Question about Samsung Office Equipment & Supplies
4527 printer ERR AQUEC ABERTO
My new printer has been set up on my laptop its a hp envy 4527.it printed photos the other week . but not now. its showing details of my old printer on laptop which is hp envy 5530
Go to installed devices and see if your old printer is still listed on your computer; if so, remove it from your install devices and then re-install your new one.
Jun 28, 2017 | HP Office Equipment & Supplies
How do you connect a Microsoft Lumia 510 smartphone to a HP ENVY 4527 printer wirelessly? I have tried but it just won't connect wirelessly.
In this case the problem comes from the phone.
If all other device can....
Maybe you need to set an option on the phone to be able to use a printer. It's a WINDOWS phone....
Mar 20, 2017 | HP Cell Phones
Como tirar apenas um lado da folha?
Para imprimir dois lados documentos utilizando o software Lexmark, por favor siga os passos abaixo:
  1. Com o arquivo aberto, clique em Arquivo> Imprimir.
  2. Na caixa de diálogo Imprimir, clique no botão Propriedades, Preferências, Opções ou Configurar (dependendo do programa).
  3. A partir da guia Layout de impressão, selecione o layout e as configurações de duplex para o tipo de documento que pretende imprimir.
  4. Depois de ter aplicado todas as configurações desejadas nas Propriedades de impressão, clique em OK na parte inferior da tela para retornar à caixa de diálogo Imprimir.
  5. Clique em Imprimir para concluir a tarefa.
Nota: Esta é traduzido usando translate.google.com.
Jul 25, 2011 | Lexmark Refurb X1185 All-in-One USB...
I have a wep p7-500 line printer .this printer give a err -48v circuit * see manual
its related to PPC Board... replace ppc board...need to repair PPC Board..
Jan 06, 2011 | Printronix Line Matrix P5005B Printer
How do i clean a ricoh ft 4527 copy machine
start with the optics, corona wires, use the vacume cleaner, alcohol, water,...
Jan 05, 2010 | Ricoh CL4000DN Laser Printer
1332 infoprint printer not supporting 1332 toner cartridge
If the toner in the machine is NOT MIRC it will not work in a MIRC printer. Get the correct toner cartridge or get a NON MICR printer to put your toner in. MICR uses a special toner (magnetic) for printing checks and the printer is usually modified at the factory (troy or others) to make it print using MICR toner. No way around it.
Aug 14, 2009 | IBM Infoprint 1332 Laser Printer
Ricoh FT-4527, E541 error. I know that the hardware relating to this problem is the fuser, lamp, fuse or fluctuating voltage, but I don't know the key strokes to remove the error code after the part has...
....Nor do you have the parts. I answered you earlier today. If it were a simple fix/ adjustment I'd be happy to provide it. You need a trained technician, and only technicians will have the codes. You can find yourself in even bigger difficulty messing with service procedures that you know nothing about...cut your losses.
Mar 12, 2009 | Ricoh Office Equipment & Supplies
Error code E5 41 on Ricoh copier model 4527, or FT 4527
It is a fuser error (low warm up temp), often caused by fluctuating voltage.You have a blown fuse, lamp, or thermistor. Can only be reset in service mode after the problem is solved.
Mar 11, 2009 | Ricoh Office Equipment & Supplies
Toshiba A135 S 4527 ......some times freezes
Virus information and help Below is a listing of some of the different properties a computer virus is ... Alter the system time / date. Cause system to hang or freeze randomly.
Computer questions and answers listing 700 - 800 CH000700, What should I do when a computer freezes?
Good Luck, Please dont for get to Vote, Thank You
Nov 28, 2007 | Toshiba Satellite A135-S2276 Notebook
21 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
