Question about Samsung Cell Phones
My gmail account does not connect - Samsung Cell Phones
How to configure gmail SMTP setting for outgoing server?
Process to configure gmail SMTP setting for outgoing server
Gmail provides email services to user.It is used for sending and receiving mail.It is freely used by users.It is developed by Google.If you create an account an G mail then you can directly open your Google account there is o need to create another account. It provides unlimited space to user. For some Business application Gmail is used as paid .Gmail is used as open source.
When you use Gmail then you need to check that your server is connected to Gmail or not.You should know that Gmail SMTP server is used for sending email from your Gmail account. SMTP is Simple Mail Transfer Protocol ,it is used for every email account but it is not same for all the accounts.so for Gmail Account you need to configure Gmail SMTP settings then you need to follow these steps:
First you need to go in the Email client software then you have to go in the outgoing mail
first you need to check that your Gmail SMTP server Address that should be SMTP.gmail.com.
Then you have to enter your Gmail SMTP user name ,your SMTP user name should be same as your Gmail address.
Then You have to enter SMTP Gmail password,it will be your Gmail password.
Now you have to enter Gmail SMTP port number for TLS and secure socket layer connection.
Then you have to select "Use SMTP authentication".
Then you have to click on YES if if you see that Gmail SMTP TLS/SSL required.
Then your SMTP server will be set to your Gmail client.
You can easily configure your SMTP Gmail Setting with the use of above steps but if still you are not able to configure your SMTP settings then you can contact Gmail Technical Support for any query .They will provide you best solution.
GET INSTANT SUPPORT FOR YOUR GMAIL ISSUES NOW
Jun 15, 2017 | Computers & Internet
Tip
Using Gmail as your Universal Inbox
Nowadays most people have more than one email account. If one of yours is a Gmail account, you can use it as your primary inbox to check all your POP3 accounts in your Gmail browser window. But do remember that you can check only other POP3 accounts only. You won’t be able to check Yahoo mail, Windows Live Hotmail, or other such web mail accounts. Also, not all POP3 servers work with Gmail.
Here is what you need to do. Open your Gmail account and click Settings-Accounts. In the ‘Get mail from other accounts‘ section, click Add another mail account. Enter the email address of the account you want to add, and click Next Step.
Enter your username, password and POP3 server. If you want to continue to access the account through a mail client or through the ISP’s own Web interface, in addition to picking up and sending mail in your Gmail account, check Leave a copy of retrieved message on the server. This allows you to read the mail in Gmail, but the mail will remain on the ISP’s server so that you can download it with your standard mail program or read it through the account’s own Web interface. On the other hand, if you plan on accessing the mail for the address only through your Gmail account, you can leave the box unchecked.
Next, check Always use a secure connection (SSL) when retrieving mail to keep mail snoops at bay. In some instances a POP3 account may not work with an SSL connection: if that is the case, you will have to leave this box unchecked.
If you want all of your incoming messages from the account to carry a label, such as the name of the account, select Label incoming messages. In Gmail, a label works much as a folder does. You can view all mail that carries the same label by clicking the label. Gmail automatically creates a label for the address of the new account. You can select a different label or create a new one by choosing the appropriate entry from the drop-down list. Another option is to have messages bypass your inbox and go straight to your Gmail archive. This would be a good choice if you want to use Gmail primarily for searching through mail. When you’ve made all your selections, click Add Account.
You can compose mail in Gmail and have it appear to the recipient as if it were from the account you just added. When a message appears asking whether you want to create a custom From address, click Yes and follow the instructions.
Gmail will check your account, and any mail sent to either address will appear in your Gmail inbox. To stop Gmail from checking the mail, click Settings-Accounts and choose delete next to the account.
on Mar 20, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
I want to add this account to this computer without connecting accounts
You won't be connecting the accounts, you will only be adding a different account to the same gmail browser. When you get on gmail from the same computer all of the accounts that have been accessed from that same computer will all link to the same page. However, they will still all be separate accounts. When logging in you will still have to provide a password for which ever account you're logging into.
Click "sign in with a different account" and you will be prompted to put in the different gmail, and password.
Mar 11, 2016 | gmail.com
How do I check my mail from gmail .com
If it's an android phone, Tap your Gmail App Icon. Your phone is usually connected to your gmail account. If you have a different account goto Settings, Account, Add. Then add the Gmail account you wish to use.
Oct 28, 2014 | Cell Phones
Why will google not send my emails from gmail?
  1. Check that your device is connected to the Internet by opening Safari and loading a webpage, such as google.com. If you cannot connect to the Internet, try the steps in this article.
  2. If you have other email accounts on the device, check if those accounts can send and receive email.
  3. If the issue is isolated only to the affected Gmail account, visit this website:https://www.google.com/accounts/DisplayUnlockCaptcha.
    Complete the form to unlock the account.
  4. If the issue persists, follow this Google support article.
  5. Once the account has been unlocked, or the correct password entered, check that the issue is resolved. If not, remove the affected Gmail account from the device and add it to the device again: Settings > Mail, Contacts and Calendars > Add Account > Gmail.
Jun 14, 2014 | Apple iPhone 5c
I have a gmail account I need a second one for business. How do I set it up
This page will show you a few ways you can login to gmail with multiple accounts. Check this out
http://www.xinz.org/mobile/multiple-gmail-sign-in-gmail-login/
May 05, 2012 | gmail.com
I have samsung s5233 mobile phone and i cannot configurate my gmail account in my mobile , kindly help me
Gmail Settings For Samsung Star Cellphones:
Go To > Menu > Messages
Click Settings > Email
Then Touch >Email Setup Wizard
Notice will ocuur Touch > Ok
Give name to your account E.g Gmail
Enter your email id : yourname@gmail.com , Then Enter Password for your account.
Incoming Server type : POP3, Incoming Server : pop.gmail.com
Outgoing Server SMTP : smtp.gmail.com, Secured Connection :Off
Then touch OK & it will display your POP3email account configured successfully. Now press back button and tap on Email Accounts, then touch the email account you have just created. There some more options you just have to edit such as:
Secured Connection:Off, POP3 Port:995, SMTP Port: 587
Now,Tick The option APOP Login., Download Limit: 500
Secured connection: SSL (Choose SSL for second option only & not for first option.)
Retrieving Option: Choose Subject only
Keep On Server: Tick
My Address: youraccontname@gmail.com
Username /Password : same as you entered above
POP before SMTP : Dont Tick
SMTP Auth: Tick
Same as POP3/IMAP4 : Tick
And Finally Save All Settings and your gmail account is set up.
Sep 17, 2011 | Samsung Star GT-S5233 Cell Phone
Mozilla Thunderbird setup
    Google Gmail Outgoing Mail Server (SMTP): smtp.gmail.com
    The Gmail SMTP server requires authentication (use the same settings as for the incoming mail server)
    The Google Gmail SMTP Server requires an encrypted connection (SSL) on port 465.
    GMail uses POP3 over an SSL connection, so make sure your email client supports encrypted SSL connections.
      Google Gmail Incoming Mail Server (POP3) - pop.gmail.com (SSL enabled, port 995)Outgoing Mail Server - use the SMTP mail server address provided by your local ISP or smtp.gmail.com (SSL enabled, port 465)
Sep 21, 2008 | Computers & Internet
Email set up
you can, if you have an internet connection to your phone and a pop3 and smtp account on your email.
On jam, go to messaging >Accounts>Outlook E-Mail>Account>New Account...>Enter your e-mail Address: >next>next>Your Name>Username (Put your email login username)> Password (Your E-mail Password)>Account Type (POP3 is OK)>incoming mail (pop3 address, for gmail ,its pop.gmail.com)>Outgoing Mail (smtp server, like smtp.gmail.com)>Domain (if any)>finish.
then to connect, Accounts>connect.
Oct 09, 2007 | i-mate JAM Pocket PC
Cell Phones Logo
13 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
