Cameras Logo
A
Anonymous Posted on Feb 07, 2014
Battery doesn t charge - Optio Pentax Cameras
Engine doesn't crank over, blown fuses and certain things not working?
sound like dead battery.no power to fuses if battery dead use digital voltmeter check battery volts should 12.6 volts if not have battery charged tested.if battery 4 or 5 years old battery could be faulty.
2helpful
Battery doesn't hold charge for more than a week
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
HP Elitebook 2530 Pindicator says battery charging but battery not charging
Could be a back power brick or DC jack yes. Power off the computer and remove the battery. With the battery out plug in just the power brick and turn on the computer. If the computer doesn't power on gently wiggle the plug into the laptop and repeatedly hit the power button if it comes on briefly then off again you dc jack is loose. If it doesn't come on at all then its the power brick. If the laptop comes on gently wiggle the plug into the PC. Powers off while wiggling DC jack.
After jumper not charging charger not suuported
Many new chargers are digital devices that can detect battery issues such as bad cells so it then doesn't give out any current so have battery tested.Many times if a good solid connection via cable boosters and leaving the charging car idling awhile connected up to ur battery doesn't boost the battery it's bec the battery is no good.
Dec 18, 2011 • Cell Phones
I was using my psp while it was charging and the charging light turned off, so i naturally assumed that it was fully charged. But a few minutes later the battery died and it wont charge when i plug it in....
Have you tried to remove the battery and put it back in and try to turn it on. Try removing the battery and putting the charger in and starting the PSP. If it starts, it might be the battery. If it doesn't, it's either the plugin for the charger or the PSP is just dead. If it does start with the charger, try putting the battery back in, if it charges awesome. If it doesn't the battery might be dead.
3helpful
My motoriola defy phone wont charge it has been at 0% charge all morning.
Hello and welcome to FixYa;
Take out battery, clean off the battery and gently clean off the terminals. Put battery back in and try to charge again with your charger. If this doesn't help;
Try another charger to the phone such as a car charger if you have one. If the battery still will not charge;
you may need to get another battery. I suggest you go into your local service provider first, have them use one of their spare batteries that fit into your phone model and see if the battery will start charging.
If it doesn't, you need to have your phone itself looked at instead of the battery.
Try these steps before you spend money on replacing parts needlessly.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
May 30, 2011 • Cell Phones
2answers
RECHARGABLE BATYERY DOESN´T CHARGE
you probably will have to go and buy a whole new one. theses kind of batteries only last about 1 year.
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
