Question about Gant Rugger Camo Printed Mesh Polo in Camo - from GANT by Michael Bastian
Shirts fisheye buttons - Gant Rugger Camo Printed Mesh Polo in Camo - from GANT by Michael Bastian
I have a Nikon D-40 I'm currently using a 55-200
Fisheye is the extreme of a wide angle lens. I think you are not using a fish eye lens, but a fish eye adopter. That is a lens that will "shorten" the focal length of a lens most of the time with 30 % sometimes with 50% when you put it in front of your lens. So you could make a 24 mm lens look or act like a 12 mm.
On your tele lens this only will slightly shorten the 55 mm, but even 50 % of 55 is 27 mm and can't be seen as a fish eye.
I think when you put this on a short lens, the picture you get will be round, like you were using a real fish eye.
Feb 28, 2012 | Nikon Cameras
Will the GV-FE110 Fisheye IP Camera need the Capture Card?
No. None of the IP cameras require a capture card. Instead the included Geovision software can be used to record the video. That's the beauty of Geovision. Good software at no cost when you use their cameras.
Jul 20, 2011 | Geovision Gvfe110 13 H264 Fisheye Ip...
I JUST got a Nikon Cool Pix L22 but no matter what setting I use EVERY picture is blurry. I am an art teacher and understand shutter speed and aperture, I even used a tripod. The pictures are still...
Most likely your fisheye lens attachment is out of alignment. An internal element may have come unscrewed or unglued. The other option (I'm assuming you have already checked this) is that it is incorrectly attached to the camera - check your threads and make sure it wasn't cross threaded and that there are no blockages to the lens attachment being screwed in completely. If the fisheye lens is not in the correct position relative to the CoolPix lens, then the pictures will be blurry.
Nov 21, 2010 | Opteka Full Fisheye Lens for Nikon Coolpix...
How do I get my lomography fisheye to advance?
Turn the thumb wheel located behind the shutter release button until it stops at the next frame.
Note that on your model the MX button (Multiple eXposure) to the left of the thumb wheel often gets stuck and prevents the film from advancing. The button should be firmly to the right when not in use. If the MX system is broken there's nothing you can do as the parts cannot be repaired or replaced. All LOMO and Holga models are extremely cheaply made plastic "toy"cameras and are not designed to last. Most have a maximum design lifespan of ten to twelve rolls of film, the FishEye model is designed to last just half that. It's only in Western countries that these models sell for ridiculously high prices, as an example my Lomo FishEye cost me 48 Hong Kong Dollars (that's just under GBP£4 or just over US$6). Back home in the UK they sell for ten times more.
The above explanation is not meant to be disparaging about your camera, but is just to illustrate that these cameras are really built from the start as disposable cameras which have the added bonus of being reusable a few times so cannot usually be repaired when broken.
Oct 09, 2010 | Lomo Fisheye 35mm Film Camera
When I get my prints developed from my Fisheye 2 camera, all the images are to one side. The fisheye image has a chunk missing from it and appears like a 3/4 circle, with about 1/4 of the print just...
Check the negatives: you should clearly see that the images are complete, although where they've been cut into strips it's possible that the cut may have gone through an image. If there are very few complete circular images, then you have a camera problem and problems are not at all rare on Lomo cameras which are in general of absolutely dreadful quality.
if you can eliminate the camera as the cause, then the fault is with the photographic processing service. The process is mostly automated, and the machine which makes the prints from the negatives expects to find nice regular rectangular images with neat straight unexposed lines between them. Your FishEye 2 produces circular images instead with wide hourglass-shaped unexposed partitions and so it's confused the machine.
If you've used an ultra-budget postal processing service then they might agree to reprint for you but will usually (and entirely fairly) point to a clause along the lines of "at these prices, this service is for regular 35mm prints only". In future always use local processing shops and tell them clearly what to expect as they can manually intervene and ensure that the prints come out correctly.
This should solve your problem, if so please rate my answer.
Feb 23, 2010 | Lomo Fisheye 35mm Film Camera
I just purchased the Zeikos fisheye lense for my 50mm Nikkor lens and when I attach it, it doesn' take fisheye photos - just regular with some distortion around the edges... am I using this incorrectly?...
The 50 mm lens is a full frame lens, and the D80 is a DX camera. This means that the 50mm lens puts an image out that is bigger than what the D80 can "see". The good part of this is that the D80 (and most of the other Nikon DSLR's) use only the image from the center part of an older lens. The bad part is that if you put the fisheye filter on it, the fisheye effect that is mostly seen at the edges of the lens doesn't show up on the D80 sensor. If you could put the fisheye filter on a DX lens, it would give you the full effect.
Sep 24, 2009 | Nikon D80 Digital Camera with 18-135mm...
Like to fit my bronica fisheye p e into nikon f 5 camera
The lens you're refering to is the Fisheye-Zenzanon-PE 30mm, yes? As far as I'm aware no Bronica ETR > Nikon F adaptor has ever been made, and if one was to be it would be rather cumbersome.
You're probably better off selling it and using a Nikon Fisheye-Nikkor 16mm 1:2.8 in its place.
Oct 25, 2008 | Bronica PS Zenzanon (1.4x) (bq1275) Lens...
Gant Rugger Camo Printed Mesh Polo in Camo - from GANT by Michael Bastian Logo
81 people viewed this question
Top Gant Rugger Clothing Experts
treeeee
treeeee
shuyumeng
shuyumeng
Erin Wood
Erin Wood
Are you a Gant Rugger Clothing Expert? Answer questions, earn points and help others
