Question about Homelite Garden
Sprocket drum heating up - Homelite Garden
    New Friend:
  • 3 Answers
Is your chain on too tight or is there some sort of drag on clutch that is making the clutch slip
Posted on Mar 12, 2014
How do i remove sprocket from chainsaw homelite ut10588
The washer needs to removed too as it may have dropped into a thread. Other than that there nothing that shouldn't be anything holding the sprocket drum; unless you have a clutch or needle bearing failure.
Note: only 6 tooth .375 sprocket is available and than it is an aftermarket one. The 8 tooth .325 spocket is no longer available.
Nov 20, 2014 | Homelite Garden
Which way does a rim sprocket go on a Mac Pro 60
The rim will fit onto the splines either way, i normally fit them with the numbers facing the drum.
Feb 11, 2013 | Garden
I need to change the drive sprocket on a 028 av super i am having problem getting the old sprocket off whats the trick
is the chain brake still applied, thus gripping the drum on the sprocket.. Remove the E-clip and take the chain brake off... clutch drum should lift out.
Sep 15, 2012 | Stihl Garden
I have an 18" rear
Perhaps you mean brake disc not sprocket..
no you will have problems mounting the brakes
Feb 06, 2011 | kawasaki KX 125 Motorcycles
MOTOR RUNS, BUT CHAIN DOES NOT MOVE
Hi, poppa530 I will try to help you out. You probably installed the chain so it is not engaging the sprocket. Remove the chain and re-install, but make sure it is engaged on the sprocket located behind the drum where the shoes are that as the RPM goes up engage the drum and turn the chain. I can't think of anything else that could be causing this problem, unless the drum and clutch shoes are not engaging any more. Do you know if the clutch shoes, drum and sprocket have been removed from the crankshaft, and maybe not re-installed properly? Can you turn the chain by hand? If not, something has jammed preventing chain from turning. Have you recently installed a new chain, bar or both? If so, you might not have the right width drive link tang or the right pitch on the chain. If a new bar has been installed the bar groove might not be the right size. You might also check out the sprocket to see if it is bent or damaged. I hope I have helped even a little bit. All the best and good luck. Any questions welcome.
Feb 06, 2011 | Homelite Consumer Products 9.0 Amp, 14 In....
Cant remove rear drums
My friend;
Try this;
  1. There is small sprocket { like gear } inside the bottom side of the drum.
  2. You can reach it by knock small metal in the back plate of the drum system.
  3. Then with a chisel & hammer knock (remove) that small piece of metal.
  4. With Normal slotted { flat } screw driver tray to rotate that sprocket inside the drum but from inside toward the axel .
  5. You can look its picture in the Google image window.
  6. There are two small holes in front of your face in the center of the drum to insert two bolts & by tightening them equally it helps in the removal process.
  7. You can pour very hot water to ease the removal & hammer it with rubber mallet.
This pic like that sprocket inside the drum;
http://www.pocketbikeparts.com/v/vspfiles/photos/FSSP010101-1.jpg
This sprocket keep automatically adjust the brake shows every time they wear.
Try it, & PLZ; let me know if I add any benefits to you.
I hope I add some thing valuable to you.
Regards;
MAR;
soer2@yahoo.com
Nov 09, 2009 | 1993 Ford F250
Need sprocket and drum parts for XL homelite chainsaw ut10656
any place that sell chain saws will have one,take the old one with you to be safe
Aug 28, 2009 | Homelite Garden
I want to replace the sprocket drum
pull the bar cover and bar take a center punch and hammer and knock it loose the threads are counter clockwise
May 28, 2009 | Garden
Poulan Wildthing 18" chainsaw 2375 sprocket/drum replacement
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi tchild,
my name is Dennis Gladx and I can assist you with the problem of getting the sprocket off of the crankshaft of your chainsaw.
To remove the centrifugal clutch and sprocket you unscrew it from the crankshaft and it has a left hand thread. Also a little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance Please rate this solution because I can learn from your rating. Thank you
Nov 08, 2008 | Poulan Garden
Garden Logo
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
