Question about HP LaserJet 4 plus Printer
Hp laserjet 4 plus offline
Printer displays ready but the computer says printer is offline
    Novelist:
    Scholar:
  • 80 Answers
It sounds to me like you may be using this printer through the JetDirect interface and have the printer assigned a different IP address than what the computer is expecting. For example, if the computer is configured to find the printer at 192.168.1.205 and the printer has an address of 192.168.1.120, you will see the "printer offline" message on the computer but the printer is happily "online" according to its point of reference.
Another possibility is that the computer has the printer configured to "offline" mode. To check this, right-click on the printer and see whether there is a check mark next to "Use Printer Offline." If so, click on that option and that will remove the check mark, returning the printer to online status.
Posted on Aug 21, 2014
checkitright
  • 1362 Answers
SOURCE: hp laserjet 4 plus printer, message window "Ready", off line button shows red
You can try to do a "Cold reset"
turn off the printer hold down  the Menu/reset button and turn it back on.
Do you hear the machine go into rotation? the 4 plus has a high pitch sound follwed by the fuser turning ( you'll know when it does it) if it doesn't go into rotation then there is another problem.
Posted on Oct 15, 2007
shaggyrat
  • 1224 Answers
SOURCE: serial port on HP Laserjet 4M Plus
buy the adaptor for this these ports are called lpt ports they make adapters to run down to size
they also make a lpt printer port switch this is connected easy connect from printer to switch one printer cord then buy 2 other printer cords to hook to other computers
this is not a converter this is a switch
the printer cords can either be made on spot at most computer store or bought from fry's electronics they always have these in stock the proper lines your looking for
Posted on May 17, 2008
SOURCE: Photosmart 2575 printer is offline - won't print
I have the same problem and i have no idea how to fix it please help!!!!!
Posted on Oct 12, 2008
SOURCE: Printer status offline
I just ran into the same problem. The computers on the network that were running XP were showing the printer as "Ready", but all of the computers running Vista were showing the printer as "Offline".
After trying a number of solutions that I found on other message boards, I accidentally discovered that the problem was an IP address conflict. It seems that the server changed the address on the printer, which didn't bother the XP machines but brought the Vista machines to their knees.
Press and hold the blue button (HP called it the "Go" button) for 5 seconds, which will print a configuration report. In the TCP/IP section you will see the IP address for the printer. Next, open the Printers window, right-click on the P2015 and click Properties. Click the Ports tab. Find the port that is checked and click the "Configure Port..." button. If the "Printer Name or IP Address" field differs from the IP address on the configuration report, change it to the one on the report. It took a few seconds after hitting OK for the computer and prrinter to link up again, but that solved the problem for me.
Posted on Dec 03, 2008
hansola
  • 279 Answers
SOURCE: the HP printer is connected but the icon shows "offline"
Go to control panel, then select printers. Then, from the list of printers (if you have more than one), right click on your printer and make sure "Use printer Online" is checked.
Hope this helps.
Posted on Jan 12, 2010
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
Keeps telling me the printer is offline
Step 1:
b. Click Printer.
Step 2:
If still you are facing issues, then update the printer driver. This should fix the problem.
Update drivers: recommended links
http://windows.microsoft.com/en-US/windows-vista/Update-drivers-recommended-links
Source: Samsung SCX 5635FN Manual
Mar 02, 2014 | Samsung SCX-5635FN All-In-One Laser...
Printer offline wont print cant get back online
Step 1:
b. Click Printer.
Step 2:
For further precise instructions, please let me know the Operating Systems installed on the Computer.
Hope this helps..
Jan 12, 2014 | Canon PIXMA MX712 Wireless Inkjet Office...
The Brother MFC-7840W printer was installed on a USB connection. The printer worked the previous week albeit not for all applications but at least for the Vista word program. Now it doesn't respond to...
Hi there!
You can check if the usb cable is connected directly & securely from printer to your computer. Once it's verified. The display of your printer should show the date/time.
Since the printer is displaying offline you can open Control Panel, go to Printers folder right click on the printer icon and select 'Use printer online' If you have pending documents right click on the printer icon and click on cancel documents.
Try checking for a duplicate copy of your printer driver or check which printer driver is selected as the default and has the status ready.
Right click on the printer driver that has a Ready status click on printing preferences and click on print a test page.
Hope this helps! Vikroks
Mar 22, 2011 | Brother MFC 7840W Printer
Printer is offline and will not print. Restarting does not help.
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 10, 2010 | Office Equipment & Supplies
I have a cannon inkjet mp560. when ever I try to print it says "printer is offline" or "printer is not responding. I've tried unplugging the usb cord and turned it off and restarted it, but it will not...
Mfc7340 will not print--it was working just fine and then it errors out. Uninstalled and reinstalled and it shows ready but errors out
Hello ,
First, please make sure there is no error message displayed on the LCD screen of the printer
Now we will check the status of your printer in the printers menu in the control panel.
The printer’s status should be set to “ready”
If the printer is “paused” simply clear the print queue, right click on the printer and select “resume printing”.
If the printer says “offline”, follow these steps.
  1. Clear the printer queue
  2. Shut down the computer
  3. Unplug the USB cable from your computer and your printer
  4. Unplug the power cable from the printer and wait 15 seconds
  5. Plug the USB cable back into the printer and the computer.
  6. Plug the printer’s power cable back in.
  7. Turn your computer back on.
Your printer status should be back to ready now and you are able to print.
Thank you,
Mar 26, 2010 | Brother Office Equipment & Supplies
Printer Offline Message
If your system is showing Printer Offline message, then you need to check the status of the printer in control panel. If it is offline then you need to set it online. The following steps will help:-
1) Click start -> Control Panel -> Hardware and Sound -> Select Printer.
2) If the printer is online it shows "Ready". and if the printer is offline, then it shows "offline".
3) Set the printer online if it is showing offline.
4) Now right click the printer and select "Use Printer Online".
5) The display should change to ready.
Note:- If still you are facing the issues, then update the printer driver or you can also take assistance from any tech support provider such as AskPCExperts. To know more you can also visit: http://www.askpcexperts.com.
Jan 07, 2010 | Epson Aculaser C1100 Printer
Printer off line
The computer reports the printer as being offline because it cannot "see" the printer. Make sure the printer is turned on, that the computer is connected to the printer (either with a cable or wireless), and that the printer isn't displaying any error condition on its control panel.
Apr 15, 2009 | HP PSC 1350 All-In-One Thermal Printer
HOW DO I GET OFFLINE INTO READY ON MY PRINTER
Make sure that usb cable is connected between the computer and printer if printer is usb printer.
After this right click on printer icon and click on option use printer online after this printer will be ready for printing.
Jan 25, 2009 | HP OfficeJet 4215 All-In-One InkJet...
HP LaserJet 4 plus Printer Logo
1,531 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
