARD CM1415fnw AllInOne Laser...
What does the error message - 49.4C02 - mean?
49 errors are often caused by the printer receiving commands it does not understand. Sometimes hardware failures but not often. To determine hardware or software, turn the printer off. Unplug any network or USB cables attached and turn printer on. If it will come to ready with no cables attached, then likely you have a print job that is causing problems. This can be fixed by installing the latest firmware from HP.com. Download the Easy Firmware Update Utility version. To install this update you need to have the printer connected to the computer, so check the print queues to make sure that there are no print jobs pending, delete them if there are. Plug the network or USB cable back in. Wait a couple of minutes to make sure that the 49 error does not come back. If printer stays on ready, run the upgrade utility and your problems should be gone. If it is a hardware issue then a different set of trouble shooting steps applies. Post back if this does not fix your problem.
Aug 15, 2014 | HP CP3525DN Color LaserJet Printer
We have an error 49.283 come up on our HPLJ 9050n, how do i fix tis
A 49 error is usually caused by either a corrupt print file or file that the printer does not understand. In most cases updating the firmware will resolve these problems. First, unplug all usb and network cables attached to the printer and power it on. If it comes to ready that is a good sign. Make sure that there are no stale print jobs in the queue of any computer that prints to the printer. Plug the network or usb cable back in and see if the printer continues to stay on without a 49 error. If yes, then go to www.hp.com and download the current firmware for your printer. Most firmware updates for these units are available as an easyupdate utility. Run that utility from any computer that normally prints to the printer. Select that printer from the drop down menu in the utility. After the firmware has been updated the printer will restart and you are ready to go, with your 49 error a past memory.
Jul 09, 2014 | HP LaserJet P4015N Printer
49.4 C18 laserjet 4345
49.XXXX is a fatal catch-all error. Could be firmware problem, network, print job. If the error occurs when you try to print, clear the print queue. If the error occurs when the printer is just sitting idle, reseat the formatter. Try powering on without the network cable attached. If it still happens replace the formatter. Could be a corrupt print job being sent to printer. Print something else.
Mar 28, 2014 | HP LaserJet 4345mfp Printer
One of the hp 9050n printer have 49.2f83 eror what is the solution please
Follow these steps.
1. disconnect all parallel, network and usb cables and power cycle printer. If it comes to ready good.
2. After making sure that all print jobs are cleared from printer queues, reconnect the network cable or parallel cable. If printer stays are ready, good. If it errors again, likely a stale print job that you missed in a queue. Check and start over.
3. When you can get the printer to ready with the network cable attached. Go to HP.com and download and install the latest firmware on the printer.
If the printer continues to 49 you can try updating the print driver as well. If the 49 error is persistent, remove the formatter and try to perform an engine test. if the engine test works then you have either a bad formatter or bad memory on the formatter. Remove memory and restart, still error, then formatter it is.If the engine test does not work then you may have a bad dc controller.
Mar 08, 2014 | HP LaserJet 9050 Printer
49.ff05 service error hp laserjet p5200
there is nothing wrong with your printer!! it is a connunication issue from the computer to the printer... cancel the document that you tried printing and try reprinting it again.. to clear the error remove the USB cable or Network cable then turn off the printer.. then back ON while the printer is in the ready state re attache the USB or Network cable and reprint the document :-)
Jan 02, 2014 | HP LaserJet P3005d Printer
My network printer and scaner can't install its giving error fatal error
Which fatal error do you have. If you have a 49 error, you can check my tips on resolving 49 errors. If you have a different error, please post back with the exact error code and I can provide guidance on that.
May 03, 2011 | HP LaserJet M3035 MFP Printer
Error message 49 on my HP CP 2025 (printer shuts itself off and truns itself back on to see error message 49)
Firmware error:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Nov 22, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
LaserJet 4350n Error 49.C02
49.XXXX PRINTER ERROR To continue turn the printer off then on Description The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications. Action
  1. Press Cancel Job to clear the print job from the printer memory.
  2. Turn the printer off and then on to clear the error message.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
  4. If the above action does not solve the issue, contact HP or authorized service provider.
Dec 05, 2008 | HP LaserJet 4350 Printer
HP LaserJet 2420 Printer Logo
27 people viewed this question
Seeker5211
Seeker5211
