Question about Fisher and Paykel Dishwashers
Instructions to top draer door handle DD24DCTX6
2 Suggested Answers
  • 10865 Answers
SOURCE: I can not open the driver side door from the
Hi. Before you get into replacement expose the linkage and lube it good with a penetrating lubricant like WD-40. J
Posted on Jul 29, 2010
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
How do i take off the inside drivers door panel on a 2005 dodge caravan
Hi Roberta, here's the instructions on how to remove your door panel. I have to wonder though on why you are removing it, my guess is you window doesn't roll up or down and your replacing the regulator. Any way here goes.
REMOVAL
  1. Remove the plug and remove screw attaching door pull cup to inner door panel.
  2. Remove switch bezel and disconnect power window/memory switch.
  3. Remove screws attaching trim panel to door from below map pocket.
  4. If equipped, remove window crank. (Refer to 23 - BODY/DOOR - FRONT/WINDOW CRANK - REMOVAL)
  5. Remove screw holding door trim to door panel from behind inside latch release handle .
  6. Disengage clips attaching door trim to door frame around perimeter of panel.
  7. Lift trim panel upward to disengage flange from inner belt molding at top of door.
  8. Tilt top of trim panel away from door to gain access to latch linkage.
  9. Disengage clip attaching linkage rod to inside latch release handle (INSIDE DOOR HANDLE LINKAGE).
  10. Separate linkage rod from latch handle.
  11. Disconnect the power door switch, courtesy lamp electrical connectors.
  12. Remove front door trim panel from vehicle.
Hope this helps and have an awesome day Roberta!
May 21, 2014 | 2005 Dodge Grand Caravan
Need to replace door handle
1. Unplug microwave oven or disconnect power. 2. Open the microwave oven door. 3. Pry the choke cover away from the top door pin, and remove the top pin from the pivot bracket. Lift the door off the bottom bracket, and remove it. 4. Place the oven door front side down on a padded surface. 5. Remove the choke screws from the door frame. 6. Starting at the top right corner, pry the choke cover out with a putty knife, and unsnap it from the choke. Only remove the top, bottom and right sides of the choke cover at this time. You will remove the handle end of the choke cover later. 7. Starting at the top edge of the door near the center and working clockwise, use a putty knife, and pry the latching tabs of the choke out of the door frame slots. Lift the choke as you release the tabs so they do not snap back into the slots. NOTE: When you reach the handle side of door, pull both the choke and the choke cover away from the door frame, and then separate the two components. 8. To remove the door switch actuators from the choke, remove the screw from each actuator. REASSEMBLY NOTE: When you reinstall the door on the oven, insert the top pin into the pivot bracket and press down on the pin until it snaps into place
Read more: http://www.appliancepartspros.com/whirlpool-microwave-door-handle-w10246505-ap4418092.html#qa1#ixzz2qpA2P5CA
Jan 17, 2014 | Whirlpool MH3184XP Microwave Oven
Have lost installation instructions could I get a copy please?
You can get the install manual on the link below.
http://www.fisherpaykel.com//admin/pdfs/pdf_installations/599632C_DD24D_TALL_installA2_USCAw.pdf
Here is the user guide.
http://www.fisherpaykel.com//admin/pdfs/pdf_usecares/599595B_DD24_userguide_USCAw.pdf
If this is not your model Please give the correct make and model # so I can get you the right one.
Good Luck
Nov 12, 2010 | Fisher and Paykel DD24DCTX6 Dishwasher
I want to switch the side that the door opens on my refrigerator. Everything looks simple enough except where the handle meets the door. My assumption is that once I unscrew the top portion of the...
This is generic because you did not include the make and model number. Had you provided that info we most likely could have provided you with the installation instructions that would show you exactly what to do.
Having said that... To release the plastic on the top of the TOP hinge use a butter knife on top of a putty knife so you don't dent or scratch the top. Gently lift in and outward and upward direction and it will come right off. Of this us a 2 horizontal swing door model the center hinge is inverted on the opposite side. Sometimes the lower hinge is also inverted. Other times you have to remove the hinge pin and place it on the other side of the hinge bracket. It is not a difficult task but it sure is helpful to have 2 people when installing the larger door. What ever you do leave the pliers off the job / at least away from the refrigerator. You might need them to switch the lower hinge pin installed position. The door handle usually on the lower portion (Screw part) may have a plastic insert covering the screw that you can gently remove with a small knife blade prying around the edges if the insert piece. Other handles it is exactly the opposite of what you stated... you slide the handle DOWN to expose the mounting screw.
If you need more help please include your make and model number and I will do my best to find exact model installation instructions for you.
Thanks for choosing FixYa.
Kelly
Sep 03, 2010 | Refrigerators
Installing exterior driver side and passaner side door handles
I found this on another page, hope it helps:)
Remove the plastic cover behind the door handle assembly by removing one black 14mm nut from just above the door handle, and 1 screw (usually phillips) from the bottom of the plastic cover.
Remove linkages from lock cylinder and door handle assembly. Use a small flathead screwdriver to slide retaining clips forward, and linkages will come free.
Remove one black 14mm nut from the very top of the door handle assembly.
Remove one phillips screw drom the bottom of the door handle assembly.
Door handle assembly should now come free by pulling out slightly at the top, and pulling upwards.
Transfer lock cylinder and key minder light (if applicable) to new door handle assembly. Lock cylinder is retained by a single TORX bolt.
Reinstall in reverse.
TIP: If you lose or damage any of those black plastic coated nuts, order new ones. They are GM p/n 10067214 and should be around $0.58/each. There are two on each door.
Mar 02, 2009 | 1995 Pontiac Grand Prix
Check out this door frame diagram, specifically number 1805. It clips on to the door frame. Remove it using a dull table knife or something similar (be careful not to scratch or break anything). You will then have access to the bottom screw.
Mar 18, 2008 | GE Advantium SCA1000H Convection /...
Maytag electric range door handle (how to replace?)
The above solution is fine, but you don't have to remove the door.  Open the storage drawer for access to the trim screws (3) on the bottom of the door, remove the screws.  Have a helper hold the glass along the bottom. Take the three screws on the top of the door trim out.  Slide out the glass and put in a safe place.  Remove the four screws that hold the handle brackets in place, remove the handle (or tighten if loose). Install the new handle (one screw on each side).  Reinstall all parts in the reverse order of disassembly.  The entire job took less than 30 minutes.
May 01, 2007 | Maytag MER5775Q Electric Kitchen Range
Dishwashers Logo
18 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
