Question about Saeco XSmall Plus Automatic Espresso Machine
My xsmall won't turn on - Saeco XSmall Plus Automatic Espresso Machine
My Saeco Xsmall stops before brewing the coffee
1- The grind fineness setting is too fine. Pump is not able to pump through the compacted coffee grounds.
2- The machine is not descaled. The Calcium deposits in the hydraulic system have reduced the pump pressure. The partially clogged water passages can generate a back pressure to reduce pumping pressure. Was the machine descaled in the past two or three moths? If yes, what was the descaling product used?
3- The pump may be air locked and not able to pump water.
4- Oily beans may have been used. Oily beans are poison for the all fully automatic espresso machines. This clogs the grinding chamber or the grinder outlet. This model is made in Romania made in 2006 or after. This machine has a Ceramic Burr grinder 2006 which is a huge problem to clean adjust beans quantity per shot of espresso etc. etc. Occasionally it will dump dry coffee grounds when the quantity of beans powder is insufficient.
Based on the above details, you can figure out what is wrong and fix it. See the exploded parts diagram included, for help. Services Unlimited Inc Parts Guru Since 1988
Dec 29, 2016 | Saeco Coffee Makers & Espresso Machines
My saeco xsmall has red light continuously on after rinsing
You have to turn the button to the side where is the icon of the cup.
Then you have to wait until the machine stops running water by itself.
Jun 28, 2014 | Saeco Xsmall Superautomatic Espresso...
Why does the red and green light on the right side stay on?
Hi there, I am having the same issue. The machine has worked before, but I haven't used it for a while. I need it to work now while I try to fix my other machine! I will post a reply if I work it out.
May 13, 2014 | Saeco Coffee Makers & Espresso Machines
My Saeco xsmall plus espresso machine is flashing red light on it
Owning this machine for nearly five years, all I can say is that it is an example of problematic engineering. It does not except dark roast some of the time, and if it is very well roasted it won't accept it at all. As the machine is fully automatic, there is not much you can do but roast the coffee to a degree that will be accepted by the machine. IMHO this is an unacceptable decision made by engineers and Saeco should address this issue.
Nov 04, 2012 | Saeco Coffee Makers & Espresso Machines
During the rinse and spin cycle, water is sprayed everwhere
There may be too much water and not enough clothes in the washer. If that is the case the water rises up the side of the tub when spinning and overflows the inner tub. Usually it goes into the outer tub but it can spurt out through bleach dispenser and run down the inside of the cabinet or hit the lid and splash out. Set water level (Xsmall, small, medium, large, Xlarge) appropriate for amount of clothes.
Aug 11, 2009 | Washing Machines
Nintendo wii console
Hold the power button in for about ten seconds. See if that brings it around.
Dec 28, 2008 | Nintendo Wii Console
Saeco XSmall Plus Automatic Espresso Machine Logo
130 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
