Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Soot is forming on my gas fire. it is fuelled by lpg. ive tried using calor gas instead of a cheap gas but its still the same . help` its driving me potty !!!!!!!!!!!!!!!
  • 58 Answers
The range is not converted or converted proberly to lp gas. they are sold to be used with natural gas and needs to be converted to handle lp
Posted on Oct 31, 2007
I bought a new frigidaire gas range and the burners are sooting. How can i fix this
check that you are using the correct gas
there are different jet sizes between LPG and natural gas and the air shrouds have to be correctly adjusted
The gas fitter doing the installation would know this
Dec 10, 2017 | Frigidaire Kitchen Ranges
Why does Oven soot up during use?
Are you on propane (LPG) or natural gas? I would guess that you are on propane, and that your oven has not been converted over to LPG correctly. The regulator needs to be set up for LPG, and the oven gas orifaces need to be tightened down, and the air valves opened up. If you don't know what these terms mean, then you need to contact a professional, because you don't want to monkey around with gas!
Aug 31, 2014 | Kitchen Ranges
Calor gas fridge freezer
you had a broken line
Jul 16, 2013 | Heating & Cooling
Should there be soot in the flue deflector? How often should this be cleaned out and what is the best way to clean this out?
Soot is formed when the fuel combustion is incomplete. Incomplete combustion may occur if the fuel is low, air and fuel mixture is not correct, wrong size of burner orifice with respect to the fuel used ( propane or natural gas).
Soot can be removed by wiping it off with a nylon scrubbing pad dipped in grease cutting solution. Check also the fire tubes for soot or carbon build up.
Apr 10, 2011 | Pitco Frialator 35CS Deep Fryer
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
When one of the gas hobs is on ,it does not burn with a blue flame but a more yellow one .also black soot forms under the burner plate.it is on lpg
Have to adjust the piolot lights for the amount of gas coming out. U have too much gas coming out(yellow flame). On older gas ranges, there was a small screw between the piolot light & burners that had to be adjusted. (if this is a older model) have to turn the screw just a little at a time, till ur flame returns to blue on ur burners. Hope this helps.
Sep 12, 2010 | Microwave Ovens
TRIDENT LPG EXCEL GAS FIRE PILOT FLAME VERY POOR AND WILL NOT RUN CONSTATLY have blown jet out etc
Hi, This needs new pilot assembly,when the fire uses lpg they have a harder time of it than with natural gas.They burn hotter and lpg is less forgiving .Let know if you need help further or parts. Will
Aug 27, 2010 | Heating & Cooling
Can we use lpg gas instead off propaine
It's best that you use the gas type and bottle size that the manufacturer recommends. Different gases burn at different temps.
Aug 14, 2010 | Thermos Grill2Go Fire+Ice
Calor gas and cookers
You need a C.O.R.G.I. (soon to be re-named "gas safe" in april) engineer qualified for LPG to sort this.
Jan 04, 2009 | Cannon 10476G Dual Fuel (Electric and Gas)...
Cannon Rhapsody LPG Gas open Fire sooting up of burners
well its my experience that ranges don't come lpg they are all made natural gas but you convert them to lpg after purchase now if the lpg conversion isn't done properly then they soot like crazy proper lpg converson is to change the spuds on the burners and to turn the orifice over in the pressure regulator do you still have your owners manuel if so consult it on converting gas range to lp then check to see if every thing was done right on the pressure regulater there is a square cap you take it off and there is a round part that on one side says lp on the other says ng this changes the pressure that the regulator as ng and lp operates at different pressures and the regulator has to be set for what you using like i said im not familiar with your brand or model but i do know the problem if the range did come ng then you need to make sure the conversion most ranges aren't lp because there is not that big a market for it read the plate on the back will tell you if it was made ng or lp serial plate on front may say also most of the time it is beside the bottom drawer on the range
Jan 18, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
191 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
