Question about NEC Lands Phones
How to change a contact preset on nec phone - NEC Lands Phones
Need access to voicemail on NEC DT300 series, and reset password. Previous employee held this position & no code was left behind.
you may not be able to get to the VM. You may have to reset the system and start over if the PW is not avaialble. I cannot find a way to reset only the VM password and retain the VM. You may want to contact NEC directly in case they have a way that isnt in the manual. The manual seem to indicate you need to reset the entire system. NEC DT300 Series User Manual To Change Security Password
Apr 02, 2018 | NEC Lands Phones
How do i make the nec electra professional phone not ring
I think you have change its internal setting so reset your phone again so its again setup your phone and your problem has been removed like phone ring.
Nec sv8100 IPK DTerm phones Inlinecom
Aug 11, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
How to access voice mail or record greeting on NEC DTU 8D-2 Corded Phone
If I'm not mistaking, you need a NEC PBX to work with that phone. In which case you need to contact your telecom helpdesk to find out what the voicemail phone number is so you can set that up.
I could be wrong about the phone
Jun 15, 2012 | NEC DTU 8D-2 Corded Phone
Need change the time on my nec phone d term 80
To reset time NEC Dterm 80
Press speaker and enter 728 on keypad.
Then enter correct time in 24 hour format...Ex. 2:56 = 1456
Then press speaker again...
Note: On my system this changes time on all phones on the system
Dec 15, 2010 | NEC Dterm DTP 16D-1 Corded Phone
NEC Electra Elite
you need to access program mode. Did you contact your nec vendor? ldtsnj.com
Apr 24, 2008 | NEC Electra Elite 32D-1 Corded Phone
Adding/Changing Name to NEC multi-line phone
On an NEC Elite you must enter system programming to change the name of the extensions. Unless you have a PC connection to the system this is somewhat complicated. If you would like me to step you through the system programming, please contact me @ 850-326-0394.
May 21, 2007 | NEC Electra Elite 32D-1 Corded Phone
Changing the time on my phone
Here is a link to the support page at NEC regarding this year's DST time change: http://www.neccare.com/kb/S7YGL52
Mar 12, 2007 | NEC DTU 16-1 Corded Phone
Lands Phones Logo
13 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
