Question about Parrot 3200 Ls Color Handsfree Bluetooth Car Kit
Parrot no volume on speaker - Parrot 3200 Ls Color Handsfree Bluetooth Car Kit
No volume on parrot ck3100
check the settings on your phone first. turn it up on your phone and then go to settings and move up the phone setting volume.
Aug 25, 2012 | Parrot Hands-Free Car Kit with LCD Display...
Iphone volume
Have you tried to remove the device from your iphones blue tooth list, and reset the connection?
Mar 15, 2012 | Parrot SA Parrot Evolution Bluetooth Car...
How do i wire a parrot to my 07 plate jeep patriot
how have you wired it up, have you used the correct lead? on some jeep cars the sound only travels down the rear speakers and the amp in the boot splits the sound. you will also need to radio on for the parrot to work.
Dec 02, 2011 | Parrot Par Ck3000 Evolution Ck3000...
I have a parrot ck3000, but i dont know how to erase the memory using only the steering wheel contols. i have tried to hold the call and answer buttons simultaneously but it does nothing, i have tried with...
You will need to plug in the original parrot control to do this. contact the supplier if you do not have it as they should have left it with you. Otherwise Parrot web site has a list of certified engineers.
Feb 19, 2011 | Parrot Par Ck3000 Evolution Ck3000...
Connected Parrot Ck3100 in Toyota Rav4 with Alpine 5897 aftermarket head unit. Tapped the Parrot harness into the speaker wire between the Front driver side speaker and amp, per instructions and phone...
First, you will have to ensure that the vehicle doesn't have an amplified system build in it. Cause in that case the kit should use the two wires line in and line out and check behind the autoradio if you have the entries line in line out. (with this solution, no accessibility with the mute when you have the radio and you receive a call).
But the general idea is to ensure about the vehicle system build in it, cause with an amplified system, you have to avoid it to passing the sound directly to the speakers. (may be wires to wires or a specific harness which is taking acount of it).
Feb 27, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
No one can hear me/sound is very bad Parrot 3200
it sounds like the microphone is trapped or faulty, get the engineer back to sort it out or follow the microphone wire to see if is trapped behind the trim going down the side of the winscreen.
Dan
Feb 16, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
No intruction manual
hi
kindly download the user manual from the below link....
http://www.parrot.com/usa/support/userguides/parrotminikit
thank you
have a nice day
May 07, 2009 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Speaker has no volume
i have just got a new phone using the same chip but unable to pair up with the parrot
what will the pair passcode be ?
Nov 02, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Parrot 3200 Ls Color Handsfree Bluetooth Car Kit Logo
23 people viewed this question
Top Parrot Cell Phones Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
