Question about Toshiba Satellite U925t
TOSHIBA U925T LCD replacement guide?
Replace LCD Screen for the TOSHIBA SATELLITE U925T ultrabook. I need a guide to do this. I can purchase the screens on ebay for about $50 but it seems very difficult to replace. Any help?
  • 26 Answers
Well it is not that hard as it seams to be. First catch at Toshiba is plastic overlay above the keyboard it is cca 10 mm thick you should remove it with the screw driver carefuly. when removed you'll find screws unscrew them. After that remove hard drive and remove the cover for ram slots. Then remove all screws from the bottom side of the notebook. After that turn the notebook on the right side as you would do it normaly when using it. Remove the keyboard. After that remove all screws that you'll find under the keyboard. When done carefully remove the upper cover of the notebook. After that dismount the cables that come from the monitor to the mainboard and remove the screws holding the monitor brackets. Then you'll be able to remove the monitor. The monitor has litle rubber circles in every corner remove them. You'll find screws under them. Unscrew them and grab the plastic border of the monitor from the inner side and pull it towards you. So now you have removed it and the only thing that has left is to remove the side brackets you'll see little screws from the side - remove them and also remove the signal cable from the back of the monitor. When done take new monitor and do the reverse procedure.
Posted on Feb 07, 2014
djnick989
  • 1067 Answers
SOURCE: Toshiba Satellite A105 grey screen
just replace screen pop top off unscrew it out and unplug it put new one in and do u have latest video card drivers installed make sure u do that also
Posted on Jan 06, 2008
  • 13 Answers
SOURCE: want to replace cmos battery in Toshiba Satellite A10
On Toshiba laptops you hit the ESC key as soon as you turn it on & then you
are given the option to hit the F1 key to enter bios.
As to the cmos battery, they couldn't have hidden it better if it was the Queen's diamond!
It is near the bottom of the laptop on the right side, almost directly beneath the pause/break key.
Problem is, you have to disassemble the entire laptop to get at it!
Disassembly instructions for the Satellite A10 are here
http://www.irisvista.com/tech/laptops/ToshibaA15/SatelliteA15_laptop_disassembly_1.htm
Best of luck
Barb
Posted on Mar 03, 2009
  • 7 Answers
SOURCE: Replacing screen on my toshiba equium a100 306
this is not the same model but i think you will get the idea.
http://www.fonerbooks.com/laptop_5.htm
Posted on Jun 17, 2009
  • 942 Answers
SOURCE: need to replace LCD screen toshiba p105-s6024.
Hello
First of all, I assume that your new LCD screen is compatible with theold one. Different screens require different video cables. Make sureyou new screen is compatible with your laptop.
Use the link below for more details and instructions.
http://www.laptoprepair101.com/laptop/2008/09/18/you-replaced-broken-lcd-screen-but-the-new-screen-is-not-working/
Regards
PCmania
Posted on Sep 26, 2009
  • 11 Answers
SOURCE: the screen on my Toshiba satellite p205 went dark
There is a way to brighten and darken the lcd screen. Perhaps it under a energy saving mode, like when you run on battery power, sometimes the screen will go darker. Anyway, if that is the case, try holding Function and press F8 to brighten it, and F7 will darken it too.
Posted on Dec 10, 2009
How do I replace the LCD cable
Purchase a new one and strip the laptop down, remove the old cable and replace with the new one.
This may help;
https://www.youtube.com/watch?v=fo5easyIX0Y
Sep 26, 2014 | Toshiba SATELLITE U945-S4140 ULTRABOOK...
Satellite u925t-s2120
first, check the cheap & easy things: hit fn & f4 a few times in case it was set to external video only.
fixed? yay!
no? take a flash light after the computer is on. if it reveals the image there, but it's not glowing and very difficult to see the back light is out. this is caused by either the HV coils or the bulbs going bad. you can get replacements online at sub$100 levels. research online to see if you're comfortable doing it yourself with this model, or a computer shop can do it for you!
Aug 22, 2014 | Toshiba Satellite U925t
Toshiba Satellite Ultrabook U945-ST4N02 Windows 8,
Check with the moniter by connecting the VGA Cable. is there any display on moniter if yes then laptop;s screen faulty otherwise motherboard issue.
Oct 11, 2013 | Computers & Internet
Toshiba satellite pro p100 screen problem
The LCD can be replaced. The part is around $50-$75 I believe. It can be tricky to replace, but if you take your time, you can save money by doing it yourself. The screen sounds cracked or broken, and black & white will not work either.
good luck
Mar 19, 2013 | Toshiba Satellite P100 Series / Satellite...
Toshiba Satellite stuck on Preparing to configure Windows screen?
Unplug, remove battery, leave battery out, plug in, reboot, select Normal boot. post results
Feb 26, 2013 | Toshiba Satellite U925t
Where can I get a guide to replace LCD panel on a toshiba satellite a505-s6973?
Hi klkdaddy1
TOSHIBA SATELLITE A505-S6970 NOTEBOOK LCD PANEL DISASSEMBLY GUIDE
The general LCD Panel Disassembly Guide for Toshiba notebooks like your can be found here:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A355-A355D/replace-LCD-screen-1.htm
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Oct 07, 2011 | Toshiba Satellite A505-S6970 Notebook
Toshiba Satellite a105 s4004
Here, I found this:
Toshiba Satellite A105. How to remove and replace laptop FL inverter and LCD screen.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
Jun 23, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite U925t Logo
231 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
