As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.? this is for the Panasonic sa-ht 880.
Maybe the fan doesn't rotate at the proper speed. Try to put some oil on the bearing sleeve or even replace the fan.
If it offers resistance it will show F61 and disconnect.
am o combina muzicala marca panasonic modelul sa-ak240 si imi da o error f61,dupa ce o aprind la nici un minut imi da error f61 apoi se stinge.din ce cauza ma puteti [email protected] astept un raspuns
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
I had the same problem, and I had to replace the fan on the unit. The fan would not turn on at all, so the computer would tell the unit to turn itself off. After the fan was replaced (which is relatively simple) it works like new.
