Question about Kenmore Washing Machines
No water drain on drain/spin cycle
Machine will not drain water on final spin. drum turns. what buttons do I press to get diagnostic codes and where do I find sheet to explain codes
    Prodigy:
    An expert who has answered 500 questions.
  • Kenmore Expert
  • 517 Answers
Clean the filter
check the pipes to the pump
Posted on Feb 07, 2014
SOURCE: Will fill with water but during rinse and spins it won't drain.
I fixed it on my own. By taking off the suction hose and spinning the fan inside it apparently dislodged something and is working now. Hopefully the problem won't come back, I was unable to find the foreign object.
Posted on Oct 23, 2006
SOURCE: Washer will not Spin during SPIN CYCLES
IT IS THE DOOR LOCK ASSEMBLY, COST AROUND $50.00 WHICH IS FAR BETTER THAN $300.00, WHAT A SERVICE REPAIR PERSON WILL CHARGE YOU. YEA IT'S THE CRAZIEST THING IMAGINABLE, THE DOOR LOCK ASSEMBLY BEING THE CAUSE FOR IT TO NOT SPIN ALL THE WATER OUT. I FIXED MINE MYSELF, HAD TO TAKE IT ALL APART VERY CAREFULLY, BUT I SAVED MYSELF $250.00. YOU CAN GET THE PART ONLINE OR GO TO NEAREST APPLIANCE PARTS STORE IN YOUR CITY. ASK FOR DOOR LOCK ASSEMBLY. THEY WILL KNOW EXACTLY WHAT YOU'RE TALKING ABOUT BECAUSE IT IS A VERY COMMON, I REPEAT VERY COMMON PROBLEM WITH THIS BRAND OF WASHING MACHINE.
Posted on Aug 12, 2008
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
barkencoa
  • 3463 Answers
SOURCE: The water will not drain from my drum. The spin
Check the filter, which is located at the bottom front right of washer behind a flap or drop down cover.
Unscrew anti-clockwise to remove and clean.
Please rate my solution.
Thankyou.
Posted on Jan 28, 2010
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Fisher paykel GWL10 doesn't drain Previous problem
Easy to check the pump but you need to have a bucket handy. Tilt washer backward pump will be on the right side. Remove and clean. Watch out for the water!
Sep 26, 2013 | Washing Machines
Washer won't drain
DIAGNOSTIC MODE
To enter diagnostic mode follow the steps below.
1. Turn the power on at the power point but off at the machine.
2. Press and hold WASH TEMPERATURE SETTING DOWN and then press POWER until the
machine gives 2 short beeps and lights up.
3. Release the buttons after the beeps as the beeps indicate diagnostic mode has been entered.
4.1 Last Fault Data
When in diagnostic mode the last fault can be found by pressing the SPIN SPEED UP or DOWN
buttons until the HOLD and SLOW lights are illuminated. Binary can then be read from the wash
progress lights.
4.2 Drain Pump Test
MW Washer
When in diagnostic mode press SMART TOUCH CYCLES to activate the drain pump. To
deactivate the pump, press SMART TOUCH CYCLES again.
GW Washer
When in diagnostic mode press REGULAR to activate the drain pump. To deactivate the pump,
press REGULAR again.
4.3 Water Valve Test
The water valves can be activated in diagnostic mode by pushing WASH TEMPERATURE SETTING UP to activate the Hot Valve and WASH TEMPERATURE SETTING DOWN to activate
the Cold valve as with previous models.
Pressing each button once will activate the valve. To de-activate valve press the same button
again. This is also good to use when installing machines as it takes the shock out of the fittings
and seals and allows checking for leaks on the inlet hoses, both machine end and tap or super-tub
end.
Caution: Do not leave the machine unattended when either or both valves are operating
May 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
Duet whirpool washing machine stop and DLF sign appear
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle.
After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause].
This will remove excess soap suds and light residue from the drum.
Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Shane
Apr 03, 2011 | Washing Machines
Have Error Code E20 - won't drain. How do I approach?
The diagnostic test is used to check individual component function only. TO START THE TEST: • Turn the Program Knob to the start position, Spin Only. • Press Start/Pause to start the cycle and save it. • Press Cancel to stop the cycle and turn off the LEDs. • Press Cancel again to turn on the LEDs. • Within 5 seconds, press and hold the Options and Start/Pause buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened.When the door is opened, the drum light should turn on. 6. Turn the program knob (5) clicks from the start position. The washer will fill and tumble. Once tumbling has started, the Boost Heater (if so equipped) will turn on. 7. Turn the program knob (6) clicks from the start position. The drain pump & door lock solenoid will activate and the washer will operate in high spin. 8. Turn the program knob (7) clicks from the start position. The control will signal the last error code. Exiting Diagnostic Mode There are two options for exiting theDiagnosticTestmode and returning the washer to normal operation: a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR b) Turn the program knob clockwise 2 or 3 clicks after the start position. Press Options and Start/Pause buttons together for a few seconds until wash cycle LEDs appear.
Dec 26, 2010 | Frigidaire Affinity ATF7000E Front Load...
Won't spin
Close the door firmly and make sure the machine is turned on. Press and hold the Chime and Extra Rinse keys until the control beeps to enter Service Mode. All indicator lights will turn off except the "Door Lock' indicator signifying the door is locked.
Press the Rinse & Spin key then rotate the cycle selector knob in either direction to display the most recent error codes if there's any. Press and hold the cycle selector to display the number of cycles since the error occurred. List down at least five most recent codes and post it here for us to determine what the problem could be. Press and hold the Delay and Chime keys for three seconds to clear the list. Press the Rinse & Spin key again to exit diagnostic codes list.
Press the Spin Only key while in the Service Mode to begin the Board Input Test. Set the rotary cycle selector to Super Wash then press it to display the position of the door switch. "OP" will be displayed if the door switch is open or "CL" if it is close. Replace the door lock/switch assembly (part #34001265) when "OP" is displayed even the door is close. Press the Spin Only key again to exit the Board Input Test.
Press the Spin Speed key while in the Service Mode to begin the Board Output Test. If water is present in the tub, set the rotary cycle selector to Quick Wash then press it to turn on the drain pump and drain the water. Press the rotary cycle selector again when the water is fully drained to turn off the drain pump.
Press the Delay button to turn on the motor and the Delay indicator light. The machine should tumble clockwise then counterclockwise with 5 second durations each and 2 second intervals. Press the Spin Speed key again to exit the Board Output Test.
Press Off or press and hold Chime and Extra Rinse keys for three seconds to exit Service Mode. Unplugging the washer will also exit Service Mode.
Perform the tests above and let us know the results for us to determine the cause of the problem or the necessary action to undertake and give you the specific and detailed instructions on how to fix it.
Mar 03, 2010 | Maytag Neptune MAH9700 Front Load Washer
Ran HE3 without Water, it's now locked up
Unplug the washer and wait 30 minutes, sometimes the next morning for the machine to reset. Make sure the water is on because it while find multiple failures and lock up, Secondly you can try putting the machine into diagnostic cycle to ensure it is ok. Press drain/spin and select no spin for spin speed finally press prewash quickly two or three times and let it run, any flashing codes?, hit prewash again after writing the codes down.
Jun 15, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Final spin cycle for kenmore 417.40042990
This is an interesting problem. How long does it have to sit before you can get it to spin? Can you let it go through the cycle and then immediatly put it into spin and it work? This machine will not spin until the pressure switch senses the water has drained. So you could have a slow drain, a clogged pressure hose, or faulty switch. A clogged hose or faulty switch would usually cause it to fill with more water than normal also. A slow drain is most likely, check the drain hose when it is draining and see if it is putting out a strong flow or just slowly draining. I think you will find it to be slow. This will cause it to take up all or most of the spin time trying to drain the water. If it is slow draining, check the pump for a sock or some obstruction. If the drain is good, remove the top and remove the rubber hose from the pressure hose and blow through it. You should be able to blow through it easily. A restricted pressure hose will cause the machine to think it has water in it after it has drained.
Oct 05, 2007 | Washing Machines
Washing Machines Logo
20 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
