Question about Napoleon NHPS12 Air Conditioner
How to clean the coil on my goodweather air conditioner
Clean the cpn14xc9
I think you are asking how to clean the coils on this unit. I would not advise taking it apart unless you really know what you are doing. If the coils are dirty just buy a good can of coil cleaner spray. Let sit for a while and brush the coils with a soft bristle brush. Tooth brush works good. Don't be forceful and bend the fins, it will restrict the air flow and reduce the efficiency of the unit. After you clean it with the spray and brush spray with warm water to remove the remaining coil cleaner from the coils. You may need to repeat this process more than once. Good luck, hope I helped you.
Sep 28, 2014 | Haier CPN14XC9 14000 BTU Portable Air...
Why is my air conditioner blowing white smoke?
Smoke or frost? More than likely frost make sure the air filter is clean and evaporator coil is clean this is a sign of low air flow across evap coil or turn fan speed up.
Aug 06, 2014 | Dometic Rooftop RV Air Conditioner
Duo therm airconditioner cleaning coil
spray coil cleaner on surface of coil with fan running allow it to pull cleaner in coil then rinse
Aug 23, 2012 | Dometic Rooftop RV Air Conditioner
My air conditioner cooling coils get frozen approx\.after 2 hrs of running i have showed it to the service boy they first serviced filled gas and even changed the fan motor. but still the problem...
Hello, the evap coil will freeze from either low airflow or low charge. I would clean the coils, check air filter and replace or clean if dirty. If you have a thermometer measure the air entering the ac and the air leaving the ac, the differance should be 15-20 degrees, measure this after cleaning the coils. If it still is below 15 degrees the unit is underchraged.
May 26, 2011 | LG Heat cool Window Air Conditioner
I purchased a new air conditioning system last year. After only 8 months of air conditioning, the coils need cleaning. My previous air condition never needed it's coils cleaned. Does this sound normal for...
Cleaning the coils with in the first year no. Rec to have it service once a year though. Cleaning them every other year. Look at them if you take a flash light and can see light thought the other side they should be good. You can also take your garden hose and clean them your self. Just dont get to close that you bend the fins.
Aug 31, 2010 | American Standard WCZ036F Air Conditioner
Dirty coil
You can buy some coil cleaner at a heating and air supply or maybe Lowe's Home Improvement. The coil needs to be clean for the unit to work properly.
Jul 16, 2010 | GE AJCQ08ACB Air Conditioner
My samsung portable window air conditioner is 4 years old and it does not blow cold air. Like at 66 degrees it is not that cold why
It is either low on freon,or,the unit needs to be removed,and cleaned,especially the coils,the condenser coils,and the evaporator coils,be careful not to bend fins on coils,use a water hose,and clean the inside of the unit out,clean off coils real good,see if this is the problem,it always helps.If this was helpful,please rate,and thank you,
Jun 28, 2010 | Samsung AW1203B Air Conditioner
On my 1999 camper trailer when I turn on the dc powered lights while the airconditioning is running the compressor will kick off. If you wait 3 minutes it will come back on and continue to work fine until...
Welcome to FixYa
Not enough cooling complaints are due to air flow issues, and not lack of “Freon.RV air conditioner- come from the factory- are hermetically sealed.The first basic area is the air filter. In summer, using the RV and air conditioner around the clock, the filter should be checked weekly and cleaned as needed. RV air conditioners use either a foam type filter or a fine mesh, both of which can be rinsed in water and reused.keep the filter(s) clean.Few years latter even the best filter will let enough dirt past to coat the evaporator coils, though, so they need to be cleaned. If the coils are not too dirty, and if the installation leaves enough room to access the coils.Once the cover is off, you can see the evaporator coil -Clean Coils too...
Thanks for Contacting FixYa....
Jun 10, 2010 | Dometic Rooftop RV Air Conditioner
Can you please give me 5 problems and 5 solutions on condenser for a samsung air conditioner
Most of the problems that arise with a window A.C. unit are from the "front", and "rear" coils ,or the filter at front are dirty. When the unit is on,the air is sucked in at both coils,and should be cleaned yearly. The front coil,and the filter are easy to clean,but the rear coil can be difficult.After checking the front, with the on cool, go outside and put your hand at the rear coil and feel if there is warm air blowing out.If not, your rear coil is probably clogged.Note:Do Not use high pressure hose to clean the coils,please.
Feb 17, 2010 | Samsung AW0603B Air Conditioner
Fan is not blowing air at its full speed
Check filer. Possible stopped up evap coil. You possibly clean this yourself. Use a stool bruch to clean coils. Does not bend fins. If this does not work call service tech to chemically clean coil.
Jun 14, 2009 | Mastercool 67471 Evaporative Cooler Air...
Napoleon NHPS12 Air Conditioner Logo
35 people viewed this question
Top Napoleon Heating & Cooling Experts
Paul Carew
Bill Long
Jim Goldsmith
Jim Goldsmith
Are you a Napoleon Heating and Cooling Expert? Answer questions, earn points and help others
