Question about ClearOne Xap 800 Digital Mic Mixer
I have a ClearOne XAP TH2 connected to a XAP 800 I just started to get feedback and noise when placing a call everything else works. any thoughts
Konica minolta bizhub 500 has malfunction : c-3902. i tried powering off and unplugging...no help... now what?
This is a fusing unit problem. Specifically TH@ also known as Thermister 2 is not detecting tempurature the same as TH1. Here is the quote directly from the service manual:
Inferior contact of the thermistor
/2 (TH2)
While in the warm-up condition,
when the thermistor /1 (TH1)
detection temperature gets to the
Ready temperature before the
TH2 detection temperature, the
TH2 detection temperature does
not get to the Ready temperature
a specified period of time after
the TH1 detection temperature
got to the Ready temperature.
Basically what you are going to need is a service tech to come out and replace TH2.
Good Luck and Thank You for using Fixya.
Aug 31, 2010 | Office Equipment & Supplies
The dryer turns on and runs, but it is not heating up...
The problem is either the Safety Thermostat TH2, High-Limit Thermostat TH3, or the Heating Element itself. Here's what you should do find which among is the culprit.
Use a putty knife blade or similar tool to push and release the clips holding the top panel to the front panel. Insert the putty knife between the top panel and the front panel as shown at about 2 and 3/4 inches from the edges then push in until the clips are released then lift the top panel off.
Open the door then remove the two screws at the bottom of the door opening as shown.
Remove the two screws from the upper side of the front panel then pull the panel out and disconnect the Door Switch connector.
Once the front panel is removed, you'll see the Heater Box at the bottom right hand side of the cabinet. Remove the cover and you'll see three sets of the terminals on the left side of the Heater Box. The set of three terminals is the Heating Element, the middle set is the Safety Thermostat TH2, while last set is High-Limit Thermostat TH3.
Using a multimeter, set to the lowest Ohm scale (R X 1), check the continuity of the Safety Thermostat TH2 and High-Limit Thermostat TH3 then the resistance between the middle terminal of the Heating Element and the other two terminals.
The Safety Thermostat TH2 and the High-Limit Thermostat TH3 are both normally closed and any discontinuity (open circuit) found indicates that the component has failed. It is necessary to replace both the Safety Thermostat TH2 and the High-Limit Thermostat TH3 if one of them has failed. The Safety Thermostat TH2 is likely to fail as a result of the High-Limit Thermostat TH3 failure.
The normal resistance between the middle terminal (2) and the upper terminal (1) is 18 ohms to 22 ohms while between the middle terminal (2) and the lower terminal (3) is 9 ohms to 11 ohms. Replace the Heating Element if an infinite resistance (open circuit)reading is obtained in any the measurements.
You may take the Heating Element out then thoroughly check it visually for any obvious coil discontinuity if you don't have a the meter to check the continuity of Safety Thermostat TH2 and the High-Limit Thermostat TH3 and the resistance of the Heating Element. It will be obvious if the Heating Element has a broken coil.
The problem lies in either of the Safety Thermostat TH2 or the High-Limit Thermostat TH3 if the Heating Element coils is intact. Bypass both the Safety Thermostat TH2 and the High-Limit Thermostat TH3 then reconnect the Door Switch connector. Run the dryer and it should heat by now to indicate that either the Safety Thermostat TH2 or the High-Limit Thermostat TH3. Otherwise, it is a totally different story. Please let us know if that is the case.
Warning! Do not use the dryer with the Safety Thermostat TH2 and the High-Limit Thermostat TH3 bypassed due to fire hazards.
Aug 11, 2010 | LG DLE2532W Electric Dryer
Need the Avaya phone type to set up the ClearOne Max Ex Conference phone
Wha???? This is an analog conference phone. Plug it into an analog phone port....
Not sure what your question is.
Oct 16, 2009 | ClearOne Communications ClearOne Max EX...
2000 400 Explorer engine won't shut off
Make sure the black wire coming from the CDI is connected tightly/clean.
May 23, 2009 | Interactive Toy Concepts Polaris Sportsman...
The powder detergent is not being released into wash. Yes, it is being poured into the proper place. The water is only coming out over the fabric softener and bleach section.
are both valves working? hot and cold water on and correctly connected. when you start cycle you hear clicks from the dispenser area, any extra abnormal noise or absense of from here? may want to take top cover off to check operation.
if both valves are working then water is directed to different compartments by a diverter in the dispenser, the servo motor is mounted on top and has 2 connections. a click is heard at each detent where a feedback switch is tripped. there are 4 positions. it normally makes a full round at start before stopping in place.
Apr 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Shuts off but everything else works
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Nov 08, 2008 | Panasonic NN-S542 Microwave Oven
Microphone problem Vista Home Premium
DOWNLOAD THIS BOOK FOR FREE AND SOLVE ANY PC HARDWARE, SOFTWARE OR OPERATING SYSTEM PROBLEMS.
DOWNLOAD NOW......
Download mirror 1 ( Hosted by HostingDude)
Download mirror 2 ( Hosted by Softpedia )
Download mirror 3 ( Hosted by Soft32 )
Download mirror 4 ( Hosted by fileflyer )
Download mirror 5 ( Hosted by Rapid Share
364
Oct 12, 2008 | Microsoft Windows Vista Home Premium with...
Humming noise/ feedback
your mixer should be grounded by the power cord, and the decks have a seperate ground wire which connects, usually on a screw terminal, to the mixer, which provides the ground for the decks. I would try the headshells to make sure they are tight and connected correctly also make sure the power socket on the wall is earthed properly.
Feb 19, 2008 | Stanton STR8-150 Turntable
ClearOne Xap 800 Digital Mic Mixer Logo
19 people viewed this question
Top ClearOne Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a ClearOne Audio Player and Recorder Expert? Answer questions, earn points and help others
