Question about Samsung HL-R5678W 56" Television
Press front power button and "lamp" light begins to blink. picture appears for about 2 seconds before image freezes and then tv turns off again. A few seconds later it powers back on by itself, "lamp" light is no longer on but same thing happens with the image. set turns on and off intermittently until ou unplug it. Sound is fine when image is on. I have no remote so I need help with how to troubleshoot this with the button on the set. Thanks for your help!
  • 597 Answers
You can start by contacting Samsung tech support
Posted on Feb 09, 2014
4 Suggested Answers
SOURCE: DLP no image at time - no chime - lamp light blink but no image - sometime 3 front panel lights blink
i have the exact same issue.
have you found the cause?
Posted on Apr 02, 2008
SOURCE: Samsung DLP won't turn on-rapid clicking sound, lamp light blinks
it was bad bulb
Posted on Mar 04, 2009
  • 41 Answers
SOURCE: Tv picture freezes then goes black 10seconds later HL-R5067W
Sounds like the digital board needs replaced.
Posted on Jul 11, 2009
Replaced lamp on mitsubishi wd62527 worked for 10 minutes then shut down. Now red lamp light is on
If the red indicator light on the front of your HDTV is glowing a solid red, you should first unplug the AC cord from the wall power outlet and wait for 60 seconds before reapplying power to the HDTV.
After you turn the TV on, if it doesn't power up, try holding the power button down for at least 8 seconds. That's supposed to force a system reset. If your model has a system reset button, use that instead. Press the reset button for about 20 seconds...release it and press it again for 20 seconds, release it again and the led will blink just for a minute or two. You should now be able to turn the TV on.
If after several attempts, the HDTV has not fully powered on and the LED on the front of the HDTV is still glowing solid red, you may want to reseat the lamp.
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp.
Apr 05, 2015 | Mitsubishi Televison & Video
Tv will not power up
Press the TV button or ON/OFF button while remote is in TV mode and there's a source of power to the outlet or outlet strip.
Make sure the TV is plugged in.
You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or flashing section below for more information.
When you first plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when the TV is unplugged and plugged back in. The TV can
only be turned on after the Power indicator goes off.
Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else, such as a lamp.
Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 53.
Multiple TV Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Setup Options, then Advanced
Options, then Multiple TV Setup. Choose TV (default).
Sep 26, 2013 | RCA Scenium M50WH187 50" HDTV
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Sep 04, 2012 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
    The following steps should be able to correct the problem:
    1) Unplug the TV or remove AC power from the TV
    2) Count to ten and then plug in the TV
    3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel
    4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons.
    5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons.
    6) The TV’s lower left Blue Power LED will come ON.
    7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
    8) Press the [Mute] button on the TV remote twice
    9) Unplug the TV or remove AC power
    10) Count to ten and plug the TV in
    11) The TV power should automatically come ON and the blue power LED with be ON
    12) Wait 40 seconds and the TV picture should appear
    13) You can now continue using your TV.
    14) If the picture does not appear, power on the TV manually:
    · If the LED begins flashing, unplug and power ON a second time.
    · If the LED begins flashing again, power ON the TV without unplugging
    If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you.
    If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
    1) Press the [Menu] button on the remote control.
    2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote
    3) Scroll down to "system info" and select [OK] button on the remote
    Dec 19, 2009 | JVC Televison & Video
    I have RCA HD50LPW167 DLP TV with NO Sound and NO Audio. The LED blinks when I turn the TV on but that's all it does. Took it to the local RCA authorized repair shop and they told me that the digiital...
    Still sounds like a lamp:
    TV won’t turn on
    • Press the TV button or ON/OFF button while remote is in TV mode and there’s a source of power to the outlet or outlet strip.
    • Make sure the TV is plugged in.
    • You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
    • Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
    is blinking or fl ashing
    • When you fi rst plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
    and then go off during the initialization of the TV. This happens only when power is reapplied to the TV. The TV can only be turned
    • Check the wall receptacle (or extension cord) to make sure it is “live” by plugging in something else, such as a lamp.
    • Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
    remote control solutions on page 84.
    Remote Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Connections, then Special Features, then
    Remote Setup. Choose TV (default).
    Power indicator is blinking or fl ashing
    If the light blinks 5 times, pauses, and blinks again 5 times, the lamp is trying to turn on. If the TV doesn’t turn on after 5 minutes and
    then the light blinks steadily for one minute, one of the following options is possible:
    • Lamp door may be open.Face the back of the TV. Locate the door at the bottom of the TV and close it. Turn off the TV and turn
    back on. The lamp should turn on.
    You can easily replace the lamp yourself by following the lamp replacement instructions. If your TV is still covered by
    the warranty, call 1-866-723-6486 to receive troubleshooting assistance and a lamp replacement.
    • If your TV’s warranty has expired, call 1-800-338-0376 to purchase a lamp replacement.
    To order the correct lamp, you’ll need to know your TV’s model number, serial number, and lamp type—this
    information is listed on the Service Model Number sticker (example of the sticker is shown above). Face the back of
    the TV. The sticker is located on the right side of the TV.
    Hope this helps :)
    Mar 07, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
    TV won't come on
    Menu and Input/Device button on front panel for 5 seconds, then this will flash a 2 digit seq. this will be your error code.
    Apr 05, 2008 | Mitsubishi WD-62525 62" Rear Projection...
    Tv keeps turning off?
    cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
    Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
    Samsung HL-R5678W 56" Television Logo
    87 people viewed this question
    Henry  Thomas
    Henry Thomas
