Question about Asko D3232XLSS Stainless Steel Built-in Dishwasher
Asko dishwasher drain pump won't stop even with door open
Timon90
  • 126 Answers
SOURCE: Asko D3350 code F7
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
Posted on Jan 24, 2008
jonniewalker
  • 1031 Answers
SOURCE: Asko door latch stuck
The only way is to pull out the dishwasher ,unhook the latch and then unscrew the door panel.your dishwasher is installed with 2 screws to the underside of your countertop. its tricky but youll have to remove them adjust to leveling legs down this will give you more room to get some head bit in ther to remove the screws if its out then slide the d/w foward ,remove the strike plate door will open then you can get your dishes out first
Posted on Sep 20, 2008
SOURCE: asko d3120 flashing coffee cup
I had to slide the dishwasher forward (undercounter installation)and tip it forward as far as possible. Water leaks onto floor, but then the internal controller seems to reset and the ASKO now works normally again. What kind of idiot would design a control module that does not incorporate a power-off interlock? FAIL FAIL FAIL - Bad, ASKO, Bad. Go to your room.
Posted on Feb 13, 2009
  • 10865 Answers
SOURCE: The pump on my ASKO 1716 dishwasher will not stop
Simple fix. It appears that your anti-flood feature has activated due to water pooling under the tub of the machine. You may be able to remove the water yourself or you may need help. If you want to try to remove it yourself you will need a syringe with a tube attached and you will have to get under the drum. Joe
Posted on Mar 25, 2010
joe_lishman
  • 192 Answers
SOURCE: Asko D3230 dishwasher pump will not turn off, with main switch on
This is a anti flood activation. It is a safety device (polystireen float and micro switch at the base of the washer) that keeps the drain motor running due to water leak / spill detection. Dry the water and rectify the leak (normaly pipe or clamp leak) and this should solve the problem.
Posted on Mar 26, 2010
Asko D3350 code F7
you seem rushed
ok
the problem might not be in your senser or timer but in the pump its self
Sep 14, 2008 | Asko 24 in. D3350 Dishwasher
Water will not drain out but the water pump keeps running even when the door is openned or closed.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 16, 2011 | Asko 24 in. D3120 Dishwasher
Dishwasher runs part way thru cycle then f2 cumes up all lights come on and draim pumps runs all the time even with door open
F2 signifies high water level. Check the drain pump and drain hose, make sure they are not clogged. Check the operation of the water inlet valve.
Feb 23, 2011 | Asko D1776 Built-in Dishwasher
My dishwasher is signalling F2 but there is no water in the machine. When I start the dishwasher, it starts correctly but then very shortly starts the F2 signal. When I open the door, the dishwasher does...
Do you have a user manual for this dishwasher.
F2 is linked to either water intake or drain pump problem. Please confirm what you mean by "dishwasher does not stop". If there is no water inside what is the dishwasher doing when you open the door.
Nov 26, 2010 | Asko D1776 Built-in Dishwasher
I have an ASKO D3250 and it has recently started making a loud noise from the pump area. It starts as soon as the cycle begins and doesn't stop even if you open the door. It seems to stop about 90 seconds...
All power and sounds should stop when any dishwasher door is opened.
Your door switch may be stuck causing it to continue.
The 90 second sound at the beginning of the cycle is the water pump extracting any residual water before taking on clean water for the wash cycle.
Any excessive noise from the drain pump could be debris in the pump. e.g. broken glass.
You can remove the pump and check it for blockage or any foreign object.
Aug 14, 2010 | Asko 24 in. D3250 Built-in Dishwasher
ASKO D1986: Water pump running constantly
Solved by draining water from bottom pan.
Jan 18, 2009 | Asko 24 in. D3350 Dishwasher
Pump is always running on my Asko D3121 even when door is open. the pump works OK when I put water in dishwasher but never stop
check the float switch ... it is under the dishwasher it could be stuck in the up postioin or you can have water under the dishwasher..
Hope it helps....If NOT let me know more about your problem ... I will Help
Nov 16, 2008 | Asko 24 in. D3120 Dishwasher
Dishwasher stuck on "drain"
This is a on going problem with asko and they keep jerking everyone around with this defect. I had a repair person come over and used a turkey baster with a 7" rubber hose attached to the end of the baster. He took off the kick plate and inserted the hose end in the overflow tray and pull about of 12 onces of water from the tray. He is a asko repair facility and says it is a comon problem and has made the repair solution on his own as it is easier then taking the hole dishwaser out and tip it on the side just to drain the water. This has been on going for 3 years and each time i called asko it was like i was the only person having such a problem. I now do this every 3 months and the problem is on going. What a piece of junk. Purchased at Marcellas appliances in Schenectady,NY. They also know how to avoid the problem in fact there repair person left out most of the screws so the next time it would take less time to drain the water. DDDDDont buy ASKO. Michael Foote
Aug 02, 2008 | Dishwashers
Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Aug 29, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Asko D3232XLSS Stainless Steel Built-in Dishwasher Logo
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
