Conext 900 avr - How do I change the battery fuse in this thing. I can't find it. There are three fuses soldered in place which appear not be blown. I can't see the middle fuse. Is there another "Battery Fuse" that I should be able to see????
  • 556 Answers
SOURCE: Sylvania (ProView) CL2072b Circuit board fuse
normally it is
3AMP/250VOLTS.
good luck.
Posted on Oct 12, 2007
tech240
  • 169 Answers
SOURCE: PCB Fault?
dc power from batteries is switched (inverted) by semi conductors. this involves switching on and off the dc supply buss to create an alternating voltage. if the devices are blown then as soon as the unit is connected to dc the dc shorts outs and blows the dc fuse, this could be your problem. unless you can get a good power electronics tech to fix this for a reasonable price you should recycle this and buy a new one. in some ups systems the dc from the batteries go via a dc up converter which increases the dc voltage to a level the inverter will run at. all this circuitry is difficult to work on and almost all of it is controlled by logic circuits and software.
one last word
batteries are always live and are very dangerous, remove all metal objects watches,rings etc before handling, wear eye protection and take account of all instructions supplied .
with batteries if in doubt the don't work with them.
Posted on Apr 23, 2008
emissionwiz
  • 79851 Answers
SOURCE: shuts off while driving. no fuel pressure. pcm fuse blows/ fuel pump relay inserted.
Sounds like the fuel pump is shorted.
Posted on Nov 03, 2008
TLRogue
  • 99 Answers
SOURCE: 97 audi a4 no power/battery fuse?
Sounds like either the battery leads are on the wrong way round, or the starter main cable is touching something and shorting to earth. Retrace your steps and check your connection locations.
Either that or its a dead short through the starter. Remove main cable from back of starter and tape up incase of short. then reconnect battery. If ok now then your looking at starter motor.
TL
Posted on Jan 22, 2009
edwardjohn
SOURCE: Did my Conext 900AVR die or is it just a battery?
I took my Conext CNB900 to Batteries Plus and they put in a new battery and checked the unit and found that the new battery solved the problem.
Wilson in Houston
Posted on Jan 23, 2009
Speaker fuse
The problem is your system not the fuses which merely trip to tell you overload. So we have to find what is causing the over load.
Nov 16, 2013 | Harman Kardon Audio Players & Recorders
No indicator lights after replacing battery
I have one question, have you connect the battery terminal correctly the first time you install your new batteries? If not, it might be your battery fuse is blown during the process :) check your UPS battery fuse.
Dec 30, 2012 | APC Conext 900VA (cnb900) UPS System
2004 Saab 93t will not crank. Charged battery but still will not start. Is there a fuse that could be blown?
did you change you battery? I got a saab 9-3 and the same thing happen for three times even after I changed the battery, after placed the battery, it just work for a while but a week later it just gone dead
Aug 04, 2012 | 2004 Saab 9-3
Replaced conext ups cnb325 battery but power indicator light does not come on.
There is a solder problem on some units. Remove the battery and the 4 screws, tilt the lower panel away, and let the circuit board drop out onto the workbench. WATCH FOR THE TRANSFORMER, it is not fastened. Inspect for a loose solder connection, and if you find it, re-flow the solder. Re-assemble and plug into the AC current to charge the battery.
Jun 01, 2012 | APC Conext UPS System
The fuse on my circuit board for my kenmore refrigerator is blown. It appears to be soldered on. Can I replace just the fuse?
Yes you can solder a new one in place just have to be careful, you can also, if you have room, solder in a new holder in case it blows again it will be easy to repl.
Feb 27, 2010 | Refrigerators
My Belkin 550VA don't start up The model is F6C550-AVR
this may happen because of gone battery without battery it will not comes on mains also so directly change battery before that you also check the fuse if blown replace it with same ratings problem will be solved
Feb 24, 2010 | Belkin (F6C550-AVR) (DBF6C550AVR) UPS...
Conext 900 AVR. Won't turn on, no lights. Power still out of the surge protected outlets, but no power out of the battery protected outlets. Opened it up, don't see anything damaged, using a meter checked...
I had the same model/symptoms (no lights on the front panel). I had a compatible, though smaller, battery from a Verizon Fios backup unit, and I tried that in the UPS--it worked. That confirmed that I just needed a new battery.
Feb 03, 2010 | APC Conext 900VA (cnb900) UPS System
A piece of metal fell of my phone charger into the cig lighter and caused a spark. I pulled over and the radio, odometer and lights would not work. Then after the car was put in park, i could not get it...
check for blown fuses in fuse boxes under dash on left & under hood.check for a blown 'fusible link' a wire leading from battery + terminal to the electrical box near the battery.a fusible link is a wire designed to 'melt' in case of a short.outside of link will appear blistered,and a new one needs to be soldered in it's place.
Oct 13, 2009 | 2003 Toyota Corolla
My generator starts and runs great, It is not
  1. Check for any blown fuse and replace. It can be traced directly from the output lines.
  2. Check field excitation. The field excitation is supplied by the battery to the excitation coil through a pair of carbon brushes. If the brushes are worn out, no excitation field is supplied and no output is generated. Replace carbon brush if found worn-out.
  3. Use an analog multitester to check the continuity of the carbon brush and the field coil.
Sep 24, 2009 | Northstar Generator 18 Hp, 10,000 Watt,...
Wilson in Houston
Jan 10, 2009 | APC Conext 900VA (cnb900) UPS System
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
