Question about HEALTHRIDER Exercise & Fitness
Replace computer board - HEALTHRIDER Exercise & Fitness
Is a Bernina 430 worth fixing if the circuit board goes bad
Ooooh, that's a tough question. Circuit boards (computer boards, in general) could be costly to replace. However, a computerized machine will most likely, at some point in its life, require board replacement. It just depends how much you like the machine and what you are willing to spend. This model series was discontinued some years ago and replaced with bigger/better?/costlier machines. Some people are less attracted to the 400 series because it has to be connected to a computer to do embroidery. Of course, there is always the possibility that when you replace one board, another may go bad. Such is life with most things computer. If a donor machine could be found with a good board, the cost may not be as much as trying to find a new board or going through Bernina. You can check what it would cost to have a Bernina dealer fix it for you. On the other hand, if you or someone you know is very computer-savvy, well, you know. Just remember, even if you replace it with another computerized machine, you could be facing the same decision in the future.
Jul 22, 2017 | Bernina Sewing Machines
Manufacturer of Compaq Evo Motherboard
open it up and the mother board manufacturer will be printed on the board
any mother board can be used as a replacement and if it needs replacing update it so that a later chip can be used
it is cheaper to replace the mother board , power supply , memory, chip than to buy a new computer
and hard drives are now solid state and do not have any spinning bits to fail
talk with a computer repair shop and get ideas as to how to proceed
you will probably find that with a rebuild you will save at least 25% off the price of a new store model pc and get a better unit to boot
Sep 16, 2016 | Compaq evo Computers & Internet
I have a1997 grand cherokee laredo with the phantom electrical problem. back firing, stalling,etc. I replaced the starter coil,spark plugs,plugs,plug wires,distributor cap and pickup plate,rotor,rotor...
Check under the hood the fuse box with the feed from the battery gets corroded and works intermittently clean main wires going in and replace the screws holding the wires 1/2 to 3/4 inch ones for better contact
Sep 02, 2011 | 1997 Jeep Grand Cherokee
FPD 2485W .I replaced the bad capaitors in the inverter board, I hear the sound but can not see the gateway logo. I hook it up to the computer a d I do not see any video. Replace the inverter board, power...
Sounds like you've replaced everything but the backlight itself!
If you have another working unit, connect this LCD panel to the working unit and see if it works. If it's still dark, you need to replace the FL tube (backlight(s) ).
Jul 31, 2011 | Gateway FPD1950
Board has all lights are red, fan is running but not as fast as it used to, lcd light on front of computer not working, no video showing up either....this board is only a few weeks old running a triple...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 12, 2011 | Biostar Motherboard TA880GB+ AMD AM3...
Brand new electrolux range oven wont work, all that shows on display is F15
F15 means : signal lost between oven relay board & EOC(main computer board)
1. Test the harness and connections from EOC connector P16 to oven relay board J2.
2. Replace the oven relay board.
3. Replace the EOC.1. Test the harness and connections from EOC connector P16 to oven relay board J2.
3. Replace the EOC.
Hope this help. good luck to you.
Feb 07, 2011 | Vacuums
Computer screen has experienced a white out
The problem looks like the picture board on you monitor is malfunctioning or let me put it right, the picture board on your monitor is bad that is why you have a blank screen on the monitor, i suggest you replace the picture board on your monitor in other to get it to display.
Replacing the picture board on your monitor will solve the blank screen problem.
Take care.
Jun 30, 2010 | Soyo 19" LCD Flat Panel Monitor
My oven locked and I cannot open it nore turn off the lock. The temperature went down and it's been locked throughout the whole day does anyone know whow to fix the problem?
Unplug the power from the OVEN for 24 hours and let the remaining voltage in the circuit board REBOOT the computer.
It should work fine then, or you will need to replace the computer board. It is an easy fix. Replace the Auto Lock Switch too, just to be safe if it was the item that toasted the computer board.
Good luck,
Jim
Dec 21, 2009 | Ovens
Ac charger will not work when computer is on. It will recharge the battery when computer is off. Have replaced the charger and continue to have same problem with all ac chargers.
Tray and remove the battery from the system, leave the system plugged in with the battery out. Does the system boot? If yes, then the system board has enought power to turn the computer on, your board is most likley fine. however that may not be the case and it could be the board I would look at replacing the battery before you replace the board.
Also try and use the power adaptor that game with the unit, this will help ensure that your system will not get to much volts and fry a cap on the board.
Hope this helps.
Apr 18, 2009 | Compaq Presario R3000 Notebook
Working on a 50 fryer
Ok, follow these direction CAREFULLY!
1. UNPLUG THE CENTER JACK of the pcb, that leads to the computer board! LEAVE THE GROUND WIRE ON THE BOARD!!!
2 REPLACE THE FUSE. Both lights on the pcb should light up, that give you the 12 volt line, AND THE 24 VOLT LINE. If they are both lit, stay lit, and don't blow the fuse, then try plugging in the computer again ENSURING THE GROUND IS GOOD FIRST ON THE COMPUTER/TOUCHPAD!!!!!!!
3 If suddenly the fuse blows when you plug in the grounded keyboard cable back into the printed circuit board, or if one of the two lights on the printed circuit suddenly goes dim when the keyboard is plugged in, YOUR NAME JUST BECAME JESUS AND TODAY IS GOOD FRIDAY! Your computer and touchpad is defective and that is going to cost you BIG MONEY!
Dec 27, 2008 | Frymaster Dean MJH50-SD Deep Fryer
Exercise & Fitness Logo
12 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
