Question about Bissell 5200 Flip-It Hard Floor Wet & Dry Cleaner Lighweight
Bissel flip it won't spray water
Won't spray water
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
reddevil6
  • 1673 Answers
SOURCE: Bissell proheat
First is the smart mix valve turning like it should? If it is then replace the soap dispensor. Also is the gasket on the valve at the bottom of the bottle?
Posted on Jun 01, 2008
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
  • 10 Answers
SOURCE: bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Posted on Sep 26, 2009
Vac Belts
  • 701 Answers
SOURCE: My Bissell Proheat is not spraying water. What is ...
It is very simple and inexpensive to fix. All you need to do is replace the pump belt. Here is the belt you need:
Bissell Proheat Pump Belt
Posted on May 25, 2010
Won't dispense water
Hey Parker. I know how frustrating no spray can be when you're ready to clean your carpets.
Here's a complete list of troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Mar 30, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell flip-it select won't spray clean solution
I'm sorry to hear about the spray issue you're experiencing.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1237&cid=ccsocial
Mar 07, 2013 | Bissell Flip-It Select Hard Floor Cleaner...
Water won't stop spraying water 9400 bissell
Hey, you may want to have a Qualified Technician at a BISSELL Authorized Service Center inspect your machine.
Here's a quick link to locating one of our Authorized Service Centers in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 27, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a bissell pro heat 2x +and the water is not coming out of the hand tool or the carpet cleanerr
We are sorry about the issues you've run into.
This link gives detailed troubleshooting instructions for you: http://www.bissell.com/FAQDetail.aspx?id=1122&icid=ccrr
And this video shows easy maintenance items: http://www.bissell.com/how-to-videos/proheat-2x-machine/care/?icid=ccrr
If your machine continues to not spray, please take it to a BISSELL Authorized Service Center for warranty repairs. If you are experiencing difficulties other than no spray, the technician will let you know the cost for those repairs if your machine is outside of the one year warranty timeframe. You can locate a BISSELL Authorized Service Center at this link: http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50&icid=ccrr
One pointer that can help between uses is running water through the lines. First, put clean water in both tanks and set your unit to the heavy traffic setting for one pass. This will flush out any cleaning formula in the lines so your spray tips won't get build-up between uses, which can lead to a lack of dispensing the cleaning formula.
Jun 27, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a bissel pro heat 2x and it wont spray
I love these and have 2 of them! The warrantees are usually good and it is your pump if both the hand held and carpet positions won't spray water. Both the soap tank and water resevoir need to have at the very least water in both for the unit to work. Yes... You can use just hot water for light cleaning in both. The pump controls both the spraying water and suction. Last, if one or the other won't spray, the unit can have residue blockage. The passages are narrow, check to see if they are clean. Last test. Turn it on, release the handle. At the base of the neck there will be an oval shaped opening. With the handle on the floor as if filling the unit with water...put either your hand or a paper plate over the hole to see if there is suction. If the pump is good, you will feel a lot of suction against your hand or the flat surface of the plate.
Sep 05, 2011 | Bissell Vacuums
WON,T SPRAY CLEANER/WATER CARPET IS DRY.THE TOOL ATTACHMENT WORKS OKAY.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 08, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Water wont spray out of bottom carpet cleaner but will out of the scrubbing hose
First try putting in a little hot water in the water resevoir , let sit for about about 5 mins. then try it. if this doesn't work, flip the machine over and locate the spray jets on the bottom. You'll need a pin or something small enough to clean out the jets bye sticking pin or paperclip in it . Detegent left in the machine sometimes cloggs the jets.Empty water before you flip the machine over.
Dec 12, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Pro-Heat 2x 12 amps Model 9200-2 The rollers wont turn and the water wont release
my bissell 9200 won't release water or solution when the trigger is pulled.
Sep 16, 2008 | Bissell 9200 Upright Vacuum
Bissell 5200 Flip-It Hard Floor Wet & Dry Cleaner Lighweight Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
